Question about Pioneer DEH-P4700MP CD Player
How do i turn on sub mode?
I have installed an amp and sub in my car. I know i did it right, my friends have checked it over also. I turn on my radio and crank it an nothing happens with the sub. They said i probably need to turn on the sub option on the head unit. I look on the head unit display and i see an unlit up option that says "sub" so i know its there i just dont know how to turn it on. Please help!!!
  • Derek9298 May 15, 2008
    Also where do i put the remote wire(blue wire) i dont know where to put it in the back of my head unit. I thought it was supposed to be spliced with the blue wire with the white stripe but the amp dosent turn on ever.
  • golfpro12 Mar 13, 2009
    I am Having the same problem... However, the amp does get power, the sub just is not working, there is an unlit Sub light on the display, anyone know how to get this to work?
Ok, I was having the same promblem... I just got off the phone with Pioneer, they said that the rear RCAs are always on, there is no sub "option" to turn on or off, the display in this unit is also used in other units that have that feature, so something else is wrong...
Posted on Mar 13, 2009
For one thing I hope you know you need an amp to even power subs at all.. The remote wire coming off the rca wiring that you hook your subs up with has to go on the prong 3-in on the top here is a rough diagram: the = signs are power and ground and the prongs are thicker the comma is you remote..
You need a wire coming out of that slot on the wiring harness.. it should be blue. and unless you have a power antenna(comes out when you turn your radio on) then you dont need the blue/blue&white power ant. wire you can just cut it and cap it. if your amp isn't coming on when you turn your ignition to acc then your remote wire isn't properly attached..
Posted on Sep 20, 2008
Protect Light On Amp Being Weird
Could try switching right and left subs. If the problem moves to the other side pull the wiring and redo.
Then if the wiring is ok check the sub.
May 15, 2013 | Jensen JPA600D - 600 Watts Digital Mono...
I have a power acoustik ibm12000d amp had it installed to weeks ago wired at one ohm to a 15inch acoustik p3 sub worked good for to weeks hit good and everything but now its cutting off when turned up I...
Sounds like an over current condition. Your sub may be the problem. Does it go into protect mode when it cuts out? remove the sub and turn up the volume and see if it cuts out when you keep increasing the volume. If not, then it may be that the sub shorts out when turned up too much, kicking the amp into protect mode. If it still cuts out, then it may be the amp. Try another sub if you have one or borrow one from a friend.
Aug 06, 2011 | Power Acoustik OVN1-2000D 1-Channel Car...
I just installed my 10 inch square pyle sub and its hooked up to the dub amplifier..the amplifier is in safe mode and the subs woint hit..what do i do to fix this?
ok if the amp was in safe mode before the sub was hooked up then the amp needs to be fix , make shor the suds are hooked up right an the wires arent touching , the amp is in pro mode so there for u have to find out more on why the amp is not working or let me know what is goin on with it ,
Jul 19, 2011 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
I have phase linear uv8, need to know how to get subs 2 work! Amp goes into protect mode when rca's r plugged in, there r 3 sets of preamp out puts 1 front left and front right, 2nd is rear left rear...
try testing the amp without speakers plugged in. Run the sub preamp out to the amp that you will drive the subs with, but don't wire up the subs yet. Test for protect mode kicking in.
Yes - unplug the rca ins from the amp. retest.
No - Problem lies within the sub wiring. What is the load on the amp (measure with an ohm meter)? If it is below 4ohms, chances are the amp can't dip that low. Give it more resistance by wiring it differently (series vs. parallel)
Bruce
May 05, 2011 | Kicker Car Audio & Video
I have an Alpine CDE-100 and when I hooked up my subs and amp I would only get subs with radio and regular speakers for my ipod via usb and the cd player? I had a friend that use to install sound systems...
While I don't know the specifics of this head unit, I would guess that it has settings that can be adjusted for each source. You might check to see if there's a menu that allows you to turn the subs on/off for the various program sources.
Nov 08, 2010 | Car Audio & Video
My red light on my 1000w amp wont turn on to power my subs. the blue one is the one one to turn on can anyone help me
make sure that you have a good ground, make sure you have the right amp turn on wire, and your power wire is fused, best solution is to have it professionally installed! Amp install is very basic if you are having a hard time with that, I wouldn't attempt to try it or have one of your buddies install it! FRIENDS DONT LET FRIENDS INSTALL!
Sep 11, 2010 | Kenwood KAC-7203 Car Amp
I hooked up my two 10 inch JL Audio W3v2 2 ohms to a mono JL Audio 500.1 amp and the subs will not work. I have the subs wired in a series. I then hooked them up to my friends amp and the subs worked. Any...
try one at a time. if they work then try hooking them up differently. if none work, then check to see that your amp is not in protect mode. if amp is ok, then check to make sure you have your rcas connected to your amp. in other words, re-check all your wiring. if still nothing, try your amp on your friends car and vise versa.
Apr 01, 2010 | Jl Audio 10W3v2 Car Subwoofer
I have a jl 1000/1 amp hooke up to 2 12 w6 subs and when i turn the volume up half way the speakers cut out and amp stops working but i turn the volume back down and it works fine. what could this be?...
what is happening is the amp is going into protect mode because it most likely is at the wrong oms and is getting over loaded and shutting itself down to protect it self!
do you know what ohm load you are presenting to the amp? or what ohm are the subs ?
if you correct the ohm load it will fix your issue and make the system sound way better! let me know if you have any more question and let me know about the ohms! good luck
Oct 02, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Memphis PR300.2 Amp protect light on
If it is not turning on your problem is it is not getting power. Check your fuses. The reason an amp goes into protect mode is usually because the subs are not wired up right. Make sure your fuses are good, you have a good ground, and make sure your amp turn on wire didn't come loose when you were putting the deck back in. As for the amp going into protect you probably wired the subs down to too few ohms and the amp you have can't handle it. Try hooking the subs up straight w/o bridgeing them and turn it up to see if it works. If you don't have problems with it then you wired your subs wrong.
Mar 22, 2009 | Car Audio & Video
P3001 amp may be fried
Check this out: http://www.techlore.com/article/14696/
Aug 06, 2006 | Rockford Fosgate P3001 Car Audio Amplifier
Pioneer DEH-P4700MP CD Player Logo
218 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
