Question about Samsung 225BW Monitor
How to open a Samsung 225bw besides just removing the screws?
  • Samsung Master
  • 1,684 Answers
Here is a link to a repair guide that shows how to dis-assemble the unit.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-225bw-22-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Posted on Jan 04, 2012
Samsung 225bw
Here is a link to a repair guide that may help you get it going again.
May 13, 2012 | Samsung 225BW Monitor
Try to figure out how to take the monitor apart to check caps. I took three screws out of the bottom but it did not come apart. What do I need to do?
You start cracking it open at the bottom edge of the monitor using thin flat balde screw driver and then work your way around and watch out for any cable attached the front panel switch assembly, it can be real difficult sometime. You can also look at YOUTUBE for 'how to open LCD monitor'. It takes experience to figure out.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 08, 2010 | Samsung 225BW Monitor
Monitor will not come on. Power light just flashes.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Aug 13, 2010 | Samsung 225BW Monitor
Any one have the list of caps that need to be repalced
You can get a full repair guide with parts list at:
There is also a video showing how to dis-assemble the unit to get to the power supply board.
Jun 25, 2010 | Samsung 225BW LCD Monitor
I have no blue light at the power button for my Synchmaster 225BW
The power switch is a momentary tactile switch. If you want to fix it, you will have to turn it off and look at the size of the switch to try to find the replacement for it. Not much you can do but open it up to find the cause of the problem.
http://www.badcaps.net
Apr 17, 2010 | Samsung 225BW LCD Monitor
Need to replace all capacitors in my 225BW. Need
The 225BW monitor uses the same capacitor kit that the 214T monitor uses. You can order the repair kit at:
http://www.ccl-la.com/LCDrepair4.htm The kits run $12 including shipping. If you don't want to do the repair we do offer a repair service for $30 plus shipping.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 31, 2010 | Samsung 225BW LCD Monitor
Hi, i have Samsung SyncMaster 225BW monitor and while using Microsoft word it stop working. On off button blinking with blue light.. However when i plug/unplug the video cable nothing happens. Regards...
There r problem with your CPU not from Monitor might be any hardware failure at that moment.Pls restart the system after that if display is coming or not if display is not coming might be RAM chip is faulty replace it with goods one.If display still not coming then problem with your Motherboard.pls get it repair by vendor.
Nov 17, 2009 | Samsung SyncMaster 203B LCD Monitor
Samsung model 225bw does not turn on
The Samsung 225BW has a known issue with the power supply going out. The dark screen with no power light or power light blinking are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com. We have a step by step repair guide with pictures posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $30 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
Buddy
Corporate Computer
www.ccl-la.com
Apr 05, 2009 | Samsung 225BW Monitor
Samsung 225bw display with NO VIDEO and flashing power button
A flashing power light and no picture is a sure indication of a shorted power supply board. There are parts called capacitors that fail and this causes the power supply to continuously shut down and restart over and over, hence the power light flashing. If you can do a little soldering then you can repair the unit. Here is a link to a service guide showing how to dis-assemble the monitor and repair the power supply board.
I hope this helps, if so please ratre my solution.
BuddyMc
Nov 22, 2008 | Samsung 225BW Monitor
Monitor
Steve from Monitor Technology. You need to open the monitor and locate the inverter board.
Remove 3 screws,turn the board over and locate 2 caps,C110 and C111.Replace,820UF/35V
this will fix this problem.
thewizguy@comcast.net
May 03, 2008 | Samsung 225BW Monitor
Samsung 225BW Monitor Logo
179 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
