Question about Whirlpool Duet GHW9150P Front Load Washer
Door will not open,it just will not do anything
  • 15,935 Answers
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
What causes erratic hatch opening and closing?
Hi Robin, Im AL the owner of Big As Auto Repair.
Robin, it sounds like you have something binding in the motor assembly. You see anything that catches and causes a restriction in the movement of the door closing are opening will cause the door to reverse. If you see anything touching the door or the props that hold the door open move the obstruction and it should work properly. If you do not see anything, then the most likely cause is the gear and motor assembly. Hope this helps and please visit my auto-repair-website here: http://www.bigasautorepair.com/
Jan 18, 2016 | Cars & Trucks
My Philips blu ray player bdp2185 the power light is on but the player won't do anything
What do you mean it does not do anything. Does the door open or try to open? If the door does not respond to the open and close functions you may want to try to gently press on the door and quickly release it. I have found that works at times. There are various reasons this could occur. Is the door trying to open? Is there a DVD stuck in the drive?
Aug 09, 2014 | Televison & Video
Genie garage door opener wont do anything. I just bought it today
Press learn on the ceiling mounted opener point the remote at the opener then press open three times then a light should blink test by pressing open if this does not work you should take it back to where you got it then ask for a refund
Nov 24, 2013 | Building Materials
Not even distribution - fault code comes up on the screen and will now not wash anything.
could be a faulty door switch. with the door open the power will not go to anything. if you close the door and no light comes on then it thinks the door is open.
Sep 30, 2013 | Fagor Dishwashers
I bought a Silver Spur ' as seen ' The rear nearside door won't open. The chrome knob inside the car is not connected to anything and the inside and outside hanles pull OK but don't do...
The door may be able to be opened with a "slim jim" or similar device. To do this you need to know the mechanical details inside the door. Opening up the other rear door sounds drastic but it might help. If you can get it open then it should not be closed until it is fixed.
One way many car doors can be opened is to remove anything that is in the way of removing the inside door cover such as the bench seat and then remove the door cover. The rods and levers, etc can then be manipulated to open the door.
I hope this helps.
Jun 21, 2011 | 1991 Rolls Royce Rolls Royce Silver Spur
What do you do if your ps2 regular doesn't open up?
If you mean the Drive door won't open, it means your probably going to need to replace the motor for the drive. First check and see if there's anything obvious that's keeping the door shut, anything sticky or perhaps jammed into the opening. If that doesn't work, you'll have to open up the unit and check the drive for anything inside manually.
Oct 04, 2010 | Sony PlayStation 2 (PS2) Console
1994 nissan sentra drivers door wont open from inside or out is it possible to pop door latch with screw driver or anything to get door open so i can remove the door panel and get a better look at things
Here's a trick I learned from a local body shop where I live.
Get a sawzall and cut the post that the latch hooks to.
This will open the door for you. Then repair whatever is required in the door, and replace the post on the inside of the body is cheaper than damaging anything else in the door.
Good luck on this repair.
Jul 02, 2010 | 1994 Nissan Sentra 4-Door
The door is locked on my front loader washer.
PUSH THE START PAUSE BUTTON, AND CLEAN THE LINT TRAP AT THE BOTTOM OF THE UNIT
ROB
Apr 14, 2009 | GE WPXH214A Front Load Washer
Opener not working properly
Garage doors have safety sensors so the door does not hit the car or anything else that gets in the path of the door. Check to see if anything is blocking sensor mounted on the track near floor. Also sensor my have been bumped and not in alignment. Hope this helps
Aug 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
Whirlpool Duet GHW9150P Front Load Washer Logo
65 people viewed this question
Dan Webster
Dan Webster
Sal De
