How do i use the dryer of a philco gemini washer and dryer?
Where can i get electronic spare Parts for Philco GUD808e washing machine
Best I suggest is contact manufacture for dealer near you
Apr 29, 2014 | Washing Machines
Philco dryer
Check the motor.
Jan 15, 2014 | Bosch Washing Machines
Philco washer doorlock
The door switch or latch could be jammed and you might have to try and check for the end of the washing cycle to get door latch released.
check this link: Door lock
Oct 03, 2013 | Washing Machines
Philco WD 1896 Ecotronic Electronic Washer/Dryer Machine: any ideas on why the drum has stopped turning, the machine still fills and empties with water. Perhaps a blown use? I do overload it often! Any...
sounds like carbon brushes in the motor they can be replaced as they just pop out of the motor. carbon brushes are very resonably priced so worth while to do.
Mar 29, 2010 | Washing Machines
I need a code number and programming instructions for a Gemini Easy 3 Remote. The TV brand is Philco. Any suggestions? Thanks!
have bell + howell tv 19 inches, made in 1994, can't get the volume on cablt tv remote to work with tv...help!
Dec 28, 2009 | Gemini Televison & Video
PARTS FOR WASHING MACHINE
Try this link and enter your model number. You may be able to find the part you seek there. Sure hope so and best wishes.
http://www.spares2go.co.uk/browse-PHILCO-m290.htm
Aug 25, 2009 | Washing Machines
Need a replacement needle for a Philco turntable that has a Diamond needle? The model # is a 1962 Philco Stereophonic High Fidelity model # K-1636X-121
Check lpgear.com for Philco stylus replacement. You may need to find the "Contact Us" tab and request information for your particular model, but if they can't help you, then contact Philco (division of Ford Motor Co.)
Jun 28, 2009 | Audio Players & Recorders
How do you level this dryer (model# FEQ1442C)
hi,
it may level like an old philco refrigerator, two big screws in the front? try turning them to see if that works
J
Jul 11, 2008 | Frigidaire Dryers
Gemini universal tv remote
I lost a few manuals myself. Gemini Universal Remote Control Programming Codes ------------------------------------------------ 1.Locate the 3-digit brand code from tables below. 2.Press and HOLD the RCL and ENT keys simultaneosly, until the red indicator turns on (3-4 sec) 3.Select the type of device you are programming by pressing the TV, VCR, CTV or AUX key. 4.Enter the 3-digit brand code number. If a valid code was entered, the indicator light will go off. 5.Test your Gemini remote,by pressing PWR key. Repeat 2-5 with new code number if not responding. Autosearch Instructions: If your remote has an auto search on it. 1. Turn ON the device you wish to program the Gemini to operate. 2. Press and HOLD the RCL and ENT keys simultaneosly, until the red indicator light turns ON. 3. Select the type of device you are programming by pressing one of the TV, VCR, CTV or AUX mode keys. Now enter one of the following device type search codes: TV-990, VCR-992, Cable-994. 4. Aim the Gemini at the device and press the red PWR key. If your device turns OFF, press the appropriate device mode key again,(TV,VCR,CTV or AUX),to lock in brand code for that particular device and exit from the programming mode. 5. If the device doesn't respond, press the VOL"+" key once to advance to the next brand code. Now press the PWR key again. Remember to immediately lock in your code when the component turns OFF by pressing the proper mode key. Continue repeating steps 4&5 until your device turns OFF. I hope this helps you out, Good Luck to you. TV Codes ADMIRAL 400,530 MITSUBISHI 020,160,180,190,230,240,580 AKAI 160,240,550 MTC 140,180,300,310 AMARK 390,590 NATIONAL 010,270,420,510,570,610 AMSTRAD 110 NEC 180,190,240,300,310,580,620 ANAM 170 PANASONIC 010,270,420,510,570 ANAM NATIONAL 420 PHILCO 080,120,130,180,270,240,270 AOC 180,240,300 300,390,450,490,540,590 BELL&HOWELL 530 PHILIPS 080,120,130,180,270,300,450 CANDLE 060,080,300,310 490,540,560,590 CENTURION 190,580 PORTLAND 390,590 CITIZEN 060,080,140,300,310,390 PROTON 240,390 CONCERTO 310 QUASAR 010,420 CONTEC 170,260,470 RADIO SHACK 070,170,190,390,410 CORANDO 390 RCA 090,180,240,400,500,600 CORONADO 590 REALISTIC 070,150,170,190,390,410 CRAIG 170 SAMPO 190,300,580 CURTIS MATHES 030,140,190,300,390,470 SAMSUNG 140,180,190,300,310,390,410 590,650 580,590 CXC 170 SANYO 200,430,460 DAEWOO 180,340,380,390 SCOTT 020,190,390,580 DAYTRON 190,390,580 SEARS 020,140,190,200,210,390,430 ELECTROHOME 160,390 440,460,590 EMERSON 020,110,150,170,240,280 SHARP 000,050,070,390,590 330,390,470,590,650 SONY 350,550,640 ENVISION 300 SOUNDESIGN 080,240 FISHER 200,460 SSS 170,180 FUNAI 020,170 SYLVANIA 080,120,130,190,270,300,360 GE 010,040,290,400,420,630 450,490,580,630 GOLDSTAR 180,190,240,310,390,590 TATUNG 420 HITACHI 100,260,310,320,390,590 TECHWOOD 310 INFINITY 270 TEKNIKA 020,060,080,140,160,170,180 JBL 270 270,310,390,480,530 JVC 030,250,370 TELERENT 390,530 JC PENNEY 040,180,190,240,290,300 THOMSON 400 390,400,440,500,630 TMK 240,310 KLOSS 490 TOSHIBA 140,200,210,220,440 KMC 390,590 TOTEVISION 390 KTV 170,240,390,590 UNIVERSAL 040,290 LLOYTRON 390 VIDTECH 180 LODGENET 530 WARDS 020,040,070,120,130,180,190 LOGIK 530 240,270,290,300,390 LOGIX 530 YAMAHA 180 LUXMAN 310 YORX 190,580 LXI 000,190,210 ZENITH 520 MAGNAVOX 080,120,130,190,270,300 390,450,490,580,590,630 MAJESTIC 530 MARANTZ 160,240,300,450,490 MEMOREX 530 MGA 020,160,180,190,230,240,300,580 VCR Codes AKAI 002,052,112,202,372,402 MULTITECH 072 AMSTRAD 072 NATIONAL 272 ASA 022 NEC 202,252,292,302 AUDIO DYNAMICS 202,292 NORDMENDE 202 AWAI 392 PANASONIC 272 BROKSONIC 282 PENTAX 332 CANDLE 022 PHILCO 272 CANON 272 PHILIPS 272 CITIZEN 022 PIONEER 252 CRAIG 092,182 PORTLAND 232 CURTIS MATHES 272 QUASAR 272 DAEWOO 062,232,342 RADIO SHACK 022,072,092,142,152,182,272,312 DAYTRON 232 RCA 032,182,272,422,452,492 DBX 202,292 REALISTIC 022,072,092,142,152,182,272,312 DUAL 202 SABA 202 DYNATECH 072,142 SAISHO 242 ELECTROHOME 022 SALORA 212 EMERSON 042,072,082,102,112,132 SAMSUNG 172,182,342,412 192,242,282,472,482 SANSUI 202,252 FERGUSON 202 SANYO 092,312,382 FINLUX 072 SCHAUB 202 FISHER 092,322,332 SCOTT 132,212,242,342,432 FUNAI 072 SEARS 022,032,092,162,312,322,332 GE 182,272,422 SHARP 142,222 GOLDSTAR 022,292 SONY 122,252,352,362 GRAETZ 202 SYLVANIA 212,272,452 HARMON KARDON 292 SYMPHONIC 072 HITACHI 032,072,202 TASHICO 022 INSTANT REPLAY 272 TATUNG 202 ITT 202 TEAC 072,292 JCL 272 TEKNIKA 022,072,272,502 JENSEN 202 TELEFUNKEN 202 JVC 012,202,252 THOMSON 202 JC PENNEY 022,032,272,292,302 THORN 202 KENWOOD 202,252,312 TMK 042 LLOYD 072 TOSHIBA 162,202,212,342 MAGNAVOX 272,452 TOTEVISION 022,182 MARANTZ 272,292,452 UNITECH 182 MARTA 022 VECTOR RES. 212,292,302 MEI 272 VIDEO CONC. 302 MEMOREX 022,072,272 VIDEOSONIC 182 MGA 022,192,212 WARDS 022,072,142,182,222,272 MINOLTA 032 YAMAHA 202,292 MITSUBISHI 022,192,212,442 ZENITH 122,252,432 MTC 072,182 CTV (Cable TV) Converters Anvision 104 Realistic 504 Cablestar 104 Regal 444 Diamond 444 Regency 164 Drake 144,284 Rembrandt 474 Gemini 244,274,474,534 Samsung 094,374,474 General I. 004,034,044,204 Scientific Atlanta 074,524 GI/Jerrold 004,014,024,034,044,204,234,244,354 Sprucer 494 GI/Starcom 394 Standard Component 474 Hamlin 424,434,444 Starcom 014 Hitachi 414 Stargate 484 Kate Vision 474 Sylvania 114 Macom 184,304,324 Tocom 194 Magnavox 054,104,124,344 Toshiba 184,264 NSC 474 Tri-Vision 124,234,354,364,384 Oak 294 Unika 154 Panasonic 334,494 United Cable 014 Paragon 454 United Satellite 224 Philips 054,104,124,134,174,214,254 Videoway 314 Pioneer 064,084,094 Viewstar 054,104,124,134,174 Pulsar 484 Zenith 144,184,404,464,514 Randtek 104
Jul 01, 2007 | Gemini 1 Device Universal Television...
Washing Machines Logo
150 people viewed this question
Top Washing Machines Experts
