Question about Zebra TLP 3842 Thermal Label Printer
Printing quality TLP3842
I am using a TLP3842 in direct thermal printing for barcode labels.
The printout quality deterriorated, to mthe lve that the pritaout i wsed out, clea adareadble.
  • 300 Answers
Clean the printhead, if no better replace it
Posted on May 17, 2008
Printer not Printing barcode label properly
best guess would be a thermal printhead has an element out and needs adjustment. However with out a model number and a picture of the printout that is the best I can do.
Aug 24, 2015 | Office Equipment & Supplies
Zebra ZM400 drops interface on port 515
make sure you have no network traffic for your printer and decrease the printing speed, and make sure you are using a free port not a used and default port for the service..
Jul 20, 2014 | Zebra ZM400 Thermal Label Printer -...
Zebra eltron LP 2824 printing too light
This could simply be old direct thermal labels. Direct thermal labels have a shelf life of about 1 year from the date of manufacture. After that time has lapsed the thermal coating on the labels begins to dissipate and this will cause labels to print light or faded. You can trouble shoot with a roll known to be fresh. You can get one free here to test Labeldomain com .
If this does not solve your problem then please check this article on 5 common print quality issues and how to correct them Fix Zebra 2824 2844 3842 print quality
Jan 28, 2014 | Zebra Eltron LP 2824 Thermal Printer
We're using 4.00 X 2.00 inch labels. The barcode is printing just under an inch long when it should be about 2 inches long so our scanners cannot read the barcodes. The text is printing out the
in some barcode software you can see the preview. if you click on the barcode itself maybe you can stretch it out to fit better. or try swapping to 2 by 4 format and see if that works. good luck
Aug 12, 2017 | Zebra ZM400 Thermal Label Printer -...
The barcode cannot be printed on the direct label
Your description is not very specific but no printing can be the result of:
1. The darkness is not set high enough
2. The ribbon is loaded backwards
3. You are trying to do direct thermal printing (no ribbon) but the label stock is not direct thermal stock.
Maybe you can provide more details.
Hope this helps,
Jul 18, 2010 | Zebra Stripe S600 Thermal Label Printer
The printer is not feeding the label until the perferated line. it only feeds about an inch and then stops and then feeds another inch. on our other zebra once the feed button is pushed the printer feeds...
Simple yeah. Printer calibration is the problem.
see this video , http://vodpod.com/watch/3948392-how-to-calibrate-zebra-tlp-2844-printer
For over 4 years, Trridev Labels has provided Barcoding solutions and Barcoding equipment to a wide range of large and small companies in virtually every industry sector. Trridev Labels offers more than 10,000 brand name products and services such as Barcode Labels, Barcode Printers, Barcode Scanners, Thermal Transfer Ribbons (Wax, Wax Resin, Resin), ID Card Printers.
Contact Trridev Labelss Mfg Co – If you have requirement of Barcode Labels, Barcode Printers , Barcode Scanners, Self Adhesive Labels, Thermal Transfer Ribbons, Printer Heads, RFID Solutions, Barcoding Solutions. We provide you a complete solutions for barcode.
Call us at +91 – 96000 07995 / 98840 42305 To Get the Best Price Tagged with Best Quality.
Jul 02, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Ladder orientation barcode printing bad resolution needs correcting
Try slowing down the speed of the printer. Faster speeds degrade the quality of your print. Try printing your serial (ladder) barcodes at 2-4 inches per sec. It should improve the quality of your format.
Apr 13, 2009 | Zebra Z6M Plus Thermal Barcode Label...
Speed of printing barcodes
Generally the ZM 400 can cope with printing at the lower speeds when printing barcoedes that are the same. You may get pauses if the barcodes are sequential numbers or are all different, then the data to be transfered to the printer cannot cannot keep up with the printer and pauses while it gets more data. We have found that if you can select in your labelling software to print the barcode as a graphic, then it speed up quite a lot. It is a matter of matching your print speed and quality to match your expectations, sometimes you will just have to put up with the pauses.
Feb 02, 2009 | Zebra Stripe S600 Thermal Label Printer
Tlp3842 printing every third label, need to change size
If you are using windows go to Start, Printers and Faxes. Right click on your printer and select Printer Preferences. Under the Advanced tab there should be an area where you can change the dimensions. You'll want to change the Width and Height to match the dimensions of the label that you are using. These are usually in inches or inches/100. Ex: 1 inch = 100 in/100.
Dec 17, 2008 | Zebra S4M Thermal Label Printer
Poor Quality Print on Zebra 105SL direct thermal
How many labels has the printer printed? Because it sounds to me like you just need to replace the print head.
They are around $400 from whomever your supplier is, and very easy to replace.
Nov 12, 2008 | Zebra 105SL Thermal Label Printer
Zebra TLP 3842 Thermal Label Printer Logo
386 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
