What is a common problem associated with desktop computers?
  • 5,660 Answers
Number 1.
Power Supply failure.
TOP problem.
Also a Power Supply failing, can emulate issues that seem software related.
Doubt that your computer professor will know this, however.
(Can also be a bad Power On switch. The diagnosis should include testing both the Power On switch, and the Power Supply, by bypassing the Power On switch.
This is done with a jumper wire on the Soft Power On wire, {PS_ON. Green in color}, to ANY Ground wire, (Black in color), in the ATX {20 or 24-pin} main power cable connector.
Example of 24-pin ATX main power cable, and it's respective connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Bypassing the Power On switch turns the Power Supply on?
Problem is a bad Power On switch.
Bypassing the Power On switch does Not turn the Power Supply on?
Problem is a bad Power Supply)
Number 2 most rated problem, is the computer is dirty inside, as well as the inside of the Power Supply.
Most users are seemingly not aware, that the inside of a computer should be cleaned on a regular basis as needed.
Many may be timid in cleaning the inside of their computer.
Computer unplugged from power, Anti-Static Precautions observed, a can or two of compressed air for computers, could easily eliminate this problem.
Heatsink for the Processor is coated with 'Gunk'?
The Processor overheats, and BIOS turns the Processor off.
Same thing with the fan used to cool the Processor.
Whether it is a fan mounted directly on top of the Heatsink, or a computer case fan pushing air through a plastic shroud to the Heatsink.
Power Supply, (SMPS), cooling components.
This is the internal fan mounted at the back of the Power Supply's case, and the Heatsink's used inside the Power Supply.
[Basic construction of a Heatsink, is a plate of metal with tall, thin fins protruding from it.
The plate of metal absorbs heat from whatever object it is placed against, (Via a thin layer of thermal paste), and the fins absorb the heat from the plate.
The fins then radiate the heat away.
If a fan is used in conjunction with a Heatsink, the flow of air from the fan helps to dissipate heat away from the fins.
(Such examples would be a Processor's heatsink, and the heatsink's used in a Power Supply)
Posted on Sep 13, 2010
No notices show up on home page frozen
What site do you normally have on your browser as a start page? I use Paul & Associates Computer Services, Google & MSN as a start page. You just need to check your IE options by clicking Tools and then Internet Options. The first thing that you should see the site designation. If not just click and put for example http://www.paulcomputerservices.com/ or http://www.msn.com/ as your start pages. Then you can navigate from their to other sites that you commonly use day-to-day.
Apr 23, 2014 | Computers & Internet
Dell computer makes a beeping sound when turned on and screen is black
Hi daisy jean,
The beeping sounds you hear are error code beeps which are associated with problem devices installed in your computer. The most common problem component is the RAM memory which slots into the motherboard inside your computer. It is often caused by static on the RAM chips and simply removing the RAM and spraying it with an anti-static electronic aerosol spray will often solve the problem.
The second most common cause for beeps when turning on your PC is
due to a faulty display card. If your PC has an on-board display card(this is the card where you plug your screen in), you will have to buy an add-on PCI-E display card to replace the faulty on-board display card.
Let me know if you need any clarification.
Best wishes,
Graemevm
Jan 23, 2012 | Dell Computers & Internet
During starting i get one beep every 2 sec.
Hello axel,
Before addressing the beep code, please unhook any devices you have plugged into the computer, such as printer, scanner, camera. Then try starting it.
According to hp that beep code is associated with a cd/dvd burner issue. Open up the computer, and pull the power cord out of it. While you have the case open, clean out any dust that is inside, overheating may be causing the issue. Place cover back on, and try starting it.
Next step is to reseat the hardware inside your computer, this involves removing components such as memory, video card(if present), and any additional hardware you may have.
Next remove extra hardware, If it is non-essential try starting your computer without it being installed.
including a link to common beep codes to use as a reference, They will change depending on the hardware you remove, such as memory, video, and the processor.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph07107#N196
Aug 18, 2011 | HP Pavilion a810n (PP164AA) PC Desktop
I have 8 programs that won't work and say "they do not have a program association with it for performing this action". They say to "create an association in the folder options control panel".
Windows uses "associations" as part of its object-oriented interface.
For example, after installing Adobe Reader, there will be an "association" created, such that everytime that you double-click on a 'PDF' file, then Windows will launch Adobe Reader.
Similarly, '.doc' files will be associated with Microsoft Word,
and '.xls' files will be associated with Microsoft Excel.
That's the correct way to "add" or "delete" a specific association.
It's strange that you don't have an association already defined;
it could be the result of a computer-virus, namely, one that has deleted that association.
Aug 31, 2010 | Computers & Internet
Set association to open a PPS slide show from Email
Right click on that pps file:
1. Open withh
2. Chose default program
3. Browse and hose Power Point
4. And check box with (Always use selected program to open this kind of file
Jul 10, 2010 | Dell Studio One 19 Desktop Computer (Intel...
I get a better connection speed on the wireless pc then the pc connected directly to the router. Why is this.
There could be several reasons why this is, but the most common one is that the computers adapter can only handle a speed that is less than the wireless adapter card, so it would seem that the wireless connection is faster, but I need to confirm this. What is your computers manufacturer and model, and what is your laptops manufacturer and model? Or it could be that the laptops clock speed is faster than the desktops, making it seem that the hard wire is slow, when in fact it may just be the computer.
Ryan Frame
Creative Energy Associates Technical Center
Nov 09, 2009 | NetGear DG834G Router
No boot device
A boot device is typically the main hard drive which contains your operating system.
There are a couple of reasons you'll get this message:
  1. You or somebody else modified the BIOS and disabled the bootable hard drive. To fix this, turn the computer on and watch for a prompt that includes the words BIOS or SETUP. It should have a key associated with it (F2 and Delete are two common options). Look for the boot up section and make sure that your primary hard drive is on the list (usually 1st or 2nd in the boot sequence.).
  2. Your hard drive is damaged or the boot sector is damaged and the BIOS can't find the boot information. In this case, I would take the computer to a local professional. Your hard drive may not be recoverable.
Oct 14, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Hi, whenever I turn on my wireless reception , a MS Dos-like, blue screen pops up and my computer reboots. The error centre said it is a wireless adaptor problem. Please help.
The blue screen of death is caused by a problem associated with the drivers for the wireless adapter. It is commonly called a "STOP ERROR"
download and run everest home from this site
click on Network, click on windows network. this will ID the wireless card you are using. google the card for updated drivers.(or e-mail me at mewms_14904@verizon.net
Aug 22, 2008 | Computers & Internet
Find and download a network adapter driver
well this is the link for you to download drivers for your compaq desktop
http://welcome.hp.com/country/us/en/support.html?pageDisplay=drivers
just type your compaq desktop model no ...for eg.compaq presario v 6000..you need to know your model no in order to download drivers for your desktop pc...
for windows xp if you want networking between your computers attach your computers with cross cable and right click on my computer for system properites > there you will see computer name tab > there you will see network id button > click on it and run the installation on all the computers you want to be in network....
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
t
Thanks
dilipbagdi
Technical Associate
Sep 14, 2007 | HP 290563-B21 Network Adapter
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
