Question about Sport & Outdoor - Others
How do you reset the nordic track apex 6100 xi i paid a repair person $100 dollars to hit 3 buttons but now i can not remember. can you tell me what 3 button and in what Sequence
With the key in the console, press one of the incline buttons. While the incline is changing, remove the key. After a few seconds, re-insert the key. The treadmill will automatically rise to the maximum incline level and then return to the minimum level. This will recalibrate the incline system.
Posted on Sep 20, 2010
What is the phone number for Nordic Track Support desk?
NordicTrack Customer Service Department at 1-877-993-7999.
Sep 04, 2014 | Nordic Track Nordictrack Apex 6100xi...
I have a Nordic track commercial1500 and the belt motor will not run. Everything else works fine. The fuse is good on the board.
1) see if the belt is tight or loose, repair or replace the belt
2) test the input voltage motor, if there ARE the motor need repair see my personal TIPS for motor help
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulyt, replace see the b.diagram attached.
Jan 09, 2013 | Nordic Track NordicTrack Commercial 1500...
Does a nordic track commercial 1500 have a fuse?
see my personal TIPS specially block diagram, if you will see the fuse for every treadmills.
2) Reset the c.breaker too.
3) Reset the c.breaker from your house outlet wall.
4) Test the power cord for wires, break, loose, or burn and repair.
5) Test the power switch, for open or shor. see the diagram attached.
sincerely. God bless you
May 08, 2012 | Nordic Track NordicTrack Commercial 1500...
My nordic track apex 6100 xi all of the sudden won't run...or walk...at all? HELP!
Dear Sir:
This is probably a 1) faulty speed sensor or 2) the speed sensor is not plugged in properly. Its also possibly a 3)faulty motor control board or lower board.4)the drive motor is faulty 5) The drive belt is broken.6) Resent c.breaker 7) Test the power cord. 8) Reset the c. breaker from your home. 9) Do not use extension cord .
Adjust the speed sensor see the diagram, and RUN your software calibration for easy diagnose and troubleshooting. read your user manual.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 11, 2012 | Nordic Track NordicTrack Elite zi...
BUYER BEWARE!! I purchased the Nordic Track C2500 in 2009 and after 2 years of moderate usage (105 lb women walking 3-4 times a week) the console stopped working. None of the buttons respond and it beeps...
Watch this video:
http://www.youtube.com/watch?v=E-q-uS4t6so
1. Power
o 1
Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet. Do not use an extension cord.
o 2
Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place.
o 3
Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 540S and a horizontal switch on the 540 Interactive Trainer. Press it to the "Reset" position, which will be labeled.
2. Reed Switch
o 1
Unplug the treadmill and remove the safety key.
o 2
Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 540 Interactive trainer and four screws on the 540S.
o 3
Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models.
o 4
Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw.
o 5
Reverse the directions to put the hood back on and the treadmill upright in the original position.
Check too:Optical Sensor. If have it
Sep 22, 2011 | Nordic Track NordicTrack Treadmill, A2550
Nortrak 4100i wont go up or down
hold down stop and speed + then put safety key on
hit stop once
push incline+
let it go up and down
take key off and reattach
try
if it still doesn't go the incline motor is bad
Aug 07, 2010 | Nordic Track Nordictrack Apex 4100i...
Manual for a Nordic Track Personal Performance
Go to iconservice.com click on to manual Input manufacturer : Nordic Track then model # NTL349050 and you manual await you.
May 13, 2010 | Nordic Track NordicTrack Professional...
Nordic Track exp 2000I. Consol lights, buttons do not work.
If the console lights up but the buttons don't work, then unfortunately it's probably the console and they're not repairable that I know of. You may want to check the wiring harness and the connections at the console and at the controller under the motor hood. Pull them apart and check for bent pins. If they look good, the console is most likely bad.
Mar 04, 2010 | Nordic Track Nordictrack Apex 4100i...
Reset programs
Hello there, If you go to iconservice.com you will be able to find a free downloadable pdf file there under the manuals section. Then select nordictrack in the brand and then put apex 6100 in the model name then do a search. You will see a list of manuals come up. Pick the correct model number. (located on the lower frame below the walk belt.)
Download and print.
There are instructions in there on the custom programs and how to set them up.
Good Luck! Tim
Jan 17, 2010 | Nordic Track NordicTrack Professional...
Squeaking when i run on nordic track 5100r
My treadmill (American Motion Fitness) squeaks when only when  it warms up. I spray CRC oil onto the front roller bolts which bolt it to the swivel housing and onto the bolts which bolt the swivel housing onto the main frame also onto the rubber bushings which allow the front roller to bounce every time my foot hits the deck. I seem to have to do this 1 per week but it is easy to get at and takes 2 minutes. cheers johnO
Apr 29, 2009 | Nordic Track Nordictrack Apex 4100i...
Sport & Outdoor - Others Logo
308 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
