Question about Toshiba 36A40 36" TV
Television will not power on. Wall plug is good, Television is plugged in. Can it be a fuse??
  • 387 Answers
Yes it have fuse but you check and tell what are the reading of components inside, power supply. horizontal output etc
Posted on Sep 13, 2010
  • stans2 Sep 13, 2010
    So how can I check to see if the fuse is any good??
I have a nad 3130 amplifier which has been in storage for sometime. I've plugged it in and I have no power to the amp.
If the fuses are good....do this.....
1...unplug the amp from the wall AND KEEP IT UNPLUGGED !!!
2 Turn the power switch on ( again , the amp is UNPLUGGED from the wall )
3 with an ohm meter or a multimeter set on ohms., measure the ohms across the ac cord that plugs into the wall....in other words...take one meter lead and touch it to only one " blade" that plugs into the wall and keep it touching the " blade".....while you are holding it there, touch the other meter lead to the other " blade " that plugs into the wall.....you should get a very low ohm reading ( 2-50 ohms )......if it is over that number, your transformer or your switch is open ( toast ). hopefully it is the switch as transformers are un-available......good luck, be safe, and if you arent sure....ask before doing something silly.....Rob
Apr 03, 2015 | NAD Audio Players & Recorders
Phillips Television Model: AK01 will not power on when plugged in. Why?
there is a fuse in the back of the set . It is normally a small glass fuse ,fairly short and looks something like a auto fuse. SAFETY FIRST ---ENSURE THAT THE POWER LEAD IS DISCONNECTED FROM THE WALL OUTLET BEFORE REMOVING THE BACK PANEL The fuse will be on the power wires before the transformer.
Nov 22, 2013 | Cars & Trucks
Won't power on.
Check to see if the cord is plugged in to the wall. Check to see if the wall outlet has power. If it does it may be the power supply or a burnt fuse in the TV and will need to be serviced.
Nov 22, 2010 | Akai LCT3201AD 32 in. LCD Television
Sony Grand Wega KF-WE50, no LED lights, wont turn on, fuse is OK ?
Try plugging into another known good wall outlet. if still not standby light then the power board needs replaced.
Mar 30, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Mitsubishi tv vs 60707 fuse keeps blowing everytime i plug it it
1. unplug from the wall
2. cut off the end of the power cord
3. splice the plug from an extension cord
4. tape it up real good
5. try again
Feb 04, 2010 | Mitsubishi VS-60707 60" Rear Projection...
One day just would not turn on, fuse maybe?
Possibly. However, I would try rebooting the unit first. Unplug the TV from the power supply for about 5 minutes. Then reconnect and try to turn the unit on. If it still does not work, plug a lamp into the wall socket where you have the TV plugged into. If the lamp lights, then you're getting power to the wall socket. If you have the TV plugged into one of those "power strips" check that it is turned on. If so, plug the TV directly into the wall socket. If it comes on, then you have a bad power strip. If the TV still does not come on, you'll probably need repair service.
Dec 01, 2009 | iLO 3200 32 in. LCD Television
No Power
Usually there is no fuse in the printer itself. The big block that you plug into the wall is actually a transformer. It converts the 120V power from the wall outlet to a much lower voltage and also converts it to DC power.take the plug in end with the cube transformer in it and bring under a good light and it will read the specifications about that power converter. What sometimes happens is that the transformer inside that cube fails (through various causes) and thus produces no voltage or the wrong voltage. Take the plug with you to an electronics store of your choice and they will direct you to a universal 120AC to a DC transformer (it will have various settings and various plug adapters) and then follow the instructions to match the voltage on the old power converter. I hope this helps you out.
Jun 04, 2009 | HP Photosmart 3210 Printer
Akai hd projection tv pt4299hd won't turn on
Sounds like a power supply issue. Does the power indicator light up? Can you hear a click when the power button is pressed?
May 31, 2008 | Akai PT4298HD Rear Projection Television
Follow up on "no power to my tv"
Let me give an idea ...after the fuse you have the bridge rectifiers and it can be all in one package or 4 individual diodes after that you have a big filter capacitor and then a power transistor called the switch mode regulator,this are major parts that can make the fuse blow up right away as soon as you plug the set in wall but these parts work along with about 30 other minor parts.If the fuse blew up at plug in it can be one of these but if it blew at turn on from the power botton it can go farther down the power supply,is hard to tell how much is damage and how much it will cost.Get an estimate and then decide.Good luck
Oct 02, 2006 | RCA D61W20 61" Rear Projection Television
Toshiba 36A40 36" TV Logo
37 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
