Question about Pegasus Technologies Two-Piece Round Toilet by Pegasus - 15 3/4 Inch Bowl Rim Height
I have a pegasus 164-146. need a toilet tank gasket that the tank sits on to connect to the bowl. Cant find one anywhere
I have a 3" gasket on a toilet top I bought and can't find a pegasus bowl to fit this tank
Posted on Dec 08, 2010
  • 377 Answers
This is referred to as a SPUD gasket and should be readily available at a Lowes or a Home Depot.
Posted on Sep 13, 2010
You need a spud washer.
Or a gasket and bowl kit.
Or toilet tank gasket
Or tank to bowl gasket
1) Fixya answer from last year says Lowes/ Home Depot sells part
Home Depot sells Pegasus toilets
http://www.fixya.com/support/t5647268-need_tank_bowl
2) Plumbing supply dot com has selection
http://www.plumbingsupply.com/tank_gaskets.html
http://www.plumbingsupply.com/closetspuds.html
Company also has contact page:
http://www.plumbingsupply.com/email.html
3) http://www.plumbingworld.com/toilettankgaskets.html
4) If gasket is not torn apart, you can probably seal it again using rectoseal on both sides of washer. This is how I fix problems. Buy rectorseal from home center.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on toilet or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 01, 2011 | Pegasus Technologies Two-Piece Round...
I NEED A TANK GASKET
You should be able to go to your local hardware store for a replacement. Remove the one currently on there by removing the tank from the bowl.
Nov 08, 2010 | Pegasus Technologies Two-Piece Round...
Need a tank to bowl gasket for pegasus toilet
homedepot or lowes will have this part just go an ask some one in plumbing
Aug 18, 2010 | Pegasus Technologies Elongated 2 Piece...
Flapper problem
did you have the tank removed from the bowl?
if you did, there is a rather large nut that holds the flush valve to the tank, fairly simple to reinstall.
if you did not have the tank removed from the bowl, and you pulled up on the overflow tube "round white thing" then you probably broke it. you will need to replace the whole flush valve assembly.
you can get one from your local hardware store. you will also need new tank bolts, and a new gasket that goes between the tank and bowl.
Jul 04, 2010 | Pegasus Technologies Pegasus Toilet Paper...
Looking for a tank to bowl sponge gasket or washer for a pegasus toilet. 4 3/8 x 3 1/4 x 1 1/8. Any idea where to find one? Have called a plumbing store, home depot, pegasus (have not received a call back...
if you take the old gasket out you should be able to match up with a new one.Unless I am mistaken they are pretty much a universal gasket that fits between all tank to bowls
Feb 22, 2010 | Home
Home Depot Pegasus Elongated Toilet I need gasket between tank an
Strange that it went, but do you still have it? If so, bring it to your plumbing supply store and they should be able to match it up. Not sure why Home Depot can't help though. If you do not have it, bring the tank so they can try it right there. Good luck and make sure you don't overtighten when reassembling (can crack easier than you think). Can always tighten, but never loosen when it's too late.
Sep 04, 2009 | Pegasus Technologies Elongated 2 Piece...
NEED TANK TO BOWL GASKET FOR PEGASUS TOILET WITH HIGH VOLUME FLUSH VALVE
Most of these parts are fully interchangable. If you can, take the take off the toilet and bring the gasket with you to the hardware store and buy one just like it. If not, buy the ones they have there and replace the ones you don't use.
Aug 11, 2009 | Pegasus Technologies Home
How to attach tank to toilet without leaking
That gasket should be squashable. It's called a donut. and is meant to sit between the tank and the pan - No caulk or other sealant need be used
Place over siphon thread up to securing nut - lower tank on top of pan and secure with the nuts/wing nuts underneath
Tighten each side equally - NOT one side then the other.
Jun 13, 2009 | Pegasus Technologies Two-Piece Round...
Pegasus Technologies Two-Piece Round Toilet by Pegasus - 15 3/4 Inch Bowl Rim Height Logo
453 people viewed this question
Top Pegasus Technologies Home Experts
john h
Jim Goldsmith
Jim Goldsmith
Paul Carew
Are you a Pegasus Technologies Home Expert? Answer questions, earn points and help others
