Question about Acer Aspire 5315 Notebook
The computer will not turn on. It's plugged in and everything. When you turn it on the start-up lights turn on but nothing appears on the screen. The hard drive does spin though, but then stops and the computer stops booting.
    President:
  • 2,291 Answers
Check for ur pc os, u have to reinstall the windows, after installing the windows , install registry cleaner reg in out to make the windows dafe from crashing
Posted on Sep 14, 2010
Will not turn on
I would remove the power adapter, battery, RAM and hard drive. Press the power button for a few seconds to discharge everything. Plug the adapter back in and press power. If the laptop throws a wobbly and messages appear on the screen, power it off and add the RAM, do it again and the add the hard drive. If it does nothing when all is removed, the motherboard has a fault, otherwise the issue will be apparent as items are added.
Sometimes removing and replacing the RAM and hard drive will fix this problem.
Dec 24, 2013 | HP Compaq nc6230 Notebook
My monitor doesn't go on anymore. Las night I had a pop-up appearing on the screen. I closed my computer and started over again. I'm sure I didn't turn off my monitor. Everything went well until this...
First, check to make sure the power cable is plugged properly in the back of the monitor and into the surge protector. You can try a different power outlet, but if you're still having the same problem and the light isn't turning on, it's likely you've either blown the fuse inside the monitor, or you had a power surge and blown something inside the monitor. This happens when you don't use a surge protector and just plug the monitor into the wall.
That said, if the above doesn't work then you have a hardware problem with your monitor and it needs to be serviced.
Jan 11, 2011 | Computers & Internet
No picture screen black
un plug the monitor cables power cord everything turn off the computer the reconnect everything power back up turn on the monitor should work then
Feb 06, 2010 | Dell E173FP 17" LCD Monitor
PC boots for seconds then NOTHING APPEARS SCREEN
Check to see if you have inadvertently hit the CRT button which turns off your screen to turn on an externally connected screen even if there is no external screen plugged in. OR you could have a bad (Back-light) or (Inverter)
Jan 27, 2010 | LG Flatron L1750S 17" LCD Monitor
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Nintendo DS lite; changed touch screen and it won't start
Hi. this issue is normaly caused by bad screen (normaly top screen) or bad assembly in one of two screens, re insert carefully the flex cable again, if your screens are fine this must fix the issue
Mar 14, 2009 | Nintendo DS Lite
Dell 1702FP 17" shows nothing after Radeon HD 2600 put in.
Is the card plugged into the (PCI/AGP) slot correctly? Did you disable the onboard video in the bios? Also be sure to check in windows device manager and check for the graphics card to appear there.
Dec 24, 2008 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Black Screen
listen the answer is this. screen resolution set to a incorrect setting or video driver installed is not compatible with the hardware in the lappy. what you do is this when you reboot the lappy press the F8 key until it give alist of options boot to safe mode uninstall video driver by going to device manager or reset display resolution in the display setting try the latter first then reboot.
Apr 08, 2008 | Compaq Evo N610C Notebook
Acer Aspire 5315 Notebook Logo
65 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
