Question about Blaupunkt MP3000 CD Player
When I insert a cd it states sled error - Blaupunkt MP3000 CD Player
I inserted the CD but it is repeating the same thing over and over. What should I do?
the sled may be stuck.Take it apart and manually work the worm gear drive back and forth and oil it. The sled holds the laser assembly. Larry
Aug 14, 2015 | Insignia - Laser Lens Cleaner
Cd player
Check its sled motor and optical pickup unit. If anyone among this do not work properlay, thei fault will occur.
May 01, 2012 | JVC MX-GT80 Shelf System
Cd wont play it picks up an goes around but wont play need to know what to do
It sounds that the optical pickup unit to your player is faulty. Open the top cover of the player, power it ON and insert a CD in to. Check whether the inserted CD loads well into the mechanism and spins. If do not spins, sled motor is faulty. If it spins, optical pickup unit should be replaced.
Apr 23, 2012 | Durabrand CD2160 Shelf System
CDJ NOT READING CDS. STATES (DISC ERROR)
If it shows No Disc error to all CDs, either its Sled Motor [The motor which spins the disc inside], or its optical picku unit has the fault. You have to contact the nearest Denon authorised service center to get it repaired, as Denon uses special type machanism with theirs sets, and it can't be available at open electonic spare part market.
Apr 23, 2012 | Denon DN-S700
RCA RP 3755 Clock radio: CD player will not spin
Hello
Check the voltage at the terminals of the sled motor. If it is found OK, replace the sled motor. Sled motor do spins the disc inside for any CD players. See the picture of its position.3_1_2012_3_05_08_pm.jpg
Feb 29, 2012 | RCA Audio Players & Recorders
Ez25eb-s error code U81
Hello
The display may not be U81. It may be C31. There are only three Self Diagnosis Dispay will be there, They are [C13, C31 & E XX]. If it is C31, DVD/CD inserted is not correct. Reinsert it correctly. If the same display comes again, open it and check whether the inserted disc spins or not. If the inserted disc does not spins; due to some other trouble, usually with the faut to sled motor; this display will be there. Check it. OK.
Nov 05, 2011 | Televison & Video
Insignia cd player that reads no disc when it is turned on with a cd installed
Hello
Check whether the inserted CD spins inside your unit or not. If it spins, and the set does not recogonize the disc, the laser pickup assembly has the trouble and should be replaced with same type and number. If it does not spins, the sled motor, the motor that spins the disc, is faulty and should be replaced. OK.
Jul 02, 2011 | Insignia 75W DVD/CD/HD Radio Compact Shelf...
While playing A cd the sound intermittenly stops like A skip and sound comes back but player is never moved
If the CD is the problem it could be scratched or dirty, clean the CD with a CD Cleaner if need be. If the CD mechanism is the problem the sled assembly may not be moving smoothly or is hindered ( the sled mech moves the laser across the CD like a needle arm move the needle across a record), the laser lens may be dirty also. Use a CD lens cleaner to clean the lens if you can not manually clean it with some lens cleaner and a swab. If the sled mechnism is the problem the unit may need to be taken in for service.
Jun 27, 2010 | Durabrand CD Player with Cassette...
Tascam Mixwell - CD-DJ1
on putting in the cd and shutting the lid an error occurs. on the screen it reads' remain err sled' and the cd is not spinning. what is the problem???
Dec 29, 2007 | Audio Players & Recorders
Cd player
M-Error is a mechanical error and could have a multitude of causes. just went through it with a TAD-5160 unit where it was a small slip gear moving a tin lever to ingage the transport sled to insert or eject the disk from and to the carusel. You may have to take the unit apart and asess the problem. Harleysp.
Mar 19, 2007 | Fisher 9925 Shelf System
Blaupunkt MP3000 CD Player Logo
29 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
