Rheem: REAB-1415J is not turning on. Replaced the fuses and breaker and still nothing. I even checked to see if the fan turned and it does freely.
  • 144 Answers
Check your capcitor it is a canister that wires pull into it is measured in uf 's it can also be checked by contiuity if you like my subgestion please give me a vote and rating
Posted on Sep 13, 2010
Ruud troubleshooting
do you have the lower door in place tight ?? because there is a door button switch. so if its not pushed in all the way you would have no power at furnace. also make sure nobody turned off the on off service switch usually above furnace or sometimes one at top of stairs and one down by the furnace .if those suggestions don't work you might want to turn each breaker off then back on incase one is tripped. if that don't work check for 120 volt at your fan timer board also it may have a automotive style fuse on the board which if blown it wont do anything. if there is 120 volt at board and the 24 volt circuit fuse is good its probably the fan timer board.
Jan 17, 2014 | Water Heaters
Rheem RAKA-060JAZ trouble question
pls check for compressor shorting and relay issue in pcb
Oct 12, 2013 | Heating & Cooling
Looking for fan condenser relay for buick 1996
When you turn on your A/C does the compressor come on? Unless you have a heat pump or you have a newer A/C that has a control board in it you won't have a fan relay. The fan is powered by the contactor, when it is energized the fan and compressor will both come on. If the compressor comes on and the fan motor doesn't. Disconnect all the power. Try spinning the fan blade,if it spins freely the bearings are ok, if it doesn't stiff or drags even a little, then the bearings are bad and the motor needs replaced. Then check the capacitor, if it has a bulge or is swollen then the capacitor is bad and needs replaced. You sometimes can take it to your parts store and some of them will check it for you. Last with the power back on and the unit calling for cooling check the volts to the motor terminals if you have 230 volts and the capacitor is good, then the motor is bad and needs replaced, if you don't then you need to check the fuses at the disconnect or breaker.
May 31, 2010 | Heating & Cooling
I have a Samsung Ductless Air Conditioner. It wil...
i think there is a short circuit in the fan or compressor even in the board.loop check it & say how many amper is there?
May 21, 2010 | Samsung AS18A6RB Air Conditioner
Goodman A/c not cooling the fan not turning .what do I need to do?
If its the outside fan not running check the breaker and the fuses in the disconnect(some may not have fuses) if that is not the problem but you can hear the compressor running it could be seized fan motor, failed capacitor, faulty contactor, bad wiring. Turn the breaker off to the unit and try to spin the fan with a long screw driver or something similar but be careful not the bend the fan blade, If the fan will not move don't force it you need a new motor,If the fan spins freely move on open the cover and check the wiring but becareful the capacitor can still have a full charge and shock you even with power off. Other the that you will need a volt meter that can check volts, amps2_bing.gif, and capacitors to futher test the unit I suggest calling a local HVAC contractor and having the unit repaired and tuned up, by having a tune up done you can recoup the cost of the repair with the energy savings from the tune up.
Apr 02, 2010 | Goodman CKL36AR36 Air Conditioner
Rheem RBHC-17J14SFA elec furnace fan won't stop
sonds like u have a bad safety switch they r round and have 2 wires on them usually and u can check them by taking the wires off of them and checking continuity thru them there might be one on the blower housing also either that or ur blower relay may be bad and stuck closed
Feb 18, 2010 | Heating & Cooling
How do I get to the fan relay in a Rheem REAB-1410 AC unit.
The fan relay is located inside the air handler pulling out the top pannel.
Sep 30, 2009 | Heating & Cooling
Just replace compressor keep tripping circuit breaker
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
The fan motor could have been your problem all the time, because if the fan doesn't come on or runs slow, it causes high head pressure,
which causes high amps, which could trip your breakers.
Aug 02, 2009 | Heating & Cooling
Condenser fan wont come on nor will compressor I do have fan op
Thanks for your Question,
First thing to check is the breaker in the panel to see if its tripped, I would suggest turning to off, then back to on, if it trips right after you have a short, if not you will need to check your fuses at the disconnect, first, shut the breaker off to the condensor, then pull the fuses and Ohm check them, if you have no reading then one or both is bad, I would recommend replacing them both if thats the case, if they check good, then you have bigger issues with your heat pump, if these suggestions do not work let me know and I can go into more indepth proceedures with you on what to do, thanks again,
mr.grzz
Jan 25, 2009 | Rheem 81VP15S Point-of-Use Electric Water...
Heating & Cooling Logo
182 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
