WHY IS MY POWER LIGHT NOT WORKING - Audio Players & Recorders
    Problem Solver:
  • 6 Answers
If unit is working the bulb should be burned
Posted on Sep 13, 2010
My brake lights wont work.I have replaced bulbs,& the brake switch and checked the fuses and relays. Still wont work. They are the only lights that aren't working.
You are now looking at circuit tracing. Start at the brake light switch. Got power there? (get a circuit testing light, they're not expensive, looks like a screwdriver with a point instead of a blade, and a wire coming out the end)
If power to the switch, then check at light with brake pedal pressed. Power there? likely bad ground at light.
No power? wire from switch to lights broken.
Jan 08, 2016 | 1999 Lincoln Town Car
GE Monogram ZV950S D2SS range hood - lights on one side stopped working then on both sides. This happened as I was changing bulbs. Everything else works.
Light doesn't work
  1. Light bulb
If your refrigerator light does not power on, the first thing to replace would logically be the light bulb itself.
  1. Light assembly
If your refrigerator light does not power on and you have replaced the bulb, this is an indication that the light assembly may have malfunctioned and will require replacement.
  1. Light switch
If you notice that your refrigerator lights are not working, replace your refrigerator light bulb. If this does not correct the issue, proceed to check the power light switch.
  1. Door switch
If your refrigerator light is not working and it is not the bulb itself or the power light switch, the next thing to check is the door switch. This can be checked for continuity with an ohm meter. If there is no continuity present, the door switch will need to be replaced.
  1. Light socket
If your refrigerator light is not working after replacing the light bulb, check for a possible damaged light socket. If the socket is faulty, replace the part to get your refrigerator light to power on again.
  1. Light board
If the refrigerator light is not working the light board could be defective. The LEDs on this board are not repairable, so the entire board will need to be replaced.
Feb 15, 2015 | GE Refrigerators
Spotlight wiring
Copy following link for troubleshoot resources and tips to get power pack to last longer.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
The lights don't have bulbs?/ This is not clear.
Buy new bulbs.
Be sure to unplug power pack when working on lights, or power pack can fail.
Jun 30, 2013 | Malibu Hardware & Accessories
1996 Camry reverse lights don't work
Check if you are getting power to the reverse light switch. Turn ignition on, disconect terminals to the switch and check for power on the positive terminal using a light bulb or a test meter whatever. If power is there jumpthe 2 terminals and check if light backup light works. If it does replace switch. If ther is no power at switch check wiring from fuse box. If light does not work when switch is jumped check wiring to back.
Sep 11, 2012 | 1996 Toyota Camry
Tail lights not working. fuses look good, brake lights work, hazards work, but running lights don't- gmc sierra 2500
do the front marker/park lights work if not you could have a bad light switch on the tail light side of the switch.you need to check the brown wire at the back of the truck in the wiring harness as this is the tail light wire that feeds the bulbs.if you have power there then you will have to check for power at the socket,if no power at the socket but were you check the wire then there is a problem between the two that you will have to check out.if there is no power when checking the wire then you will have to check for lose of power between the switch and rear wiring.make sure the fuse is good by using a test light and not by looking as sometimes they look good but don`t work.
Jul 11, 2011 | GMC Sierra 2500 Cars & Trucks
My right rear fog light does not work, any ideas why? the other lights work fine, and its not the light bulb
check for power at the light, if no power and fuse ok check for power to switch and power coming out of switch when switched on if there is power to switch but no power out from switch when switched on, switch is faulty, if there is power from switch, wire is broken between switch an fog light
May 27, 2010 | 2003 Porsche Boxster
My power mirrors are not working & misc interior lights out
yea sounds like a loss of power. start by checking all! all the fuses.
Jan 28, 2010 | 2002 GMC Yukon Denali
Aquos has the power light and OPC light flasing but nothing works
First turn on power light stable at all?Power and OPC lights well flash,but push on/off power button do this couple times after the Power and OPC flashes well backlight come back on well work.This problem very common is Sharp tv.
Jan 17, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Were is the rpo relay located . my regular brake light don't turn on. i check light bulb r ok. there is no power to going to the back lights
RPO relay?? no power to rear lights or just brake lights?? is there power at the brake light switch? does the center high mounted brake light work? if the center light works the the switch is good. fuse #13 powers the brake lights (all)
Sep 28, 2009 | 2000 Ford Expedition
Brakes lights don't work, only 3rd brake light does.
If your third brake light is working, then we know it is not the brake switch. Get a test light and check to see if you have power at the light socket. If power is present possible bad ground. If no power, check connections inside of the trunk. Also choose a spot just behind the back seat to be sure that power is on the brake light wire, this will check for possible break along wire.
May 07, 2009 | 1997 Chevrolet Lumina
14 people viewed this question
 Grubhead
Grubhead
