Question about Imation (23780) 320 GB USB 20 Hard Drive
My Imation Apollo 320GB external hard disk became very slow and would connect only as USB1 device when I plug it in. Transfer rate would be 1MB/s at max. When I boot up the computer with it connected, it would be detected as USB2 so it would perform normally and fast. It has become a hassle because I have to reboot the computer whenever I want to access something from the hd. Lately, it has become slow even if I boot it up with it connected. I had to boot up a couple of time before it becomes useable and fast.
  • melvin_ramis Sep 13, 2010
    I have formatted, defragged, scan disk... still behaves the same way. No errors/bad sectors seen during disk scans...
  • 3 Answers
It may be time to format it. CAUTION: formatting a drive will delete everything on there. I suggest to side on the side of caution
Posted on Sep 13, 2010
Imation Apollo M100
https://www.imation.com/en/consumer/external-hard-drives/ External Hard Drives
Jan 29, 2014 | Imation Apollo UX 2.5" USB Portable (250...
3tb external imation expert d300 not working with windows xp
Windows XP does not have support for any disk-drive larger than 2TB. So, your 3TB disk-drive will not work. Upgrade your computer, or buy a 2TB disk-drive.
Jan 09, 2013 | Imation Apollo Expert D300 External Hard...
Imation apollo hard drive stop working
See the Imation Support web site where you can find information related to your Imation Apollo hard drive.
If the drive is no longer being found in My Computer, have you tried it on a different computer and / or using a different USB cable - if it still isn't shown after trying these tests, then there is the possibility that the drive has failed or the internal logic board (which translates the drive connection (from IDE or SATA) to USB) has failed.
If the drive internal logic board has failed, then provided you can remove the disk drive from the Imation casing, you should be able to re-house it in a new portable drive casing. If the drive has failed, then it would probably be easiest to purchase a new external drive given current drive prices.
Jan 14, 2012 | Computers & Internet
I bought an Imation Apollo II (320GB) and had it formatted for my macbook in the store I bought it. It has worked fine up until 2 days ago. Now, when plugged in, it says only 'the disk you inserted was...
Hello barry_carrot,
I work for Imation and we would advise you to try the following option:
restart to your Macbook without the external drive attached.
Open your Disk Utility (in your Applications/Utilites folder).
Plug in your hard drive.
If the drive shows up in the list in the Disk Utility First Aid window, click on the drive, and then click on Repair Disk. If the process repairs anything, run the same Repair Disk a second time to see that it runs with no problems found. If some other error comes up, or it won't repair a problem found, then I would recommend moving this drive to a PC, and trying a repair tool through Windows.
Note: if you see the "repair" option grayed out, Going back to Disk Utility - (you won't be able to select Verify/Repair Disk Permissions), but Verify or Repair Disk should be available if you click on the device (the entry showing the manufacturer's info for your external drive).
If that doesn't help you, please contact the Imation product support department at the phone number 1-800-351-8186 option 2.
Jul 20, 2011 | Computers & Internet
My "imation apollo 25-PHDD
You need data reovery help. This guy does it remotely and works from donations. FreeDataRecovery.us
Jul 13, 2011 | Imation Apollo (27223) 250 GB USB Hard...
Hi.My Imation Apollo 2.5" 500GB
With any luck, it may just be due to a loose cable or connection inside. You need to open the unit and make sure everything is properly connected.
Mar 14, 2011 | Imation Apollo UX 2.5" USB Portable (250...
Hi, I had problem using Imation 27390 apollo expert ux. The hardisk is in NTFS format, and work perfectly fine when i plug in computer with Windows Vista and 7. But it cannot be recognized by computer...
Windows XP has limitations on recognising too large NTFS disks. One of the solutions would be to format the entire disk as FAT32 or make a partition and format that as FAT32.
Feb 28, 2011 | Imation 27390 Apollo Expert UX 2.5" 320GB...
I am using Transcend 320 GB external hard disk in a Windows 7 Operating system. It is keep on asking me to format the disk while i plugging in to laptop. Unable to see the contents in the external hard...
guess you are using a USB port to for that.....
1 - check the cable that connects the HD to the USB port...change the cable and verify
2 - connect to another PC and check if it's ok there
3 - bring another ext HD from a friend and try conencting that....check if that's OK
4 - there could be a corruption in the HD that is preventing the PC from reading it
cardinal rule for USB....not a very dependent device specialy if connecting thru USB data cables....
solution
always use a good qty USB data cable compatible with USB2....as some cheap cables are only for USB1
visit my website
www.sureshayyar.110mb.com
for more info on PC issue and solutions...
reg
Kris
Feb 17, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
Apollo 250GB installation on mac
Did you format the hard drive to make it compatible with Mac?
Jan 15, 2009 | Imation (01946) External Floppy Drive
Imation (23780) 320 GB USB 20 Hard Drive Logo
640 people viewed this question
Top Imation Computers & Internet Experts
Raj Patel
carey w mason
carey w mason
Jax Planet
Jax Planet
Are you an Imation Computer and Internet Expert? Answer questions, earn points and help others
