Question about RCA RT2600 System
Have RCA RT2600 Home Theater. Getting "OVERLOAD" on certain sources which causes it to turn off. Have completely unplugged all connections except for power. Thoughts?
SOURCE: Help
Yes, if facing the front of the unit, with the cover off, when i hit the power button, the 5th white box from the left, turns an orange color when i hit the power button, and then kicks the unit off... i unplugged it and hit the power button again, then i touched the white box with my finger and it was already hot to the touch... is this a fixable problem??... oh yeah, my problem started when i decided to run my computer to my stereo with the digital RCA cable as opposed to the line out to stereo RCA configuration which i had been using... when there would be a loud part of a song, the RT2360 would overload and shut off, even tho i had the WAVE volume, master volume and SPDIF volume at a minimum... then the last time the RT2360 worked, i started to smell something and felt the top of the stereo and realized it was too hot, i went to shut it off and before i could move my hand from the top of the unit to the bottom, it sounded like it shorted out... thats when the "orange white box" problem started... is it a paperweight now?
Posted on Mar 09, 2008
  • 9 Answers
SOURCE: rca rt2600 OVERLOAD PROBLEM
Your receiver has blown out you need to buy a NEW Receiver and sub-woofer (the sub isnt compatable with better receivers)
Posted on Jun 27, 2008
  • 3 Answers
SOURCE: No Audio with home theater system
have you tried infra red link?
Posted on May 07, 2009
  • 230 Answers
SOURCE: rca rt2600 no sound, if you switch on the power
One of the audio output amplifier ics are toast the faulty one will need to be desoldered from the board and replaced, they run at about $10 each normaly. The faulty one will generaly be quite burnt.
Posted on Aug 18, 2009
dunnbiker
  • 8546 Answers
SOURCE: RCA Model RTD317W The standby mode
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Feb 04, 2011
RCA RT2600 sound problems
You should first try unplugging it for 30 minutes and that should reset it and has fixed the problem on other ones before.
Also, do the speakers hum at all or is it dead silence?
Thank you for further comments to my question.
Have a Good Day.
Apr 20, 2008 | RCA RT2600 System
I am getting no sound from my speakers, but im getting video. i have all the outputs and inputs in the right places. what are some possible problems?
Operator error. Mis-set switch somewhere Use a medium or low volume level until you find it.
Have you followed the manual used the Test Tones to set it up? How did it sound at that time?
Have you and evaluated every indicator on the front to understand what they mean in the context of source selection?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/RCA-RT2600-Home-Theater-Systems-manual/id/402ag606/t/2/
See page 23.
No audio.
Make sure the speakers are connected.
Check the input connections.
Check the power cord connections.
Make sure the MUTE signal on the front panel is off.
Make sure the digital setting (optical, coaxial or analog) is correct.
Check that the headphone is not inserted.
Mar 07, 2011 | RCA RT2600 System
Rca rt2600 no sound, if you switch on the power the display comes up and within a seconds it shows OVERLOAD in the display and it automatically turn off. all speakers had disconnected too. please help me...
Aug 18, 2009 | RCA RT2600 System
I have a new Phillips 42" LCD and it only has a digital audio OUT on it, how do i hook it up to the RCA RT2600 with the digital audio...for some reason it is not wanting to give me any sound?!?!?!?!?
Be sure you have selected digital audio and enabled the digital audio out on the phillips tv audio setup menu, then be sure that the RCA rt2600 input mode is set correct
Mar 19, 2009 | RCA RT2600 System
Multiple Video Sources hooked to RT2600, but only DVD shows
I own the RCA RT2600 Home Theater System. I have never set it up, it has never been used. I have someone who wants to buy just the receiver and nothing else. I am wondering what you paid for just the receiver? I don't want to break up the system but I need money right now. I am open to suggestions as to what to do and how much to sell them for.
Thank-you
connally35@aol.com
Jan 17, 2009 | RCA RT2600 System
Rca rt2600 when i press power botton i hear a click sound and doesn't turn on
you're having a startup problem, u should take to an expert.
Aug 18, 2008 | RCA RT2600 System
RCA RT2600 Speakers stopped working.
I bout mine used an it has absolutely no problems you probably got one that they knew wasnt really working in the first place.
Jan 25, 2008 | RCA RT2600 System
Rca rt2600 OVERLOAD PROBLEM
Jan 06, 2008 | RCA RT2600 System
DVD problems
u having a problem with your tv . take it to a professional.
Nov 06, 2007 | RCA RT2600 System
RCA RT2600 System Logo
62 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
