Question about GE Microwave Ovens
GE Spacemaker Microwave JVM1630BB007 door handle broken. I can get the choke cover off. But I can still not get to the two screws behind the inner door; one at the top and the other at the bottom of the handle. The door approximately midway along the top appears to have a metal clamp keeping it in place while the bottom seems to come out from under several plastic clips. I have searched and searched and cannot find any similar descriptions with solutions. The blow up diagrams that I have seen are not detailed enough and this model's door looks a little different that the pictures and videos I have seen on the internet. Any help is greatly appreciated! John
I have the exact same problem. How did you get teh choke cover off. Can you get a replacement handle?
Posted on Nov 30, 2010
  • jcw9788 Dec 03, 2010
    ... very carefully. To get the choke cover off, you need to gently pry around the sides with a butter knife. Work your way around a little bit at a time
  • tbear99 Dec 03, 2010
    Thanks. Found the handle and waiting for it to arrive before I start the repair. Any word on how to get to the screws
Mmi have a ge advantiun x20 model SCA1001FSS01 THE HNDLE IS BROKEN OFF HOW DO i REPLACE THIS pafife@yahoo.com
HELLO.
THE SOLUTION ON HOW TO REPLACE THE BROKEN HANDLE
THINGS NEEDED.
Phillips screwdriver.
Thin, flat-head screwdriver.
Putty knife.
Replacement microwave door handle.
1 Examine the inside of the door. The handles of some early GE Spacemaker microwave models were attached after the two inner door panels were assembled to the outer door. If you see two recessed screws opposite the handle attaching points, undo them with a Phillips screwdriver and remove the handle. If not, go to the next step.
2 Insert the blade of a thin, flat-head screwdriver into the top, outer corner of the door, between the plastic inner frame and the outer door. Gently pry the inner frame out and slip a putty knife into the exposed opening on top of the door. Slide the putty knife toward the hinges to free the top of the inner frame; repeat on the front and bottom edges of the door and lift the inner frame out to expose a second metal inner frame.
3 Insert a thin, flat-head screwdriver into each of the small square openings on the top and bottom of the inner metal frame, starting at the handle end of the door. Undo the attaching clips by gently levering the inner door away, using the rim of the outer door as a fulcrum. Move the inner door away from the outer door on its hinges.
4 Remove the glass from the outer door. Undo the two screws holding the handle to the outer door with a Phillips screwdriver. Screw the replacement handle onto the door and tighten securely.
5 Replace the glass panel and reassemble the door by snapping the two inner frames back in place.
Thanks.
Aug 30, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The plastic door handle on our GE Spacemaker XL microwave oven (JVM1341WW 002) broke. I ordered and now have replacement handle and screws onhand. How do I gain access to inside of the door to replace...
I do not know your unit specifically but a lot of them you have to start by, slowly, from the inside of the door, lifting up on the choke that runs along the outer inside edge of the door. It looks like a plastic trim part about 3/4 of an inch wide. You slowly work around the whole door unit you get it popped out. a butter knife or steak knife works pretty well . I just use a small flat head screw driver The screws for the handle are behind that choke seal. Usually 2 Phillips head screws. The choke part just snaps in place and has no screws to put it back, just push back in place and you will hear it snap as you go. Be careful the plastic tabs are easy to break off
Aug 19, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
How do I repair the broken handle on my Spacemaker microwave from GE?
you have to remove the trim inside the door. you have to carefully pry the inner trim and kind of twist it as you remove it so you don't break it.
if there is enough of the handle left where the screw goes in(I'm assuming that's where it broke) sometimes you can drill into it a little and put a longer screw on. otherwise you need to buy a new handle.
May 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave model JVM130J - handle loose
Yes, you're right about the screws. The inner door is held by clips. Just pop it out using a butter knife or something similar. You might need to remove the door from hinges first (It's been too long after I repaired one of these, so I don't remember exactly).
Oct 14, 2009 | Microwave Ovens
Door handle broken away from microwave unit.
The door handle can easily be replaced. This is a common problem with microwave oven doors. You would think the manufacturer's would make them a bit more durable.
This is a very simple repair. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions about this repair, please let me know. I hope this helps you.
Jul 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Can i replace a broken door handle?
Yes. This is a very simple repair. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
Jul 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My door handle is broken. Is it posssible to
You should be able to buy only the door handle and avoid having to replace the entire door. Appliancepartspros.com carries the handle. Just type in the model number you provided and look for item #3 under the parts listing. The part number and price varies based on the color you need. Make sure you order the correct color. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
If you have questions, please let me know. I hope you find this information helpful.
Jul 06, 2009 | GE JVM1640 Microwave Oven
Need to dissemble microwave oven door GE model JVM 1631 BB 002 to remove spider.
Remove the inner strip around the door called the choke. If there are no screws visable it just snaps in place and does break if you are not very careful. This will give you access to the screws holding the outer frame piece and handle on. keep in mind, any repairs done to the door will necessitate a RFe leakage inspection. Boil some water on the front burners and cook the little guy and leave the door alone.
Eric
Jun 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
May 28, 2008 | GE JVM1190SY/WY/AY/BY Microwave Oven
Replacing handle on microwave
Strupes,  looks like the handle is going to screw in from the inside.  You will have to remove the choke cover.  The choke cover is on the inside of the door, about 1 to 1.5 inches wide that goes around the glass.  It will snap out using a small flat blade screw driver.  Once off you will see where the screws go to hold the handle on.   Catriver
Oct 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
218 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
