Question about Peg Perego 12 Volt Rechargeable Battery
When I plug in my charger it lights up to green right away. Does this mean my charger is bad?
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Check the charger with a multimeter and make sure that its putting out at least 12 volts if it is then check under the blue plastic cover of the battery and make sure that the positive and negative terminals are connected
Posted on Jun 07, 2012
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
Nov 19, 2013 | Motorola htn9042a charger,120v,single unit
The light is green on charger but the controls will not light up unless it is plugged in
When the charger light stays green when you plug it in it means the charger is not actually charging. Either the batteries are bad and will not take a charge anymore or the charger is not operating correctly. It sounds more like a battery issue. The battery voltage needs to be measured on each battery with a volt meter. If the voltage is less than 10 volts on either battery they both will need to be replaced.
Sep 26, 2013 | Electric Jazzy 1115 Power Wheelchair
How can you tell if your laptop battery is dead,or that your charger is bad?
Hi, if your mains plug has a fuse, I would check the fuse, if thats ok, put a multimeter on to the end of the of the charger lead and check for around 19v, it will say the exact voltage output on the sticker on your charger.
The green light malfunction indicates a issue with the charger not the battery.
Hope this helps
Best of luck
May 31, 2012 | Dell Computers & Internet
When charging my jazzy, do I unplug any plugs that controls my jazzy, or leave all plugged in? the reaon ask, green light will not come on the charger, which is onboard charger, unless I unplug controller...
No JJR all the plugs need to remain plugged in. On the Pride chairs the light on the charger will only come on green when the batteries are fully charged. When you unplug the controller the charger thinks the batteries are fully charged and the light comes on. Now the problem is the batteries. If they are old or you have a bad battery then the charger never senses a full charge so no green light. Hope this helps
Aug 26, 2010 | Pride Jazzy Select 6 Indoor Power...
Green power light comes on when you plug in car charger in but screen is blank
green power light is on charger or in GPS? IF it is in GPD that mean you have to push and hold the power button on GPS for about 1min and release and wait , if the green light is on charger that mean the GPS connector is bad and have to be replaced.
Sep 20, 2009 | Tomtom ONE GPS Receiver
Wont charge or turn on
not sure how long you have had this, but if the unit was completely turned off or battery completely dead, you have to hold the power button for about 15 seconds for the 3000t to start up...assuming the charge light at the top right is orange (that means its charging) no light means its not charging, green light means fully charged. if there is no power light on at the top right of unit, either the charger is bad or the port on the board is bad (which i do have) good luck and hope this helps. bill
Jul 05, 2009 | Magellan RoadMate 3000T GPS Receiver
On the issue with th ebattery on the 1521 inspiron. Took battery out and plugged in still will not power up. Could it be the adapter as well?
On the ac adaptor, look for a green light that will turn on when you plug it into the wall outlet, if its on that means the ac adapter working. If you get a green light on the ac adapter but then the green light goes away when you plug it into the laptop then that means the laptop has a bad motherboard.
If you plug the ac adapter into a wall outlet and get no green light then that means the ac adapter is bad and you would need to get another one.
Jun 21, 2009 | Dell Inspiron E1705 Notebook
Toshiba satellite M55 not turning on
Either the battery is faulty, or the charger is faulty.
Check the fuse in the mains plug, or even the power point you are using could have a bad connection.
Test using a lamp that you know works or a radio or something and try the charger in another outlet to find the fault.
May 24, 2009 | Toshiba Satellite M55-S135 Notebook
Peg perego 12v charger question
The green light means it is ready to use. If the battery is bad though, the light will still be green.
Mar 07, 2009 | Peg Perego 12 Volt Rechargeable Battery
Peg Perego 12 Volt Rechargeable Battery Logo
76 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
