Question about Pioneer DEH-P6400 CD Player
Where do i put my ground wire at ? do i attach it on the stereo somewhere or what? i cannot remember i recently wanted to put my cd player back in my vehicle just can't remember where it went ...?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 35 Answers
The frame of the vehicle is ground, the metal enclosure of the radio is ground also. If you have a ground wire coming out of the radio and you don't see the ground wire from the vehicle, then attached it to the cars frame.
Posted on Sep 13, 2010
IS THERE A WIRE ON THE STEREO HARNESS THAT HAS TO BE GROUND. OR THE ACTUAL HANDBRAKE SWITCH TO BE GROUND. IS THIS DONE BY PUTTING THE POS WIRE TO EARTH
No, you don't want to ground your positive wires, EVER! Also, I would avoid using the hand brake switch for anything but what it was intended for. Most power harness ground wires are just plain black. If you can't find one, ground it to the chassis of the car somewhere. This is less than optimal, as it may induce a ground loop and cause a buzzing that matches the engine's RPM.
Aug 23, 2013 | JVC Kd-avx33 Exad In Dash Dvd Player
Whats colors go to which?
  • Connect each wire yourself if your were unable to obtain a wiring harness to install your car stereo.
  • 2
    Connect the positive wire from each speaker to the positive connector on the back of the stereo first. Then connect the negative wire from each speaker to the negative connector on the back of the stereo. If there is only one wire coming from the speakers, the speakers are grounded at the chassis. In this case you will need to install new speaker wiring.
  • 3
    Connect the ground (-/black) wire of the stereo to a screw or bolt near where the radio is mounted in the dash. Make sure the wire is attached to metal, not plastic or fiberglass.
  • 4
    Connect the 12 constant and ignition power wires (both +/red) to the new stereo. Refer to your stereo's installation manual to make sure these go to the correct places.
  • Read more: How to Install a Car Stereo ' eHow.com http://www.ehow.com/how_866_install-car-stereo.html#ixzz1C6OmWWNO
    Jan 25, 2011 | Pioneer DEH-P6500 CD Player
    I want to put my stereo in my car that i just got, but the wires that are in the dont match the wires on the back of my cd player. why is this?
    because you will actually need to take the wiring harness off of the original stereo and splice the old harness to the new stereo
    Feb 10, 2010 | Pioneer DEH-P2900MP CD Receiver...
    I have a 1998 Pioneer head unit to put in my car. the #is 1256237179. Is There anyway to get a diagram to see how to hook it up?
    Well you can please follow the below steps -
    1. Disconnect your car battery. It is vitally important to your safety that you never work on any type of electronic in your car with the battery still connected, as this puts you at risk for electrocution.
    2. Remove the old stereo by taking off all the dashboard panels surrounding your stereo, sliding out your old stereo head unit, and unplugging all the wires that are connected to the head unit. Discard the old stereo.
    3. Take your Pioneer car stereo head unit and plug each of the positive wires from your car speakers to the positive terminals on the head unit. Take all of the negative speaker wires and connect them to the negative terminals on the head unit.
    4. Attach the stereo's black ground wire to a metal bolt or screw located near where the stereo is mounted in the dash.
    5. Connect all of the ignition power wires to your Pioneer stereo.
    6. Take the harness connector and plug it into your car stereo. Now plug the antenna into the back of your head unit.
    7. Slide the stereo back into the dash, screw it in place, and replace the dashboard pieces you removed earlier.
    8. Reconnect your car battery, turn the car on and test out your new Pioneer car stereo. Please post comments for more help or information..........
    Good Luck!!
    Thanks
    Jan 16, 2010 | Sony CDX-F7710 Car Audio Stereo CD MP3...
    How do i hook up my parking brake
    in the directions it should either tell you to attach a wire from the radio to the ebrake so you can get video. i dont like that idea . first try and ground and ground the wire to the back of the unit. some manufactures incorparate a sequense ex- pull e brake three times then the video will work . what i have done with these is put a small button in the center console or somewhere out of the way . if you want to hook it up the way they want it i need to know what kind of car you have ...
    Jun 19, 2009 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
    Inconsistant functionality
    It sounds like a bad ground wire connection-you want to check the rear of the head unit and make sure that your wire harness is very secure to the unit clip the ground wire and run your own ground wire to somewhere-anywhere where you can safely ground that wire to the chassis I actually attached my ground to the rear of the cigarette lighter because you KNOW that it has a dam good ground to manage all the current it takes to light them coils orange like that
    May 21, 2009 | Panasonic Car radio CD CQ-C1110GN CD...
    Panasonic R 805e with cd shuttle
    I had a similar sounding problem with my stereo and got the following response here...
    "It sounds like a bad ground wire connection-you want to check the rear of the head unit and make sure that your wire harness is very secure to the unit clip the ground wire and run your own ground wire to somewhere-anywhere where you can safely ground that wire to the chassis I actually attached my ground to the rear of the cigarette lighter because you KNOW that it has a dam good ground to manage all the current it takes to light them coils orange like that"
    I took the advice and it worked out great! Give it a try and see what happens.
    Apr 05, 2009 | Panasonic Car radio CD CQ-C1110GN CD...
    Blown fuses for the stereo
    Verifiy the hot positive wires are hooked up correctly sounds like one is going to ground
    Feb 15, 2009 | 1987 Chevrolet Celebrity
    Speaker Problems
    If you are unplugging the subs from the aux output at the cd player, your Audio lines feeding the amps is shorted somewhere between the cd player and Amps.
    Nov 13, 2007 | Car Audio & Video
    Pioneer DEH-P6400 CD Player Logo
    136 people viewed this question
    Top Pioneer Car Audio & Video Experts
    Michael Kovalik III
    Michael Kovalik III
    Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
