Question about Samsung S860 Digital Camera
My computer doesn't hook up to my camera when I plug it in the port. I don't have the mabuel or setup cd , because I bought it used.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
Consider NOT hooking up your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Posted on Jun 17, 2011
Last month we bought a new Toshiba 46SL412U LED TV. We would like to hook up our digital camera to it to see pictures of a recent vacation. We don't know how to do it. All that came with the TV was...
Your television has a USB port. Yyou can hook up your camera to the tv using a USB cable, goto input ->USB select pictures as the type of content to browse the pictures on the tv.
Jul 15, 2011 | Toshiba Televison & Video
Hp Pro webcam will not work.
Follow the instructions below and it will work.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program.
When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the
camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
Jun 02, 2010 | HP Webcam
How do i hook up my belkin f5d7230-4 router to hughes net internet when there is only one ethernet port?
Connect that one port to your Belkin WAN (Internet)connector (Yellow Port). The other ports go to other computers, to their Broadband RJ45 connectors.
Here's from the manual:
1. Unplug your existing modem’s power supply.
Find the cable connecting your modem and computer.
Unplug it from the modem and plug it into the gray port
on the Belkin Router.
If you are replacing an existing router, find the cable
connecting the computer and old router. Disconnect it from
the old router and plug it into the gray port on the new router
2. Connect the new cable (provided in the box) to the yellow
port on the Router. Plug the other end into the modem.
G WIRELESS ROUTER Quick Installation Guide
3. Plug in your modem’s power supply. Wait 60 seconds for the
modem to start up.
Plug the Router’s power supply into a wall outlet, and the
other end into the black port on the Belkin Router.
As the Router wakes up, lights will come on; recheck your
connections if the “power” and one of the “wired” lights
are not lit up in green after 20 seconds.
4. Locate the CD in this guide and insert it into your computer
The Setup Assistant should appear automatically.
If it doesn’t, open the CD in My Computer (Windows®)
or the Finder (Mac OS® X) and double-click on the
“Setup Assistant” icon
Nov 15, 2009 | Belkin (F5D7230-4) Router (587009)
No setup cd for the Linksys WRK54G Router
hi! you can still setup your router even there is no setup cd. connect your ethernet cable to port 1 of the router and the other end to the ethernet port of the computer..press the reset button on the back of the router for 10sec.. unplug the power of the router for 15secs and then plug it back in.. pull up your internet brower and type in to the url: 192.168.1.1 and it will prompt the username and password.. by default the username is admin and the password is blank - means-leave it blank.. then it will show the setup page of the router....
Aug 07, 2009 | Computers & Internet
Have no cd to setup camera on computer
You don't need any software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
May 23, 2009 | Kodak EASYSHARE M1063 Digital Camera
My camera won't be recognized when it's hooked up...
Make sure the camera is on and pc is selected on the camera screen when connected to the computer. You will need to have PC highlighted and select ok on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. The camera uses the driver usbstor.
May 17, 2009 | Olympus FE3010 Digital Camera
Conect the router?
1. Unplug your DSL modem’s power supply.
the old router and plug it into the gray port on the new router.
port on the Router.
modem to start up.
4. Locate the CD in this guide and insert it into your computer.
If it doesn’t, open the CD in My Computer and double-click on the
“Setup Assistant” icon.It will guide you through he rest of the setup.
If you need more help please post back,If this help please rate as a fixya.
May 17, 2009 | Belkin (F5D72304F5D7000) Router
I am not sure how to install the software
WARNING: DO NOT connect the camera to your computer before installing the software.
To install the software, insert the Logitech camera software CD into your computer's CD-ROM drive. The Setup screen should appear. If it does not, please perform the following steps:
  1. Click Start and then Run.
  2. Type D:Setup.exe and press the Enter key.
  3. Follow the on-screen instructions.
After the computer reboots, the driver installation for the camera will start. Do not connect the camera until the setup prompts you to connect the camera cable to your computer.
While the driver installation progresses, remove the camera and camera base from the packaging and mount the camera on the camera base.
When prompted, plug the camera into the USB port. You should see the following diagram to let you know where to plug the camera in:
After the installation is complete, the camera should be ready to use.
Thanks
Aug 21, 2008 | Logitech QuickCam Messenger Web Camera
Trying to talk to another computer with quickcam
Setup :
*NOTE: DO NOT connect the camera to your computer before installing the software.*
Or
You can download the latest vista drivers from here, this link will give you the instructions on how to download the drivers with the images.
http://tinyurl.com/6ruwav
Using the CD :
Type D:\Setup.exe and press the Enter key.
Using the Downloaded file :
Double click on the setup file.
We have done the drivers installation which are needed by the computer to ecognize the camera.
Setup instructions to work with the camera :
http://tinyurl.com/585der
Hope this helps.
Good Luck.
Live, Love,Laugh.
Apr 13, 2008 | Logitech QuickCam Chat Personal Web Camera
Samsung S860 Digital Camera Logo
18 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
