Leer 700 series tonneau cover installation manual
SOURCE: Hard tonneau cover
I guess I should have checked it out before posting this. It was easy. It was just a matter of clamping the rails to the sides and front of the box, sliding the cover into the 2 slots in the front, and voila!
Posted on Aug 30, 2008
  • 25 Answers
SOURCE: Tonneau cover clamps
YOU SHOULD HANG OUT AT YOUR LOCAL TIM HORTONS UNTIL SOMEONE WITH A SIMULAR TONNEAU COMES IN ...JUST OFFER TO BUY THE PERSON A COFFEE, IF THEY WILL SHOW YOU THEIR CLAMPS....TAKE A PICTURE OR 2 WITH YOUR CELL PHONE....PROBLEM SOLVED.
PLEASE RATE THIS,
ROB...
Posted on Sep 18, 2008
mccorkle2008
one side of mine wouldnt unlock i sprayed it with like a wd40 then if still wouldnt come off i removed it from the top and let the bar hang inside the truck then took a pair of pliers and gently pulled up on the release and without the cover bein still attached it had no pressure and came off a little easier
Posted on Jan 24, 2009
  • 510 Answers
SOURCE: how to remove nissan pathfinder tonneau cover
If you mean bonnet release its under dash above pedals
Posted on Nov 14, 2009
  • 248 Answers
SOURCE: fibreglass tonneau cover tailgate latch fasteners are loose.
take it to a body shop or dealership
Posted on Mar 07, 2010
07 corvette top will retract but deck lid makes no effort to close, then top will not go back up. Need to release pressure in block lift top up about 1/4 of way then top will go back up
Manually Moving the Folding Top from the Down Position
Important: Allow the system a minimum of four minutes to bleed down pressure after the last cycle.
Manually release the folding top cover latch using the emergency release cable.
Raise the folding top stowage cover.
Manually raise the folding top, holding the 5 bow up.
Manually lower and latch the folding top stowage cover.
Manually unfold the top and latch per normal procedure.
Manually Moving the Folding Top from the Up Position
Manually release header latch per normal operation.
Manually lift front of roof off of the header and raise the #5 bow at the same time.
Manually release the Folding Top Cover latch using the emergency release cable.
Fold the roof down into the well.
Manually close and latch the folding top stowage cover.
Power Folding Top System Components
The power folding top system consists of the following components:
• Folding top control (FTC) module
• Body control module (BCM)
• Folding top control switch
• Serial data communication
• Folding top cover latch actuator
• Folding top cover pull down actuator
• Folding top pump motor with valve manifold
• Position switches and limit switches:
- Pin receiver switch
- Luggage barrier switch
- Folding top cover open switch
- Top open switch
- Top closed switch
- 5 bow raised switch
- 5 bow lowered switch
• Tonneau release relay
• TONNEAU PULL DOWN ACTUATOR Fuse 20 A
• TONNEAU RELEASE Fuse 10 A
• BATT 2 Fuse 40 A
• REAR FOG/ALDL TOP SW Fuse 10 A
• Folding top mechanical components:
- Folding top
- Folding top cover
- Folding top valve 1
- Folding top valve 2
- Folding top valve 3
- Hydraulic lines and cylinders
Folding Top Cover Latch Actuator
The power folding top system includes a folding top cover that is powered open and close by a hydraulic system that is controlled by the FTC module. A power unlatch motor is used to unlatch the folding top cover before the folding top control (FTC) module powers the top cover open. The folding top cover unlatching is requested by the FTC module via class 2 message, but is executed by the body control module (BCM). When requested, the BCM applies battery voltage through the folding top cover release relay control circuit to the tonneau release relay. The relay is energized and battery voltage is applied through the folding top cover release control circuit to the latch actuator. The actuator is energized and the latch releases the folding top cover.
The electronics on this are very complex ,
System Operation
Before any movement of the power folding top is allowed, the folding top control (FTC) module must be aware of the following conditions:
• Unlatch the header. The FTC module reads the pin receiver switch is Inactive.
• The windows must be normalized. Refer to Power Window Reinitialization.
• The ignition must be placed in Accessory or RUN.
• The transmission must be placed in PARK, or with manual transmission, the park brake must be applied.
• Trunk status must not be ajar.
• The luggage barrier must be in place.
• The pump motor temperature must be within the operating range.
After the last cycle of power folding top operation, allow the hydraulic system a minimum of 4 minutes to bleed down before attempting manual operation of the top.
Your best bet take and have it checked for DTC'S - diagnostic trouble codes .
DTC B3666 Rear Tonneau Position Error
DTC B3667 Tonneau Release Circuit
DTC B1011
DTC B1291
DTC B1420
DTC B3602
DTC B3666
DTC B3667
DTC B3670
DTC B3971
Jan 23, 2017 | 2007 Chevrolet Corvette Convertible
1999 saab 9-3 tonneau cover releases but will not open.
Whatever the issue you will be unable to get parts (and you will need them for this type of problem), sorry you got taken in when you bought this car by GM
Jul 12, 2016 | 1999 Saab 9-3
What is better for a truck , a tonneau cover or a cap.
I think the answer , cap vs tonneau, is a matter of functionality. It depends on how much storage capacity you are needing. With the cap, you have to climb into the back if items are stored towards the front of the bed. With the tonneau, you have easy access to the whole bed, but on the other hand, there is much more storage capacity with the cap. The Tonneau top is popular due to it's more sleek look. There are many designs for both tops.
May 30, 2014 | Cars & Trucks
Tonneau cover broken rewind
there is no alternative but for you to rewind the cover by hand and then get the spring mechanism repaired /replaced .
Apr 19, 2014 | 2004 Hyundai Santa Fe
False start
Yes my Tonneau cover used to start on me all the time and drive away in my truck leaving me to have to walk home in the cold all by myself.
Sep 10, 2013 | Revolution Tonneau Cover 1967-1972 Chevy...
Tonneau cover
I've seen a lot of <a href="http://www.hitchcity.com/CapsCovers-Covers.html">tonneau covers in Toronto</a> just be removed and re-installed and that usually takes care of any problem. Try it out.
May 10, 2013 | 1999 BMW 328 Series
Hard tonneau cover
Aug 27, 2008 | 1998 Ford Ranger SuperCab
PLEASE RATE THIS,
ROB...
Jun 28, 2008 | 2004 Chevrolet Colorado
Presario 700
Hey check the following link for compaq presario 700 manual:
http://www.geocities.com/hpmsgs/700xx/
Nov 18, 2007 | Compaq PRESARIO 700 SERIES 14.1 LCD Hinge...
Computers & Internet Logo
1,238 people viewed this question
David Payne
David Payne
