Question about Grohe Aquatower 3000 Shower Tower Handshower Panel
I have a Grohe Aquatower 3000 and cannot adjust the temperature. I want the water to be higher temperature and removed the temperature control knob and adjusted the flow to full hot. No response in water temperature. The other fixtures on the same water heater have a MUCH hotter output. What should I try next
  • 74 Answers
SOURCE: i have agrohe shower fixture with poor pressure
If the shower head is clogged (even if it it is not I would still do this)
remove the head and soak in coke (yes, it works), CLR, vinegar or bleach and see if you can dissolve the debris. If that is not the culprit, check to see if there is access to a shut-off valve behind or below the shower. It will be inside of the wall and is only acessable through a hole in the wall.
If that is not the case, it is now time to consider replacing the shower body. This is an involved job but something very doable by a competent homeowner.
Hope this helped.
Posted on Apr 16, 2009
gary1121
  • 332 Answers
SOURCE: Grohe bath faucet adjustments
grohe is a faucet all by itself ,,, I would recomend to have you call there repair dept. and explain this to them, you said you put in the new cartridge and thats about all there is to it, when you put on the handle make sure it is not over tightened, sometimes it pulls on the cartridge and makes it come on by itself good luck
Posted on Jun 06, 2009
  • 297 Answers
SOURCE: Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
Posted on Jul 26, 2009
  • 21 Answers
SOURCE: leak where Grohe shower head attached to the threaded pipe
using a pair of vice grips wrapped in a soft towel( to prevent scractching) turn the shower head in a counter clockwise direction to remove it then apply liquid teflon (real-tuf) to the threads on the shower arm and tighten the shower head but dont over tighten it liquid teflon is more effective at sealing leaks than teflon tape and it can be wiped clean
Posted on Dec 03, 2009
  • 1044 Answers
SOURCE: low water pressure in grohe hand held. Is there a
1 Check if the holes in the hand held shower are not clogged with scum which generally happens over prolonged use. Clean them with a pin. 2 If this does not help, then check the the pipe connecting the shower to the water outlet. It should be clean and not clogged with foreign material which restricts the flow of water. 3 It still it does not help then you may have to fix a booster pump or raise the level of the water reservoir.
Posted on Dec 20, 2009
My Grohe Aquatower 3000 shower is wonderful BUT after 5 or 6 minutes, the water starts cooling off. Is there some adjustment to keep the water warmer for 10-15 minutes?
You are lucky that your shower is lasting as long as it does. If you have a standard 40 or 50 gallon water heater, mixed with 30% cold water as it comes out, you can expect about 60 gallons of hot water, give or take a little bit. Each of those showerheads on that Aquatower is rated at 2.5 gpm. Even if you are just using the body sprays, you could be using 10 gallons of water EACH MINUTE. There is really only two things you can do, and that is to raise the temperature of your hot water heater by 5-10 degrees so you are mixing more cold water with the hot. The other thing is to buy a bigger hot water heater, or supplement the one you have with another water heater in series.
May 03, 2011 | Home
I just installed Grohe aquatower 2000 shower panel. there is no hot water.
Before installing, did you check the supply temperature? The mixer won't do any good on your AquaTower if you didn't calibrate the water temperature coming out of the wall first. I suggest you remove the supply line to the unit and measure it with a handheld thermometer (it should read 36 or 38 degrees celcius), then reconnect to the unit and you should be able to make adjustments through the mixer.
Jul 30, 2010 | Home
Install trim and adjust the thermostat on a Grohe shower faucet
Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
Jun 28, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
Shower head has little preasure or water volume. is there a flow restrictor that can be removed?
their might be on the handel where the hose meets, but if really low water pressure then maybe more of a problem.
Mar 26, 2010 | Grohe Aquatower 3000 Shower Tower...
We have a Grohmix shower valve and we are unable to adjust the water temperature. Any assistance would be appreciated.
Oct 20, 2009 | Grohe Grohmix Thermostat Valve & Trim -...
I have a shower tower and the water directional knob has become immovable any ideas?
try CLR to lossen it,remove and clean.This is due to calcium build-up. you may have hard water,have your water checked.
Jul 16, 2009 | Grohe Aquatower 3000 Shower Tower...
Grohe Aquatower 3000 Shower Tower Handshower Panel Logo
135 people viewed this question
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
