Question about Juki TL-98Q
My machine will sew just find then suddenly it will cause the thread to tighten, pull and bunch the fabric until the thread breaks. I have tired rethreading the machine and new needles with no success. Please help. Jane
  • 161 Answers
I wonder if you have something catch in the thread guides?
Posted on Sep 13, 2010
I need a manual or instructions for my old Dressmaker2000 deluxe precision sewing machine Sn.05940
bunching would be the tension and sadly we can not FIX that thru the airways . see a repair shop for assistance locally
Mar 12, 2018 | Sewing Machines
Thread bunching up on bottom of fabric
Remove the top thread from your machine (NOTE: ALWAYS clip the thread next to the spool, lift the presser foot, and gently pull the top thread down from top to bottom!!! This helps reduce the chances of breaking something by pulling the thread upwards!)
ALWAYS RAISE the presser foot and rethread the top thread from beginning. Verify the thread path is correct and start out with the thread tension set at the midway point (and then tweak the top thread tension through testing).
FWIW, if the thread problem appears under the fabric, it is generally a top thread issue. If the thread problem appears on the top of the fabric, it is generally a bobbin thread issue.
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
CURED Sewing Thread Nests on the bottom
Jul 04, 2017 | Sewing Machines
Why is sewing machine thread gathering under fabric?
adjust the tension to a appropriate setting,
See the video here.
Sewing Help Sewing Machine Problem Thread Bunching Under Fabric
The knob and its location can differ based on the model of your sewing machine.
Oct 29, 2016 | Sewing Machines
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
Why does bobbin cotton keep bunching?
Is it the upper thread bunching under the fabric? If so, it is usually incorrect upper threading, the thread is not seated in the tension disk, or the upper tension is too loose. Also, a damaged needle can cause issues.
Install a brand new needle that is compatible with the thread and fabric. Frequent changing of needles is an inexpensive fix for a frequent sewing issues.
All About Needles
Remove all the upper thread.
RAISE the presser foot and rethread from the beginning.
Make sure the thread path is correct (consult the manual).
Set the upper tension at the midway point between high & low numbers.
Retest. If the upper thread and bobbin thread are not meeting in the middle of the fabric stitched, then loosen or tighten the upper tension until it does.
NOTE: Always thread the upper thread with the presser foot in the raised position. This opens the disk and allows the thread to seat properly. Also to remove upper thread, it is best to clip the thread near the spool, raise the presser foot, and graspl the clipped thread tail near the needle and pull DOWN through the machine (Never pull thread up through the tension disk).
Noted that you cleaned the bobbin area, but also be sure to clean the feed dogs. Frequently, lint & dust accumulates in and around the teeth which can inhibit their ability to grasp the fabric firmly. Frequent cleaning in this area is important for your machine's maintenance.
Review the cleaning and oiling instructions in your manual. Oiling is important and should be performed frequently with 1-2 drops each spot as specified. Oiling the hook is usually good to do every 8 hours of sewing time. Use ONLY fresh good quality sewing machine oil for your machine--NOT 3-in-1, WD-40, cooking oil, or the old metal can in grandma's sewing basket.
Feb 22, 2016 | Sewing Machines
What is the factory tension setting for the Brother LS-2125i sewing machine?
you probably wont find it listed anywhere as it is from experience and changes with different material thickness and needle size
SO how to set tension
thread the machine and adjust the tension until you feel a drag on the thread
now thread the needle and sew a piece of scrap material
if the thread bunches up underneath then increase the thread tension until it sews properly
if the bottom thread is pulled to the top or the thread keeps breaking loosen ti off a bit
when the stitch is being properly formed , both bottom and top threads should meet at the center of the two materials being sewn
Oct 13, 2015 | Brother LS2125i Sewing Machine
My machine bunches tread on the bottom of the fabric when sewing. What am I doing wrong. This machine is new to me.
thread bunching under material is an indication that the needle thread is not at the correct tension
tighten up the tension setting until the result is where the both treads meet at the center of the materials being sewn
practice on pieces of scrap until you get it right
Oct 01, 2015 | Sewing Machines
Needle thread knots up under fabric.
I have the same problem but i have not watched it. I does not seem that anyone wants to help us here, I am going to other sites until i find someone knowledgeable. apparently we are the smartest here at the moment ;)
Mar 31, 2013 | Sewing Machines
Similar issue with bunching on the bottom side of vinyl
when sewing thick fabrics and when using thick threads you will usually need to tighten top tension - on most machines to maximum in order for the machine to pull the thread up into the fabric. you must also use a needle which will slide along the thread when thread is through eye of needle (take needle out of machine, put thread through eye and see if needle will pass freely along thread - if not, use a larger needle)
scott.
Jul 11, 2009 | Bernina Activa 130
Juki TL-98Q Logo
77 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
