Question about Water Heaters
Hi I have a electric hot water system and for the past 6 months dont have any hot water from 9:00 am till about 2:00pm. I have had the element replaced and the problem still exists. I have contacted my electricity provider and they advise that i am not connected to off peak so that would not be the cause. Please help as I don't know what to do. Muoi
  • 2,841 Answers
Make sure both thermostats are set to a minimum of 130 degrees to prevent bacterial growth. Your water heater has 2 elements. Have you replaced them both. If you have then you may have a heavy buildup of sediment. Turn the water source off, open your hot water faucets and remove the aerators on everyone in your home. Connect a water hose to the drain connection on the bottom of the water heater and run it outside. Make sure it is lower than the drain. Drain all the water out of the tank. Shut the valve off and remove the water hose. Shut all hot water faucets off except one and turn the water source back on. When you see and hear water coming from that one faucet turn if off. Turn all the others on to help remove any loose sediment. Put the aerators back on all faucets. You may also have a broken dip tube. It goes down into the tank and if it is broken then cold water cannot get to the bottom of the tank which will make it appear that the heater is not working.
Posted on Sep 13, 2010
Yesterday the hot water went cold after 2 minutes into a shower.I checkAQed the hot water unit and noticed it seems to be damp around the base.it's an Aquamax 315 twin element electric hot water heate
Electric hot water heaters are particular to water levels and air pockets. Air pockets (low water levels) can cause the upper element to fail thereby reducing the overall recovery of hot water. Also if this is supplied by a well the incoming water temperature is lower than city water and also maybe adding to your problem. First thing I would check is the upper element. Start there and re-post with updates..
Sep 30, 2014 | Water Heaters
It has cold water comign out no hot
Yes, the reset probably is tripped...push in the red button hard
Then turn it on and try it...
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
Jan 18, 2011 | RELIANCE ELECTRIC WATER HEATER
I put a new top thermastate, bottom thermastate, new top element, bottom element, on my electric 50 gal tank and didn't get hot water. Only 4years old. Bought a new GE 50 gal. tank and installed, even a...
The next thing you need to do is find out whether you have 240v to the bottom element....the top will not heat till the bottom is satisfied...
An electric meter is critical when working with these units....trace the power and see where it stops....
here also are some tips that will help you...
Electric Water Heater Wiring Diagram
Electric Water Heater not Working
heatman101
Dec 04, 2010 | Rheem Water Heaters
Electric water heater out. Already replaced elements and breaker. Getting power to the unit but no hot water. What now?
Have you reset thermostat on the heater, it will be the top thermostat right above the element. It will have a red reset button to press to reset. They will trip causing the heater not to work till it's reset or replaced due to thermostat gone bad. Chances are you may only have to reset it.
Please go to link below with to get some very helpful information on these topic's. If you replaced everything but the thermostat or reset it that's all left to hold out power to water heater. The thermostat is a safety device to protect the home owner. You may have had a element short out to trip it.
It will take 30 to 45 minutes to start to produce hot water after power comes back on.
http://www.water-heater-repair-guide.com/electricwaterheatertroubleshooting.html
Jun 17, 2010 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
New Rheem electric 50 gallon not heating
Check the elements, if you have access to a meter to check them. If they are getting power to elements and you have no hot water.
The elements are not working correctly. I had some elements check out ok till the thermostat's turned on and the elements didn't heat.
Sounds like the elements are bad.
Jun 01, 2010 | Water Heaters
50 gal. Reliance electric hot water w/bottom element problems
Willard when you say it throws the reset button,do you mean the breaker on your fuse box of your home?
If you mean that then yes it could be a bad element.The bottom element takes all the abuse on a electric hot water heater. They can short out,and need to be replaced.
Dec 01, 2009 | Reliance & 50gal Electric Water Heater
Low hot water output
do you have a question on this?
You have a water heater that has woked well in the past and now the amount of hot water is diminished?
When was the last time your cleaned the junk out of the bottom? Do it now ... connect a hose to the bottom drain and lead the hose to a drain. Run the water until it is clear + 2 or 3 minutes.
Is this gas or electric? You have plenty of gas ... all other gas appliances work fine in your home?
Electric ... you could turn off the power and check that the elements still good. check contunity first then carefully - repeat - carefully - turn the power and check the voltages. should be 220 V ac
If it put out hot water before and now does not ... the elements are good ... still no hot water, could be the thermostat.
all speculation on my part because I dont know what your question is.
a
Oct 05, 2009 | Water Heaters
I have a electric whirlpool 50 gal. energy saver water heater that is 3 months old. It keeps shutting off so i called whirlpool and sears came out and replaced the energy smart box on top. now it is...
the thermostat should be replaced it only has one on the upper eloement, it has the dial on it to set the temp, but if it is only 3 months old it comes with a 1 year parts 6 year tank warranty, if you call whirlpool and tell them about this problem they will have there own teck or sub contractor that they use to come out and fix it for free,,, first go to there web site and put in your serial number and it will tell you how old the unit is, sometimes they sit for a while and are actually out of warranty before it is installed,, also did you install it your self?? if you did di you fill it with water all the way till the water came out of the hot side on your faucet full force before turning on the electric,, if not you have fried the whole unit, you will need to replace both elements and the thermostat, the elements must be completely submerged in water before they have the power turned on,,,
Jun 25, 2009 | Water Heaters
Heater keeps tripping the reset on the thermostat
it's not the thermostat it's the element they are whats in the water and when the seperate thats what trips it,, you need to drain the unit with the electric off and do not turn the power back on till water is comming out of the hot side faucet they must be in the water before the power is turned on
Jun 11, 2009 | Reliance Water Heater #6-30-DORT 30GAL...
Water Heaters Logo
13 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
