Question about Canon PowerShot S2 IS Digital Camera
Display screen upside down
I have a problem with the sensor that changes the direction of the picture in the flip out screen. It is the right way around if the screen is flipped out and around (ie lying flat but screen facing me), but if I just pull the screen out to the side, the image does not automatically rotate.
Is there a quick fix to this or is it a repair job?
Cheers.
It's broken wires to a switch inside the rotating mechanism. If you take the screws off of the screen and the rotating mechanism and remove the grey plastic covers you'll see a black switch inside a white plastic mounting that is anchored around the bundle of black wires going to the screen.
You'll be able to see the metal tab that rotates down to activate the switch when you swivel the screen (do this carefully with the covers off so you don't wreck the screen by asserting too much stress on it).
If you know someone that can solder tiny stuff, take it to them. It doesn't matter which wire goes to which terminal on the switch. You should see two broken wires in the black bundle - those are the ones that need to get reconnected to the switch. I used transformer wire to fix mine, as the insulation on transformer wire is painted on (and will need to be removed from the ends with a small file) instead of having plastic/rubber insulation that can melt when soldering.
Once the wires are reconnected, insulate them using liquid electrical tape, then put the wires gently back into the bundle, and make sure that the stress points don't land right on your solder connections. After that you should be good to go.
It's not a job for someone who hasn't soldered before... better left to someone with steady hands and the necessary equipment.
Hope that helps!
Posted on May 27, 2008
All the writing is backwards on screen of model LC-15B4U-S, how do you reverse it?
On the remote,
1 Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
It rotates through several options -- normal, mirror (where you are), rotate, upside down. When you get the picture looking right, stop and the screen will disappear in 3 seconds. See Page 28 of your manual for another option, using the Menu screen.
It I
May 02, 2017 | Televison & Video
How do I fix display show upside down. TCL LED TV Model: L24T2100
http://www.tomsguide.com/answers/id-1989729/picture-flipped-upside-fix.html
Feb 20, 2015 | Televison & Video
Screen upside down
Go to the "Start menu", click "control panel", then click "hardware and sound", click "display", then click "change display settings", then click the down arrow next to "Orientation" and change it to be flipped in the direction needed.
Jun 07, 2012 | Acer (VT3600G-50075) PC Desktop
Screen display has turned upside down
If you're Windows user you can try this out.
Will flip your screen to four direction
CTRL + ALT + LEFT ARROW
CTRL + ALT + UP ARROW
CTRL + ALT + RIGHT ARROW
CTRL + ALT + DOWN ARROW
Mar 30, 2011 | Computers & Internet
How to flip the display
If you are running windows 7 you can simply right click the desktop select screen resolution and then change the setting under the orientation drop down menu.
Feb 28, 2011 | HEWLETT-PACKARD Z400 Workstation -...
Projector displays reverse image also has grayish purple color
Use the remote to go into the menu and change the screen position. There are 4 to choose from, flip left, flip right, flip upside down left, flip upside down right. It may be tricky to navigae the menu backward though.
Dec 31, 2008 | BenQ PB6100 Multimedia Projector
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Flipped\upside down screen on my compaq
http://forums.techguy.org/tech-tips-tricks/336002-windows-xp-flipping-screen-upside.html
Windows XP: Flipping the screen upside down and back again
Once, at University, someone had flipped the screens of all the public computers (running on Windows XP) of the English Department upside down. The wallpaper, desktop icons, fonts, mouse-cursor and even the start-up screen...everything was displayed or moved upside down. People could not check out their e-mails or surf or do anything.
To reverse the upside down screen mode, press ctrl, alt and the up arrow (arrows console) at the same time; the screen will probably go blank. Turn off the monitor, turn it on again and the display will be normal again. If you possess a sense of humour or are antisocial, press ctrl, alt and the down arrow simultaneously, turn off the monitor, turn it on again and everyone (excluding the culprit) will be desperate --> upside down! Works for Windows XP Home and Prof.
Mar 31, 2008 | Computers & Internet
Picture reversed and upside down on screen????????
just happened to me, phoned customer support and solution is to press the Ctrl key and Alt key and Up arrow together and it should solve the problem
May 02, 2007 | Toshiba SD-P1200 Portable DVD Player
Polaroid PDM-0725
To change the screen upside right again just hold down the mode button until the screen changes upside right again , pressing the mode button changes the aspect ratio of the screen.
Oct 09, 2006 | Polaroid PDM-0725 Portable DVD Player
Canon PowerShot S2 IS Digital Camera Logo
110 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
