Question about Jenn-Air JCB2059G Bottom Freezer Refrigerator
It's dead. no cold. fridge and freezer. fan is blowing. Made weird noises for the last 2 months. Compressor?
    President:
  • 1,218 Answers
Good day,
If the fan in the freezer as well as the condenser fan underneath by the compressor are running, and there is no frost building up on the rear panel in the freezer compartment, then yes, it sounds as if the compressor failed.
If the compressor won't run, it is possible the compressor relay or overload protector failed, but if it was making noise, it is likely the compressor is the faulty component.
If the machine is under 5 years of age, hen the factory will service it. If not, then you will need the services of a professional to check it out.
Posted on Sep 13, 2010
Condenser fan noise
you should have warranty from the tech at least one month ,but it sounds like motor fan is giving up umplug your fridge take off back bottm part to expose the fan and condenser clean all the lint in the condenser vaccum is better ,turn fan with your finger it should be very loose ant turn freely if it stucks its the motor ,umplug the motor pull the fan with the plastic base out of its place,take off the screw on the fan,pull and twist it by hand,take off two or three screws that is holding the motor to de base, buy a newone ,a the apliances store or online for about 45.00 put back everything in reverse way.plug your fridge, enjoy!!! good luck
Apr 07, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
Samsung rs2630sh not cooling or freezing
If it has fan to deliver cold air, and it is not working, cold air is stuck on the begining. So your fan could be dead. And I suppose, that compressor is running all the time. Even compressor could stert freezing if fan does not deliver cold air in fridge. The other option is, that there is not enough gas in the compressor. In this case compressor vould not be freezing, but line, going out of compressor has to be hot, if it is not, there is no gas.
Dec 02, 2017 | Samsung RS2630WW Side by Side Refrigerator
Fridge working off/on
If the noise was coming from the compressor when it was cutting off or starting, it was the internal mounts of the compressor and the compressor will have to be replaced. If the noise was a fan, it may have stopped. One is in the freezer behind the rear cover and one is underneath where the compressor is behind the cardboard cover.
Dec 31, 2009 | Whirlpool ED2FHSS Side by Side...
Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Nov 10, 2009 | Amana Freezers
Brand new refrigerator not working
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp and that the fan in the freezer is running when the compressor runs.
Sep 08, 2009 | Refrigerators
Freezer works, fridge part does not
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 21, 2009 | Refrigerators
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Fridge is not cold and freezer is not cold
f the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Jan 10, 2009 | Maytag MSD2454G Side by Side Refrigerator
Fridge/ Freezer not cold
My fridge started making a weird noise not too long ago. Now the fridge isn't cold and everything in the freezer is melting. The read out still says that everything is the right temp, but the melted ice tells me otherwise. Recently my daughter found out how to operate the buttons and has been pushing them a lot, but we change them quickly.
I would have the refrigerator / freezer checked out by a serv tech mainly because if it is a compressor, this would not be something that can be done by as customer, but it could be something internal like a fan or a fan motor that blows the cold air or a bad thermostat or sending unit – the weird noise is something internal that really should be check out by a serv tech before you lose everything as far as food, etc. – the refrigerator is a sealed unit and is hard for a customer to service unless they have serviced the unit before.
Apr 08, 2008 | Samsung RB2155SH Bottom Freezer...
Both Fridge and Freezer not blowing cold air.
with the thermostat turned to its coldest setting can you hear or feel the compressor running?  Can you find the defrost timer inside the refrigerator and turn it until the compressor stops, and then please let me know, JT
Oct 24, 2007 | Amana AFD2535DES French Door Refrigerator
Jenn-Air JCB2059G Bottom Freezer Refrigerator Logo
142 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
