Question about Whirlpool LER4634J Electric Dryer
My dryer still heats up but the drum wont turn? It sounds like its running. I think it might be the belt
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Apr 02, 2011
Creda 37761 problems drum will not turn heating up
OH OH SOUNDS LIKE BAD WINDINGS ON THE MOTOR, HAD THIS PROBLEM LAST WEEK , THE MOTOR WAS SHOT AND WOULD NOT TURN THE DRUM, I TESTED IT WITH MULTIMETER AND MANUALLY, BY OPEING UP AND TAKING BODY OFF THE DRYER, remove the drum and belt, JUMPING THE DOOR SWTICH, AND THEN STARTING THE DRYER, BINGO It the motor STARTED RUNNING, but when I put body, drum and belt back on BINGO no running or turning.
Sep 14, 2014 | Dryers
Hi my hotpoint dryer wont turn please help
You have the belt on wrong. There is a side with numbers or writing on it and ribbed side like treads. The tread side should be facing down, making contact with the drum. If the other side is touching the drum then whenever clothes are put in the belt will slip causing the drum not to turn.
Apr 25, 2012 | Washing Machines
Dryer is doing everything but drum spinning... counter thinks its going... have not let it go long enough to see what heating is doing but drum is not moving.....?
sounds like the belt:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
routing of belt:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Good Luck Tim
May 10, 2011 | Whirlpool LER5636P Electric Dryer
My dryer drum wont turn but i do have heat ,the motor is running and the belt is not broken...help!
i would check the belt idler arm under the drum,maybe it jumped off-mike
Feb 17, 2010 | Kenmore 63942 Dryer
Maytag dryer wont spin It makes heat,but the dryer wont spin
Sounds like the drum belt is broken or off the pulley of the motor
Sep 25, 2009 | Maytag Dryers
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Dryer heats up but drum doesn't turn.
If the drum is very stiff to turn could be the drum bearings shot which would account for the broken belt, replace belt and it liable to break shortly after again. hover are known for there bad bearings and they cost a small fortune.
check it out have a look and see if there is nothing jaming the drum inside, i am certain your belt has gone and maybe down to the stiff drum making belt break, replace belt but bare in mind it may break again if the drum is too stiff.
choice is yours really. bearing kits cost more than 50 quid in general
Jul 10, 2009 | Hoover Dryers
KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
Jan 21, 2009 | Kenmore 63942 Dryer
Whirlpool gas dryer motor wont turn over
If the drum is not turning, then the belt may have broken and could be (because of the noise I think your describing, partially wrapped around the motor pulley.
Modern gas dryers do not have standing pilot lights. They are electronic ignition.
Chances are, you solve the belt problem, you'll solve the (I guess your having) heat problem.
Please respond with more detail of the problems you are having, and advise if the belt is broken.
Jan 18, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool LER4634J Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
