Question about Kenmore 74889 / 74882 / 74884 Top Freezer Refrigerator
I have a Kenmore household refridgerator/top freezer and it does not wok. The inside light comes on but other then that, nothing else happens. I switch the freezer setting to "OFF" and then turn it to the max setting and still nothing happens. I o the same with the refrig. settings and the same thing happens. I have a model # 363.9759613 and it's serial # is L536 42420.
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 13, 2010
Freezer not freezing, fridge not refridgerating
do you hear any clicking from the compressor if so it could be a relay or compressor fault cheers
Dec 12, 2013 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore Refridgerator/Freezer does not work.
check your damper vent door located between the fridge and freezer and make sure its opening up to let cold air into the fridge,also check the evaporator fan motor and make sure its operating to blow the air around the inside of the unit
May 23, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore refrigerator with bottom freezer. freezer works,refrig does not. Can you help me find the problem .Also, bar between the upper doors gets real hot.
I had this problem. The Evaporator fan in the freezer was working but no air would be circulated from the freezer into the refridgerator. To test this you open the door of the freezer, and depress the door button(s) of the upper refridgerator doors so that the light extinqueshes in the refridgerator. This will engage the evaporator fan in the freezer. You can check to see if air is venting from the freezer into the refridgerator by feeling the holes at the top most part of the multi-air flow channel in the refridgerator. If air is comming out when the freezer door is open, close the freezer door and feel if air has stopped. If you have kept the upper door buttons pushed in on the refridgerator and now have the freezer door closed, you should still hear the fan running, but may have not air flow with the freezer door closed. The cause of this is the air return channel from the refridgerator to the freezer is either frozen or clogged. My return-air channel was not frozen but clogged by a residue from something that spilled inside of the bottom of the refridgerator. The return-air channel has two vents in the rear-bottom of the refridgerator that exit into the freezer behind the evaporator (cooling coils). You can't see it even if the back interior panel is removed from the freezer compartment.
The bottom line here is that if air is prevented from moving from the refridgerator, back down to the freezer, then your refridgerator will not cool, but your freezer will work just fine. You will not need to replace the fan, unless the fan is not functioning. You may need to check the dampener, to ensure that your multi-air flow channel is open - (allowing air to come into the refridgerator). The multi-air flow channel is easy to remove once all of the shelves are removed from your refridgerator. Only 2 screws holding it in (securing the center rack top and bottom). The top screw is located behind a small plastic cover that can be removed.
That's what worked for me.
Jan 12, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Freezer works but refridgerator does not . light works and coil fan woks
Since you did not mention the manufacturer breand, or if it is a top freezer/ bottom food section, or if it's a sxs- I can only give you some general diagnosis:
Top freezer model and sxs
1. Are your controls in the proper setting?
1. Check to see if there is any "snow formation" on the evaporator cover. If yes, then you most likely have a defrost issue
2. Is defrost drain clogged ( top freezer model). If defrost drain is clogged then water can "spew" over into air diffuser and cause an airflow issue
3. Make surer you are getting air flow into the food section i.e. the fan in the freezer blows the freezer air into the food section. You might havve an air difuuser that is not opening
Affordable Appliance Repair
(949) 855-0788
Jun 20, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ice under freezer floor, water in fridge (drain clogged)
in the freezer remove the cover plate where the fan is an insert a pipe cleaner into the drainage tube opening.
Apr 28, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Refridgerator and freezer wont get cold
sounds like a bad compressor, or at least the start device plugging in to the compressor has gone bad,
Mar 15, 2009 | Frigidaire FRT21H8 Top Freezer...
Water dispenser is slow
There is no pump in this refridgerator to provide cold water. Water arrives via pressure from the household cold water line that has to be provided to the rear of your fridge. Two possible solutions:
1. The filter in the upper right of the refrigeration (not the freezer) is clogged by normal minerals, etc. It should be changed at least every year, unless you have major sediment in your household water lines.
2.) The amount of water being delivered to the rear of the refigeratior is being restricted somehow. Trace from the connection on the back of the fridge to see where the water line (either thin plastic line or a small, flexible copper pipe) travels to a cold water line in the house. Look for kinks in the pipe and also look for any shutoff valves that are turned almost closed.
Mar 13, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
clogger drain,find it inside frig,freezer or on back on **** out with shop vac
Sep 03, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Freezer is not freezing and refridgerator is not cold enough
have the freon checked for leaks, also check to make sure the compressor is coming on. If it comes on and is warm, boost freon. If the unit is not coming on properly, check the capasitors and compressor
Jul 24, 2008 | Kenmore 64802 Top Freezer Refrigerator
Kenmore refridgerator 78285892 Freezer light won't work
probably a bad socket. 10-12 years old metal would not likely to last inside a freezer box.corrosion could have eaten the metals...
Feb 11, 2008 | Refrigerators
Kenmore 74889 / 74882 / 74884 Top Freezer Refrigerator Logo
99 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
