I have a 97 intrepid and it shuts off and itgets to normal tenp what could it be changed the coil pack and it still does the same thing
  • 27,725 Answers
Faulty PSU or a faulty lead
Posted on Sep 13, 2010
I have a 2002 dodge intrepid cranks but no spark.changed cam shaft sensor and crank sensor., all new plugs but still no spark....please help ..thanks
Hi Leroy, Im glad to help!
Here's a couple things you can try. First, swap the ASD Relay with one of the same type relays in the relay box. If it still doesn't start check every fuse. If it still doesn't start check power and ground at the "COIL PACK" If power and ground are good Replace the Coils Pack. If there is no power and ground at the coil pack then make certain you are getting power from the ignition switch to the ASD Relay. Hope this helps and have an awesome day Leroy.
Oct 02, 2014 | 2002 Dodge Intrepid
I changed the belts on my 97 intrepid 3/3 ltr a couple weeks ago and it stated running rough and misfiring. Changed the plugs, wires and coil pack and it is now misfiring and stalling?
changing belts will not cause this problem.when changing the plugs did you check the plug gap or just assume the plugs were gapped properly.this could be one problem.did you change the wires one at a time or did you pull off multiple wires and change them,this could be another problem(wires not in proper location).you could have an intake gasket that is bad causing a vacume leak,which can cause miss fire.it could be a fuel injector problem(either electrical or fuel).is the check engine light on,this is a starting place have the code pulled.these i would check out.
Apr 19, 2011 | 1997 Dodge Intrepid
Misfiring
have u tryed to replace the camshaft sensor i had the same problem with my 97 intrepid today and itworks like a dream now.
Jul 28, 2010 | 1997 Dodge Intrepid
Need a diagram of the firing order for 97 intrepid 3.5l
Looking from the front of the car. the passenger side is cyl 1, 3, 5, and the drivers side is 2, 4, 6. The coil pack front row is, 6,4,2. and the rear row is 3,1,5 The firing order is 123456
Dec 18, 2009 | 1997 Dodge Intrepid
Changing spark plugs 2004 dodge intrepid
First off, on this model you don't have plug wires, you have coil packs with a boot and coil connected to the pack. The boot slides on the tops of the spark plug. The good thing about this is that you don't have to mark each wire to its location.
So to replace the plugs you need to disconnect the electrical connector to the coil pack and then unbolt the two bolts that mount the pack down, then remove the pack.
Next with a ratchet, an extension and a special spark plug socket, which has an insulator inside to protect the porcelain from getting cracked, remove the spark plugs.
Next step is to replace the plug, usually I slide off the boot from the coil pack and then remove the coil from inside the boot and slide the boot over the spark plug and start to thread the plug back in. Using this method allows to you feel if you are threading the plug in right. Then with a torque wrench you would torque the spark plug to the specs for the type of engine you have.
3.2/3.5L Engine (20 ft-lbs)
2.7L Engine (13 ft-lbs)
Next reinstall the coil pack with the two mounting bolts, it is only necessary to hand tigthen the two bolts. Then plug back in the electrical connector and continue this process on the next 5 spark plugs.
Apr 14, 2009 | 2004 Dodge Intrepid
1994 dodge intrepid has no spark unless temp is above 40 degrees
Check the connector at the coil pack/module. Four wire connector that supplies the coil pack with power and signal from crankshaft sensor.
Jan 12, 2009 | 1994 Dodge Intrepid
Spark plug change in a 1998 dodge intrepid
if you don t see any spark plug wires then your motor has coil packs(black colored boxwith 2 small electrical wires) located on top of motor 3 on one side,3 on the other.disconnect negative terminal on battery,then disconnect wire connector at each coil pack and remove 2 screws that hold down coil pack, pull gently straight up and plug is right there below coil pack
Jul 03, 2008 | 1998 Dodge Intrepid
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
