Question about ViewSonic VA1912WB 19" WideScreen Monitor
Hi, I have a ViewSonic VA1912wb monitor. Yesterday, the screen on my monitor went blank and it never came back again. I checked the power cable and the graphic cable, everything seems fine but still I don't have any picture. I even tested it on a different computer and it was the same. The green light in constantly on and when you stare at the monitor you can see the icons on your desktop and even movement of your cursor, but the screen is very very dark. I would really appreciate it if anyone can help, Sean
  • 11,361 Answers
It can be the power supply DC caps for the backlight inverter circuits or the inverter circuits have failed, you will have to open it up.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 13, 2010
Hi, I have a ViewSonic VA1912wb monitor. Yesterday, the screen on my monitor went blank and it never came back again. I checked the power cable and the graphic cable, everything seems fine but still I...
Sean, I can't believe you havn't been to YOUTUBE to see video clips of "lcd monitor repair" and "lcd monitor disassembly"!!!! You must have very good "eyesight"!!! You have just performed the "flashlight test" without the aid of a flashlight!!! See the icons=SMPS in partial shutdown mode!!! No see icons=SMPS in full shutdown!!! Ask us tech's more questions here on fixya only after you do web research at fixya and have seen videos at YOUTUBE. Do reply after you find out what WE already know! You might even be able to refurbish unit for less than $8 in new capacitors on the SMPS board. 12fixlouie
Sep 13, 2010 | Computers & Internet
I am getting vertical bars moving up on my screen
vertical bars in video can be caused of poor filtering of voltage on the power supply,you need to open the back of the tv to repair the power supply.replace all bulging capacitor this causes the problem.Tnx
hope this help.
please rate my help.
Jun 05, 2010 | ViewSonic VA1912wb 19" LCD Monitor
Monitor fails during boot
the problem is due to hi-esolution, boot in SAFE MODE uninstall / reinstall the video drivers
Feb 07, 2010 | ViewSonic VA1912WB 19" WideScreen Monitor
Blank Screen
Common problem in monitors are bad caps in the power supply, that is the first place to check, look for bad caps with bulging top/bottom, see example of failed VIEWSONIC monitors due to bad caps here (worst case will be bad lamps): http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can help you further.
Feb 06, 2010 | ViewSonic VG2230WM LCD Monitor
Viewsonic VG2230wm 22 Blank screen
Look for bad caps in the power supply first, see example of failed VIEWSONIC monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you furhter.
Feb 06, 2010 | Relisys RLT1720 17" LCD Monitor
The screen is black even though the green light is on
try with another cable, pc if nothing. need to get service.
May 30, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Put an adaptor on my cable and the monitor screen goes blank
Hi Kathy,
Nothing you can do, it could be the laptop does not understand Digital Video Interface DVI
What is the laptop make / model?
Mar 13, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Viewsonic va1912wb monitor goes blank for few seconds and comes back and this happens very often
Your power/inverter board needs to be overhauled.
Your capacitors on the board are probably burned out.
If you open it up and send me a picture , I may be able to tell you if they are or aren't.
There is also a chance a transistor has gone bad on the board.
I repair many viewsonic boards on ebay
bammbammfran
Oct 21, 2008 | ViewSonic VA1912wb Monitor
Viewsonic VA1912WB error says analog signal
I had a Gateway 19" TFT that did the same thing.
Does the power light stay on? If so, you more than likely have "dry" solder joints at the inverters. Take it apart & shoot a little solder on the inverter solder joints. Good as new now. The solder joints dry out because of the high heat generated. This is a very common problem.
Apr 22, 2008 | ViewSonic VA1912wb Monitor
Computers & Internet Logo
263 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
