Question about Pentax ME Super 35mm SLR Camera
I Have a Pentax Me Super. The camera seems to be in mint condition. Shutter works well, film advances and can also be unwounded without a problem. Only problem is that every time I have gone to develop the film, the film is just blank. I have no idea what it could be. I'm leaning towards the fact that it could be the batteries, but I'm not so convinced that that is the actual problem. Any-who, please help!
    Brigadier General:
  • 3,006 Answers
The camera is almost totally battery dependent for operation. There is just one mechanical shutter speed (the 125X setting). On any other setting the camera needs battery power to fire the shutter. To check the batteries set the camera to M or Auto and halfway press the shutter whilst looking through the viewfinder. With good batteries one of the LED lamps will illuminate between 2000 and 4s continuously. With weak batteries, the LED's will flicker on and off. With dead batteries no lights at all will appear.
Blank film means that the film has not been exposed. If you're sure that the film is advancing correctly then it means that the shutter is probably not operating. To test it, open the camera back and hold the camera up to a bright light with the lens cap removed. Set the lens aperture to it's widest setting (i.e. lowest number) and fire the shutter. You should see at least some light briefly appearing. If not, set the camera to 125X and try again. If no light then you have a faulty shutter assembly. A faulty shutter really needs professional attention, but due to age and a lack of spares you'll find it difficult to find a camera technician who is willing to help unless you pay up front (don't expect much of a refund, if any, if the camera proves to be unrepairable). In any case, the repairs will exceed the camera's value, but given that the same may be said of almost all 35mm SLR's now it's a question of how much do you personally value your camera?
If you do get a professional repair, then take the chance to get the foam light seals and mirror buffer replaced at the same time if it hasn't already been done. The original material will be well into decomposing by now and modern replacement materials don't suffer the same fate, so it's a modest one-off investment. An ME super in good condition is scarce and collectable even though it's not worth much, and far more importantly it's a great camera to use. Shoot on transparencies and scan the results and you can achieve results which are comparable to the best digital SLR's. Unlike a digital SLR, your camera should last much longer if it can be repaired.
Posted on Sep 13, 2010
Testimonial: "Thank you! I changed the batteries and hopefully it will work."
Pentax ME super advance film doesn't get caught
This is a known fault with this retro model, I'm afraid - over time, the plastic gears get worn, and eventually fail. Solutions are mentioned on the Pentax Forums.
Aug 19, 2017 | Pentax ME Super 35mm SLR Camera
Is my ME Super toast?
It doesn't need batteries to shoot. You can use it on manual without batteries, but the exposure meter won't work (if you know what you're doing you can go by). But the stuck mirror should be fixed. It could be just plain dirty/rusty/bent etc.
The advance lever might be gone since it won't 'click'. A professional shop can fix it, but the one you tried doesn't sound very professional...
Jun 09, 2009 | Pentax ME Super 35mm SLR Camera
Pentax me super can not advance the film advance
if the re-wind button is not stuck in, then the tab on the advance shaft is broken off. this small piece of metal will jamb the gears eventually.
take or send your camera to a repair shop for a cost estimate before repair as there are no new parts available for this model .
Jun 08, 2009 | Pentax ME Super 35mm SLR Camera
Film won't advance
Pentax ME Super was one of my favorite camera, small and clean shutter release. But it has been about 25 years since it was manufactured. They happen to use rubber break within shutter unit and as any rubbers, it started to deteriorate and melt between the shutter-blades. This prevents the complete cycle of the shutter and jams the winding. You may be able to unjam the winding but eventually you have to overhaul the shutter unit. Overhaul charge is around $100 in US repair market. -James
Mar 31, 2009 | Pentax ME Super 35mm SLR Camera
Pentax ME Super Shutter and Rapid Wind Button...
anmolag,
it could be the rubber bumper next to the fresnel lens has become sticky. very gently ( after removing lens ) try to bring mirror down without forcing it. it should release easily.
if not, rotate the select knob off auto. open film door and check that the shutter is fully deployed, shutters should not be overlapping.
remove screws from bottom cover and remove cover, keep camera up side down so that re-wind button stays put. there is a locking lever under the take up spool ( gray ) . with a pin move lever toward film door and bring advance lever fully to the right , then let it go so it returns quickly.
the shutter should have fired. if not the camera will need to be repaired. get an estimate first as there are no new parts available.
Dec 24, 2008 | Pentax ME Super 35mm SLR Camera
Loading film in my vintage camera..help!
The "magic needles" while making the camera easy to load are about as intuitive as a dead skunk, I had a similar confusion when I got an ME Super. Put the film can in the left side of the camera back (the side with the little thing sticking out is the bottom, it looks upside down this way, but that is correct). Next push the film winder down, this will semi-lock the can into place. Now pull the film-lead across the camera and push it down between some of the white "magic needles on the opposite spool(push it in a bit so that it will stay). Next advance the lever; release the shutter. If the spool starts to turn you are doing it right. Now close the door and continue advancing and clicking until the little frame number window on top reads 1.
May 19, 2008 | Pentax ME Super 35mm SLR Camera
Pentax ME shutter triggered just from advancing film
miraje,
the shutter locking lever is sticking. time for a clean, lube & adjust.
i would take, or send this fine rugged camera to a reputable camera repair shop, have an estimate for a cla.
This model pentax is made with very little plastic and will last a long time with an occasional cla.
Apr 02, 2008 | Pentax ME Super 35mm SLR Camera
Film will not advance
Pressing the rewind button wind the film advance lever,if it is free It will set to its place. Release the rewind button, press the shutter release button.Once again try wind the film.( provided your camera is not fitted with motor wind )
Then your winding gears need cleaning
Jan 18, 2008 | Pentax ME Super 35mm SLR Camera
Pentax ME slr (old hand film wind )
the film might not have been catching onto the wheel it has happend to me befor
Oct 05, 2007 | Pentax ME Super 35mm SLR Camera
Film advance lever
Your camera is cocked but since the shutter is not working you cannot release it and hence your film advance mechanism does not work. ME-super will work without batteries in full manual mode so set your shutter to B and try to release it. If the shutter will not release in B mode then the shutter/mirror box will need servicing : rubber components in the mirror box mechanism have perished and need replacing. After that your camera will be fine for another couple of years.
Sep 18, 2007 | Pentax ME Super 35mm SLR Camera
Pentax ME Super 35mm SLR Camera Logo
499 people viewed this question
Top Pentax Photography Experts
Bill Eager
Greg Cann
Greg Cann
Are you a Pentax Photography Expert? Answer questions, earn points and help others
