Question about Hoover F5826-900 SteamVac Upright Wet Washer
Will not turn on
Unit was working fine, changed water and went to turn back on and it will not start back up
  • tanyapatters Aug 09, 2008
    I have the same steam vac and the same problem. It started making a loud noise and had a burning smell so I turned it off and now it won't turn back on. It sounds like it must be the motor to me.
    President:
  • 1,673 Answers
I assume you tried a different outlet? Otherwise you could have a problem with the cord, switch or motor. You will just have to check it over to find out what went bad.
Posted on May 15, 2008
We used it then turned it off and went to turn it back on but wouldnt do anything.latches are locked and has water in it. im getting power to the switch
E series vacuums have a safety switch underneath the motor unit to insure the water basin is on. You can see the part here and where it is located (left of the separator)
Rainbow interlock plunger
Sometimes this part may have fallen out and gotten lost when you were putting your vacuum away, or your water basin where it would depress this switch broke of.
If your motor is good and power nozzle is good, it may be this.
GoodVac.com
800-775-6586
Mar 24, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Unit not working to heat water--cant hear compressor starting up like normal
Did you make sure that it was closed all the way? Sometimes if the water canister is not on all the way it can cause this. And depending on how old the steemer is maybe that part went out. But I would check all the lines to make sure nothing is clogged or pinched
Jun 07, 2012 | Vapor Professionals TR6 Canister Steam...
Vacuum working perfectly and everything stopped. Went to the utility room and found a plastic bag on top of the equipment. Tried the reset button, etc. nothing works.
sounds like a bad relay in the tank just a simple repair but should be done by a vacuum tech or electrician. Could be a motor is nothing is starting at all, but not as likely.
Jun 14, 2009 | Broan-NuTone CV353 Central Vacuum
Hoover SteamVac Dual V Carpet Cleaner just hums when I turn it on
if the motor doesn't run sounds like you either have a bad motor or your motor armature might have gotten wet and created a dead spot.if you have any contact cleaner spray a little on the armature then turn the motor by hand make sure its uuplugged first if you can turn the motor then plug it in and try to start it
Apr 04, 2009 | Vacuums
My Electrolux upright worked fine
Are you using the proper bag? There's a kill/reset switch that needs to be pushed down by the rim of the bag before the unit will run.
Jun 22, 2008 | Electrolux Epic 6500 Vacuum
Handle unit came off
http://geeksquad.fixya.com/ThreadView.aspx?prdid=49977&thid=623558
Posted by Mcnarymoss on May 26, 2008
Hi. My unit was working fine. Then my wife started using it. She was going back and forth using the Power Drive feature. Now, the entire handle slips off, and the unit is not working correctly at all. Any ideas
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Bissell 1698 Power Steamer ProHeat Upright has a – let’s call it a power drive rod that has come apart and is no longer working and needs to be re-connected. The best results of the power steamer is that the power steamer works better on the pull back, which means that you dispense the water, the brushes scrub the carpet and the vacuum picks up the water and it goes into the recovery tank – if you go forward use the trigger assm to dispense the water so I t get a chance to soak in but the best results are on the pull back. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
May 26, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Sprays soap, but not water
My Bissell is quite fussy. Sometimes I have to wiggle and push down the tank before the water will start to flow. The water doesn't flow properly if the soap container is low - I fill it with water when rinsing. It has a viewport with a red cross that turns when the water flows. Sometimes just removing that and the white filter below (and putting them back) makes it go. Mine is easy to take apart - 6 screws in the base unit and the top comes off. There are two water tubes going into the handle hinge under where the water tank goes - very easily squished or damaged. Last time the water stopped flowing, I ran it with the cover off and just fiddled around with the tubes and away it went. Maybe it is spraying soap only. The water flows up through the handle to the finger valve and heater. Some people say the heater in the upright/handle gets plugged. I haven't had that apart, but it should be easy to bypass the heater.
Sep 07, 2007 | Bissell 1699 ProHeat Clear View Upright...
Battery light goes red after bumping/backing up
try this: turn it upside down and run it-then bump it to reverse it...same result?
May 29, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
Hoover F5826-900 SteamVac Upright Wet Washer Logo
54 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
