Not able to start...keyboard as no response to touch
    Sergeant:
  • 284 Answers
Do you mean that pc not working nor u getting any beep..nor keyboard responding??it seems some hardware issue with you pc try to remove ram and install bac????
Posted on Sep 13, 2010
My keyboard is ctk 501 can i transform it into a touch response keyboard/
Simply no, it does not have velocity sensitive circuitry.
Nov 24, 2014 | Music
HOW TO USE TOUCH RESPONSE
There are two samples for each note in the "Piano" sound samples. This allows you to play "soft = p" or "Loud = f" based on how hard you hit the keys.
The default setting of 2 suit most people. You can change the touch response to 3 (more hard) or 1 (less hard). With tough response set to 3 - you play mostly the soft samples until you bang the key much harder.
This is a keyboard that tries to give a bit of effect that an acoustic piano hammer mechanism would give.
Oct 29, 2012 | Casio Lk-110 Keyboard
Yamaha v50 touch response
how to activate touch response Yamaha v 50
Oct 25, 2012 | Yamaha Full-Size Keyboard
Yamaha PSR S900 keyboard failure, in touch response mode when I hold one key (G) and touch another the second key produces a sound that is full volume just as if the "touch response mode "...
That is NOT touch response, but velocity sensing. Each key has two contacts and one closes before the other to facilitate measuring the key velocity. In your case, it sounds like the key you are holding down has a bad disconnect diode in the key matrix and is holding the "first contact" signal true so the next key senses max closure speed. If you are not electronically adept, you need to take it in for servicing... however first tip the thing and vibrate it as some contamination MAY be shorting a line in the key matrix. Staples and paper clips are notorious problems with keyboards when they get into the key area.
Oct 31, 2010 | Yamaha Music
Keyboard not responding.
Your problem sounds more like the system running slow rather than the keyboard being the issue.
Do routine maintenance and cleanup on your system to see if it helps it.
To start the Disk Cleanup tool and specify the hard disk to clean by using a command line, use the following steps:
  1. Click Start, and then click Run.
  2. In the Open box, type the following line and then press ENTER
    cleanmgr
  3. click OK
  4. The dialog box that opens shows you the files it will remove to clean up the system
  5. Make sure Temporary files is checked
  6. Click OK
Then check your system for malicious software.
  1. Go to http://malwarebytes.org
  2. Download and scan the system
  3. Remove all found infections.
  4. Restart your system
These things should help if this is the cause.
If your problem still is present, change the battery in the keyboard. A battery that is close to empty will cause this as well.
Let me know if this resolves your issue.
May 15, 2010 | Logitech 967461-0403-PK Keyboard/Mouse
This post seems to be a duplicate of one posted under the name of Guest, so, I am pasting the solution here just in case you have not gotten notification of resolution suggestions.
    cleanmgr
  3. click OK
  6. Click OK
Mar 26, 2010 | Logitech 967461-0403-PK Keyboard/Mouse
Need a owners manual
Go to http://www.casio.com/support/manuals/ Select musical instruments. Agree to terms. Select your keyboard from the list and download the manual.
Jun 01, 2009 | Casio Computers & Internet
Sony PS3 wireless keyboard non responsive only blinks green light
Hit the Reset Button on the Keypad (Its a little hole on the left of the back). It works all the time.
Apr 25, 2009 | Sony Playstation 3 Wireless Keypad/Mouse
Touch pad failed.
Look along the top of the keyboard for an "f key" that shows a "touch pad" icon, IF you see it, press the "function key" (along the bottom of the keyboard) PLUS at the same time the "f key" (that you found along the top) and that should "toggle" the touch pad back on....
Also, IF you plug in a USB mouse that will allow you to move the cursor around--but the USB mouse doesn't fix your touch pad problem.
Hope this helps.
Oct 04, 2008 | Toshiba Satellite A65-S1065 Notebook
Computers & Internet Logo
David Payne
David Payne
