Question about HP Officejet 5610 All-In-One InkJet Printer
Hello I have a HP Office Jet 5610 all in one printer, when i tried to print it didnt allow me to, and on the printer screen it says "ink cartridges errors" Im just wondering what might be the problem and how to fix it? Thanks
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Hi
you need to replace one or both of your cartridges with new ones
if you have the old you can check , what cartridge couse the error and you can refill the old one like this
If i help you pls vote
Posted on Oct 30, 2010
Testimonial: "thanks for the help"
  • 1 more comment
  • night_archer Nov 01, 2010
    i replaced it with new ink, but it still says "ink cartridge error" when i tried to print
  • nikos pappas Nov 01, 2010
    hi
    if you have change borh cartridges and you still getting the
    error message you propably vabe bad contact between cartridges and
    cartridge carier so try the follow steps
    1 open cartridge door
    2 take out both cartridges
    3 disconect printer from wall socket
    4 get a paper towel and wet it
    5 cleane the cartridge carrier with the wet towel
    6 reinstall cartridges
    7 conect printers cable in the wall socket
    I hope this fix it
  • night_archer Nov 06, 2010
    hey , i tried another replacement of new ink, and this time it works!
    i guess there was something wrong with the other ink, but anyways, thanks alot
Hp office jet 5610 wont print colors correctly
Some printer software that detect ink levels won't recognize a cartridge that's been refilled. They treat the cartridge as empty although you've filled them with ink. You can try removing the HP software that pertains to the printing functions only (not the scanner abilities). You can also do a Power reset. Remove the printer cartridges, turn off the power, remove both the Power cord and USB cord (if applicable) for 10 minutes. After reconnecting the USB and power cords, install the cartridges as you normally would. The printer should treat them as new.
Oct 22, 2011 | HP Officejet 5610 All-In-One InkJet...
My printer is printing blank pages.
Either:
* empty ink cartridges
* clogged ink-jets, such that no ink can be sprayed onto the paper
Use the HP software to check the ink-levels in the cartridges.
Run a few "print-head-cleaning" cycles. If still no output, then replace the ink-cartridge(s).
Feb 22, 2011 | HP J4680 Office Jet All-In-One Printer
My HP Office jet 5610v will not print from any program--the printer que will not release two documents even after a delete command
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 25, 2009 | HP Officejet 5610 All-In-One InkJet...
In the middle of a print job, my cartridge refill stops feeding ink. Printer MN J4680. Does this printer hold the cartridge # in memory in order to stop one from refilling?
HP printers do not remember the cartridge serial number to reject refills (certain Canon printers do though). It sounds like you have an air bubble in the sponge that is inhibiting ink from reaching the print head. I would guess that either you or the store/internet seller that refilled this cartridge hand filled it. These cartridges should be filled under a vacuum to remove air bubbles from the sponge and allow you to fully fill the cartridge (an air bubble takes up space that your ink could be occupying). I recommend Cartridge World or Office Depot for refills. Avoid internet sellers and refill shops that have one giant all-in-one machine that does the filling for them.
Oct 09, 2009 | HP J4680 Office Jet All-In-One Printer
I have installed a new color print cartridge and my printer comes back with cartridge error. I have unplugged the printer, opened and closed the door, turned the printer off and then on and taken the...
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9o11
Jun 22, 2009 | HP Officejet 5610 All-In-One InkJet...
My ink cartridge is stuck in my hp office jet 5610 all in one
I just had this problem too. Tricky little things, they are. I took a pair of pliers to the ink cartridge and was able to pull it out. I couldn't get it by holding the sides of it with the pliers, I did top and bottom. Also, it took a few tries but I bet you can get yours out too.
Mar 21, 2009 | HP Officejet 5610 All-In-One InkJet...
HP office jet 4215 all-in-one printer. Getting a cartridge error
Are you sure you installed the ink cartridges correctly? They should snap in and then you should be able to do a Printer Test/Align cartridges function.
Which error message is it putting out?
Mar 12, 2009 | HP Officejet 5610 All-In-One InkJet...
Instation of HP office JET 5610 all-in-one ink
Hi Niko1,
Here is HP's website address that will give you the steps that you are looking for...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00442122&lc=en&dlc=en&cc=us&lang=en&product=441125
Hope that helps,
Take care,
Michael
Nov 11, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
345 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
