Question about Tools & Hardware - Others
Hi, I purchased the 4486 Quick Change Chuck for my 10.8V cordless dremel & found that the chuck jaws didn't close & that it fitted so tightly to the tool that I had great difficulty removing it. I'll admit that I probably didn't read the instructions fully, so I probaly did something wrong. Should I have left a collet on the tool before fitting the chuck, or should the chuck screw on just as easily as does the standard collet does. Thanks for any assistance, ****
  • 3 Answers
SOURCE: I cannot get the chuck to tighten the collet
sounds like u are using the wrong collet in the end of dremel the normally have a couple of different collets try changing it for a tighter one also make sure its in the right way
Posted on May 31, 2009
  • 15 Answers
SOURCE: Screw in chuck is unknown size
this can be a problem if you have been using reversible drill bits in chuck as they tend to drill out screw head when drill bit jams if this has happened you may have to drill screw and use an easy out remember it will probable be a left hand thread
Posted on Sep 06, 2009
  • 141 Answers
SOURCE: Chuck jaws on Makita 8444D fell out
There is suppose to be a flat head Left hand thread chuck screw in there. It may have fallen out. You will not be able to put the jaws back into the chuck. You will have to replace the chuck with a new one. If you make sure that the chuck screw is not there you can remove the chuck with a couple of steps. Make sure the drill is in it's lowest gear. Use a strap wrench or some large vise grips on the chuck. If there is still one jaw in the chuck make sure it is all the way open and locking the collar to the chuck. The chuck will come off in the regular lefty loosey configuration. It may be stubborn. If this is the case, You may have to cut the collar off the chuck and use a pipe wrench. Or bring it to a professional to get it changed out.
Posted on Sep 23, 2009
SOURCE: how do i remove the chuck from dewalt dc925
The dc925 and the current model dcd950 along with several other models of Dewalt 's line of cordless hammer drills DO NOT have a screw inside removal requires a CHUCK REMOVAL FIXTURE part #
233804-40 also you can't use a generic replacement chuck. As of 2/2/2010 the prices on the Dewaltservicenet web site are $72.74 for
the tool and $69.70 for the chuck, part # 330075-90.
Posted on Feb 02, 2010
  • 843 Answers
SOURCE: router bits
Mike, The fit is just a little more snug than you expect. The collet is springy, and will expand to fit your bits, even if they were oversize (which is very unlikely). Put on a leather glove and just push the shank of the bit into the collet. Do not try to file down the shank of your router bits, you will only make them run eccentric. You don't need to remove the collet. Just loosen the locking nut about a half turn after it is easy to turn. Good luck. Thanks for using FixYa. Al Kupchella
Posted on Apr 21, 2010
I am trying to remove keyless chuck from Hitachi cordless drill DS 18DVB. I am insertiung flat head screw driver into chuck, turning clockwisw but getting no bite
the screw at the base of the fully opened chuck is a left hand thread
it may be a slot but normally they are philips head or hex head undo that screw by turning as if doing it up
once it is out , hold the shaft and by placing something across the now partially open jaws a quick hit on that object with a hammer will loosen the chuck off the shaft you can place a allen key in the jaws and close them up and use that as an object to hit
Dec 15, 2015 | Hitachi Drills
How do i attach the drill bit to my dremel 300
You can use a drill that fits directly ( one size) or you can use a small chuck made for the Dremel. example:
Oct 21, 2014 | Tools & Hardware - Others
I have a new chuck for the drill need to know how to take it off and put the new one in
Thank you for using FixYa. To change the chuck on your cordless drill, open the old chuck jaws to the maximum. Inside the chuck where it attatches to the drill body, there is a Philips headed bolt. Unscrew the bolt in a CLOCKWISE direction. Reverse this procedure to fit the new chuck.
Hope this helps
Mar 04, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
I've just bought my b&d cordless 14v hammer drill but the instructions were just a few pictures. one of them was of an allum key in the chuck and hammer striking it but i dont want to damage the drill....
Hi. Try the drill at slow speed without any drill bit in the chuck. Look closely to see if the chuck wobbles off centre whilst holding the drill firmly. If it does then there is a good chance that the chuck is loose from the body. If it seems ok then next close the chuck (tighten it closed) to see if all the 3 jaws are lining up ok and open it again to see if the jaws retract back down the chuck smoothly. (jaws are the small parts inside the chuck that grip the drill bit) If the chuck it seems loose then you can use a long allan key to tighten it up which is inside the chuck. If the jaws do not operate properly then i would suggest taking the drill back to b&q for them to fix, or replace the tool as it should still be under warranty. Good luck
Jan 22, 2011 | Black & Decker Drills
Chuch jammed wont move
try with force to move it
if you can not move use a clamp
Jan 03, 2011 | Rotary 4486 Dremel Chuck Quick Change...
The blade assembly on my dremel will not come off. Is there a trick to this?The coupling seems to stuck.
Try some W-D40 and gentle hits on the coupling to liberate the chuck 3 pin holders.If you got this type of chuck:
r00130v1.jpg > Enlarge Image
4486 Dremel Chuck
The Dremel Chuck holds Dremel accessories without using a collet eliminating having to use the wrench and creating quick and e
Nov 08, 2010 | Dremel 395 Variable Speed Multipro Rotary...
How do I attach the drill bit to the chuck on a ss 120 drill
Well I couldn't find a pix of your drill so I will guess that it is a typical drill. You seem to be asking a very basic question so I will start will all the basic info I can think of.
First you have to know where the power trigger is to make it go.
2nd you have to know where the forward and reverse switch is.
Now with the switch in the forward position squeeze the trigger to make it go. Then gently grab the chuck with your hand while it is going and the center Jaws should close up and come out of the chuck.
Now with the switch in the reverse position squeeze the trigger to make it go. Then gently grab the chuck with your hand while it is going and the cetner Jaws should open up and go into the chuck to a maximum point
Open the jaws enough to put the drill in the jaws then put the switch in the forward position. Put the drill in the chuck, sqeeze the trigger to make it go, and hold the chuck so the jaws close on the drill. All while keeping the drill from falling out of the chuck.
When it closes on the drill and the drill is in straight then hold the chuck as tight as you can while squeezing the trigger to make the jaws close very tightly on the drill. If you have very tender hands you might want to use gloves.
To get the drill out put the switch in reverse, hold the chuck very tightly, and squeeze the trigger to open the jaws off of the drill.
Nov 28, 2009 | Black & Decker Drills
There is a little metal plate that is sticking out at the back of the chuck and opening and closing of the chuck has become very hard. I cannot find a schematic for this drill. I took the screw chuck off...
Place tool lightly in vice, place any allen wrench , L shaped type , with long end out of chuck, small end in chuck. clamp chuck jaws tight around end of wrench. With pipe or hammer, tap end of wrench counter clock wise.
These chucks are tight.
Jul 08, 2009 | Panasonic 15.6v Ni-mh Cordless Drill -...
How do you change a chuck on a DW995. I took the center screwn left handed screw out. How do you back the old chuck out? how do you remove the chuck there is no allen key in the center of the chuck
position the drill to speed one & drill mode.u need a allen key then clamp it the chuck jaw close & tight. hit the allen key with hammer counter clockwise until its loosen. may have to do it any several times.
Aug 11, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Keyless chuck problem
I had the locking screw come loose in the center and bottom of the chuck it has a left hand thread and is a torx head . It had backed out and prevented the chuck from closing.
Mar 14, 2008 | Dewalt 18 Volt Compact Drill Kit
Tools & Hardware - Others Logo
94 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
