Question about HP PSC 1350 All-In-One Thermal Printer
Slow printing my hp hsc 1350 all-in-one prints extremely slow.. and i just replaced the black in cartridge... tried a lot of troubleshooting, including re-installing drivers.. still slow... HELP.. i need to print wedding invitations
Change the ink cartridge. Worked for me.
Posted on Sep 27, 2008
Unplug and disconnect all cables from printer. Grasp printer firmly on both sides. Lift and carry to nearest garbage can. Deposit. Go to store and buy a new printer. They're really cheap nowadays.
Posted on Sep 25, 2008
  • 28 Answers
Try to verify your RAM space or do the following:
Step one: Verifying the amount of RAM
  1. Verify the amount of RAM installed in the computer.
  2. Determine the amount of memory currently in use by background programs or processes.
    Programs/processes will run in the background even when no applications are running. Most of these programs/processes will be indicated by an icon in the lower right corner next to the time.
    Less memory available for applications will result is slower processing time and consequently, printing speed.
    To determine processes running in Windows 2000/XP , do the following:
    1. Press Ctrl , Alt , and Delete simultaneously and then release.
    2. From the Windows Security box, select Task Manager.
    3. Click the Processes tab to view all running processes.
    4. Click the Performance tab to view the total and available amount of memory.
    To determine processes running in Windows 98 , do the following:
    1. Open the Device Manager .
    2. Click the Performance tab.
      The available system resources will display as a percentage.
  3. Turn off unnecessary background processes.
    This will free up system resources and increase printing speed.
    To turn off processes in Windows 98/ME/XP , do the following:
    1. Click Start , Run , and type msconfig .
    2. From the System Configuration Utility, click the Startup tab.
    3. Determine what processes are unnecessary and remove the checkmark those items.
Step two: Verifying the amount of hard drive space Follow the steps below to determine the amount of hard drive space on the main drive.
  1. Open My Computer , right-click the C drive, and then click Properties .
    This will display a chart along with the total hard drive space, used space, and available space.
  2. Verify that there is at least 2-3 GB of hard drive space available.
    The computer will require at least this amount to process printing data for simple text files, more for image files. The lower the amount of available hard drive space, will greater the time to process print data.
Step three: Ensuring the paper sensor is clean and not damaged The all-in-one product paper sensor plays an important role in determining the print speed.
Printing a self-test or demo page will ensure that the paper sensor is in proper working condition. If the page completes in less than 40 seconds, the sensor is working correctly.
Even if the sensor is working correctly, the printer driver might need to have the paper sensor turned off. To turn off the sensor, follow the steps below:
  1. Open the Printer folder, right-click the printer and click Printing Preferences or Properties .
  2. From the Properties box, click the Paper/Quality or Features tab.
  3. Under the Paper Type section, open the menu and select Plain Paper instead of Automatic.
    This will disable the paper sensor and increase the print speed.
Posted on Sep 05, 2008
SLOW PRINTER
You have a cartridge problem.
This condition is typically caused by one of the cartridges failing. Try removing the black cartridge and printing (not copying) a test page. If this prints at near normal speed the black cartridge is at fault and should be replaced. If the printer still prints slowly then put the black cartridge back in and remove the color cartridge, then print a page. Replacing the cartridge that causes the slow printing with a fresh cartridge will resolve the issue.
May 03, 2012 | HP Office Equipment & Supplies
HP Office jet printer slow
I think it's that black cartridge!
The problem you've described is typically caused by one of the cartridges failing. Try removing the black cartridge and printing (not copying) a test page. If this prints at near normal speed the black cartridge is at fault and should be replaced. If the printer still prints slowly then put the black cartridge back in and remove the color cartridge, then print a page. Replacing the cartridge that causes the slow printing with a fresh cartridge will resolve the issue.
Assuming the cartridges are original HP (not re-manufactured or refilled) you can check the warranty status by CLICKING HERE
Let me know how you make out.
Ben
May 03, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Very slow printing - HP 5610 all in one
Very simple solution: The cartridges still have ink in them but printing is very slow. Remove the cartridges from the printer. Take a wet paper towel and wipe the print head on each one until the ink flows from each head. Usually it is the color cartridge because it is used less than the black one. Once ink is flowing again, reinsert the cartridges into the printer and your normal printing speed will return. This worked for me, no thanks to the "experts" or trouble shooting guides.
Oct 20, 2009 | HP Officejet 5610 All-In-One InkJet...
My HP 5610 is printing extremely slow.
Very simple solution: The cartridges still have ink in them but printing is very slow. Remove the cartridges from the printer. Take a wet paper towel and wipe the print head on each one until the ink flows from each head. Usually it is the color cartridge because it is used less than the black one. Once ink is flowing again, reinsert the cartridges into the printer and your normal printing speed will return. This worked for me, no thanks to the "experts" or trouble shooting guides..
Oct 05, 2009 | HP Officejet 5610 All-In-One InkJet...
MY HP Photosmart 2613 All-in-One Printing has gone very slow in
It is not a big problem
u r able to solve it
before printing check pending status of printer
means some times pending print are create a big problem to after prints so first check it
and
one more thing
check u r printer settings
Jul 22, 2009 | HP PSC 2410 All-In-One InkJet Printer
HP 1315 printing real slow
If there are a compatiable black cartridge
replace this cartridge with your old empty cartridge and print a test page (don't mind about printing of black )
If speed is correct,
then replace the black cartridge with another new cartridge.
(some time compatiable black cartridge not work properly to flow ink)
Jun 04, 2009 | HP PSC 1315 All-In-One InkJet Printer
Hp psc 1350 colour printing problems
Sir,
Check this link to solve the problem
link 1
Link 2
Thanks Good Luck
Appreciate to rate as "Fixya"
Apr 28, 2009 | HP PSC 1350v All-In-One InkJet Printer
HP OfficeJet 6110 Prints very slow then aborts about 1/3rd way through print
I identified this issue with my Officejet 6110xi All-in-One as firmware corruption. Attempting to install the supplied firmware update gave the error that "no hp device connected to the computer would benefit from it at this time." Attempted to power down the printer using #9 keystroke and got "FULL RESET" message, but problem of extremely slow printing and erratic behavior of the print heads persisted. I solved the problem by putting the printer outside in cold weather for two (2) days. This frequently resets firmwares with software corruption back to their embedded EEPROM state. Hooked the printer back up and worked fine. If cold weather is not available you could try other creative methods of cooling the device, just use a plastic bag and with ideally some drying packets thrown in to prevent excessive moisture buildup in the cold environment. The colder it is the faster the firmware resets.
-Paul Ronco, Computer Technician
www.paulronco.com
Oct 29, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP PSC 1350 All-In-One Thermal Printer Logo
125 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
