Question about Whirlpool Duet GHW9150P Front Load Washer
What does f 20 represent - Whirlpool Duet GHW9150P Front Load Washer
  • 15,935 Answers
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a plastic air hose attached. Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) – with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub. There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU. In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 13, 2010
How can I log in to my account
try opening site / account you want and sign in if problem notify customer service of that account
Jul 08, 2017 | Computers & Internet
I am installing a 330A 220v QO in my sub panel in the garage. Does the top clips have to connect to the metal strips on top. I noticed the opening on the end just has a plastic peg.
A Square D QOABB is a QO style circuit breaker, as determined by the "QO". A represents the number of poles; and can be 1, 2 or 3. This number also represent the number of spaces it requires in the panel (NOT the cover). "BB" represents the Amp rating of the handle. Common values are 15, 20, 30, 40, 50, 60, and beyond. A Square D QO3100 (3Pole 100A) is pictured below:
A Square D QOTXXYY is a tandem circuit breaker. "T" represents Tandem. "XX" is the amp rating of one handle and "YY" is the amp rating of the second handle. It occupies one singe slot in the panel (again, NOT the cover). It look like this QOT2020 (A single pole breaker with tandem 20 amp handles) below:
The clip under terminal screws engages the panel's "rail", and the other clip(s) must engage the panel's powered bus or "metal" strips as you called them. If you are installing a QO230, BOTH clips MUST engage. If only one engages, you will only have 120 Volts to ground, and may not be able to put the panel cover on.
I hope this helps and good luck!
Apr 02, 2012 | Square D Circuit Breaker QO220GFI
How many tons is this Carrier unit? Model #38AH-034---610AA Serial #OBO1F65263
This is a 30 Ton Hi Efficiency Gemini series unit from carrier you can matched to either of these air handlers.
40RM028 40RM034
Model is broken down in sections
38AH = carrier Gemini series units from 20 to 120 tons the numbers following the dash represent the size 024 = 20 028 = 25 034 =30 044 = 40 054 =50 the list goes on in increments of 10 untill it reaches 130 tons 134=130
Hope this helps
Best of Luck
Jun 01, 2011 | Carrier Heating & Cooling
How can i get my Authorization code for adobe Photoshop cs3? My serial number is 1045-1090-6246-8353-3166-2968 Activation number 5053-8469-2611-8128-6347-4470-4063 Activation type Normal:...
First off, you shouldn't be posting your serial numbers online for everyone to see. But to answer your question, you can activate online or by phone. Although it is faster to activate over the Internet, you can call Adobe activation too. Call 866-772-3623 and be at your computer. Have the activation number provided in the Activation screen ready to give to the Adobe representative. The representative then gives you an activation authorization code.
Feb 28, 2011 | Adobe Computers & Internet
University theater sold 444 tickets for a play. Tickets cost $20 per adult and $15 per senior citizen. If total receipts were $7345 how many senior citizen tickets were sold?
Let A = number of adult tickets and S = number of senior tickets.
The total number of tickets is 444. This equals A + S.
444 = A + S
Total receipts were $7345. This can be represented as:
7345 = A*20 + S*15
Solve for A in first equation.
A = 444 - S
Substitute this into the 2nd equation for A
7345 = (444 - S)*20 + S*15
Solve for S
7345 = 8880 - 20*S + 15*S
7345 = 8880 - 5*S
-1535 = -5*S
307 = S
Therefore there were 307 senior tickets sold.
The number of adult tickets would be 444-307 = 137
May 14, 2010 | SoftMath Algebrator - Algebra Homework...
My cd reads e20 wont play tried cleaning same problem pont gfand am gt
The E-20 represents a failed optics assembly. have this assembly replaced asap. this will fix your issue.
Jun 14, 2009 | 1999 Pontiac Grand Am GT
Poisson
Hello
To raise a number to any power you use the [^] caret key or on some calculators the [x^y] (x raised to exponent y)
20^(4) =160000
20 to the power of negative 3
20[^] 3 [(-) or +/-] ENTER gives 1.25x10^(-4) = 0.000125 (-) is the small minus sign.
If that gives you a syntax error
20[^] [(-) or +/-] 3[ENTER] = 0.000125
27 [^] (1/3] represents the cube root of 27 which is 3.
Hope it helps.
Oct 20, 2008 | Texas Instruments TI-30 XIIS Calculator
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
