Question about Texas Instruments TI-83 Plus Calculator
I cannot get my TI-83 plus to turn on even though I just changed the four AAA batteries. What can I do??
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please add a comment to this post and we'll go on from there.
Posted on Sep 13, 2010
  • marielmestre Sep 13, 2010
    Ok, I tried using the 2nd key and then holding the Up-arrow key, but the screen didn't become legible.
    Any other suggestion? Anything would be very welcome! Thanks
  • kakima Sep 13, 2010
    You made sure you released the 2ND key before pressing the up-arrow key, right?
    Next step. Remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries. Does the calculator now turn on and work normally?
Can I reset ti 83 plus
Remove all four AAA batteries. Press and hold the ON key for at least fifteen seconds. Replace the batteries.
Sep 28, 2012 | Texas Instruments TI-83 Plus Calculator
What kind of battery does the TI-83 take
4 AAA batteries and one CR1616 or CR1620 button batter for backup
Source: http://en.wikipedia.org/wiki/TI-83_series
Sep 15, 2011 | Texas Instruments TI-83 Plus Calculator
There's something wrong with my TI-83. When I'm typing up an equation it will randomly shut off. And when it's on it will have shown that the RAM was cleared. Now it sometimes takes like 5 presses of the...
Have you tried changing the batteries? I'd try that first thing. From your description, the problem sounds like you have low batteries. The RAM shouldn't clear itself when you turn the calculator on unless you tried to turn it on when the calculator didn't have any juice. The TI-83 has four AAA batteries and one CR1616 battery it uses for memory backup. The CR1616 isn't enough to power the calculator, just enough to keep your calculator from losing its RAM contents while the primary batteries are out. If you try to power the calculator on without primary batteries, the backup fails. However, the TI-8x line is usually pretty good about warning you when the batteries are low by displaying a big warning message when you turn it on about the batteries being low and a recommended change of batteries. It might not, though, so you really can't be sure until you try a fresh set of batteries. Good luck!
Apr 09, 2011 | Texas Instruments TI-83 Plus Calculator
My ti 83 will turn on when i press the clear thing but when i try to put something in nothing happens
Hi imagenius1,
You need to free up some memory. Try clearing your RAM memory. Your calculator should operate properly afterward.
Press [2nd] [MEM] [7] [1] [2]
If the steps above did not reset the memory to your Ti 83 family calculator try the procedures below.
Please be prepared to re-install the calculator's OS if you run through this process.
If you have a straight Ti 83 without the Plus or, Silver Edition label goto (Procedure 2) below. If your Ti calculator is a Ti 83 Plus or better goto (Procedure 1).
(Procedure 1).
  1. Try a new set of AAA batteries.
  2. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and, then press [CLEAR] one more time to remove the message.
  1. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  2. Steps to re-installing the operating system:
    ~Connect the TI Connectivity cable between the PC and the calculator.
    ~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
    ~Follow the on-screen directions to reinstall the calculator's OS. If you could not install the new OS on your calculator goto step 4.
  3. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
  4. If the above process did not reset your calculator. Try re-doing (Procedure 1) and, extend the time in step 4, by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
(Procedure 2).
For a straight Ti 83 without the Plus or, Silver Edition label try the procedure below.
  2. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the AAA battery and then turn the calculator on.
Jan 06, 2011 | Texas Instruments TI-83 Plus Calculator
My TI 83 plus is not working. when i press"on" nothing happens. I changed my AAA batteries, i even change the back maxwell battery, but nothing happened
If this doesn't do it, please reply to this post and we'll go on from there.
Sep 27, 2010 | Texas Instruments TI-83 Plus Calculator
I have a TI-83 Plus. It just died. I have replaced the 4 AAA batteries and the lithium 1616 backup battery. I have checked to verify that the screen hasn't just dimmed. I get nothing. Any ideas?
Remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries. Turn the calculator on (you may have to adjust the screen contrast again).
Sep 10, 2010 | Texas Instruments TI-83 Plus Calculator
My Ti-83 Plus won't come on. The screen is blank. I have just put new batteries in it. What could it be?
If that doesn't do it, remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries. The calculator should come on (you may have to adjust the contrast as described earlier).
Aug 24, 2010 | Texas Instruments TI-83 Plus Calculator
My TI-83 Plus Calculator will not turn on
This is from TI FAQS:
Solution 11900: Troubleshooting a TI Graphing Calculator That Will Not Turn On.
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  2. Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Aug 06, 2009 | Texas Instruments TI-83 Plus Calculator
Dark screen, no blinking cursor
press 2nd and the down button (hold down button)
Jan 14, 2009 | Texas Instruments TI-83 Plus Calculator
Ti 83
Remove one of the AAA batteries. Press and hold CLEAR while reinstalling the AAA battery. Continue holding CLEAR button and press ON. Release buttons and press CLEAR again.
Jan 02, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
32 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
