Question about EuroTech EDC158 Electric Dryer
Need a belt - EuroTech EDC158 Electric Dryer
  • EuroTech Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 15, 2010
Need timing belt diagram
I need a diagram on how to line up a timing belt for a 1996 chevy cavalier 2.4l
Jan 22, 2012 | 2000 Volvo V40
Do you need to remove the belt tensioner to replace the serpentine belt?
NO YOU DONT HAVE TO REMOVE BELT TENSIONER.ALL YOU NEED IS A 1/2 BREAKER BAR PLACE BREAKER BAR ADAPTER END INTO 1/2 ADAPTER HOLE IN BELT TENSIONER THEN ROTATE BELT TENSIONER AWAY FROM BELT TO RELEASE BELT TENSION ENOUGH TO REMOVE DRIVE BELT.
Sep 11, 2011 | 1996 Ford Crown Victoria
Noisy fan belt
with a noisy belt its caused by a worn belt,belt not tight enough,a pulley in poor condition or grease/oil on the belt.check the condition of the belt,make sure the belt is tight enough.if it has an auto belt tensioner it may not be any good and need replacing.if the noisy belt doesn`t use an auto tensioner then the belt will need tightening.if its grease/oil then the belt will need to be replaced and the pulley`s cleaned off.
Jul 25, 2011 | 1998 Land Rover Discovery
I have a 85 cutlass with a 350 engine i need to know what belt i need it sqeeks very lound dnt seem to have the answer for it. It stops when the cluth fans kick but when it first start
i`m guessing that you are trying to find out which belt is making the noise.first you need to push on each belt to see if the belts tight and not to loose,at the same time check the sides of the belts for a glaze or shiny sides as well as cracks in the belt .any belt that is to loose may just need to be tightened, any belt that is glazed or cracked needs to be replaced.if the condition of the belt is good then it probably just needs to be tightened.a trick to find which belt that maybe just loose enough is to take a wax candle or a bar of soap and with the engine running(being very careful around moving components) take and apply the wax to each side of the belt one belt at a time, when the noise stops that is the belt that needs attention either by replacement or tighting
Mar 02, 2011 | 1985 Oldsmobile Cutlass Supreme
Brush not moving, suction working
This machine is made for Sears by Panasonic. The power head, depending on model has a "gear" / cog belt or a standard flat rubber belt. First turn the power head over and see if the brush roller turns easily, if so you do need a new belt. To access the belt you will have to remove the hood from the power head. There are 4 screws, one at each of the corners to take out. Once the hood is off you will see where the belt goes and find "teeth" in the motor shaft for the motor / brush roller if you need a gear belt. If both of these are flat you need a rubber belt.
You can go to sears.com and find the belt you need with the vacuums model number.
Apr 27, 2010 | Kenmore 22812 Bagged Canister Vacuum
How often should you get engine belts replaced and what belts need to be replaced?
Replace belts as needed, check for cracks on the sides of the belts or pieces missing from belt. A good belt should last 100,000 miles. and it is a good practice to replace at 100,000 even if it looks good. REPLACE ALL BELTS as needed.
Jan 18, 2010 | 1996 Nissan Pickup
I need to change the timing belt . i have a 2003 hyundai sante fe and the belts are squealling
If your belts are squealing it is the drive belt/belts that need attention not the timing belt. You need to check your belt tension and condition and replace as needed. If a timing belt ever got to the point that it might squeal the car would not run because it would be too far out of time. Your belts will all be external whereas at timing belt is internal and a major part of the engine.
Dec 02, 2009 | 2003 Hyundai Santa Fe
How do I tighten the A/C belt on my 2008 Mazda 5? The darn thing is squealing so loud but I can't seem to find a tensioner anywhere...
If it is a serpentine belt is is self adjusting. So if it is squealing then it needs replacing as it is worn out. And also possibly the tensioner needs replacing as it may not be holding sufficient tension on the belt. If it is a drive belt it more than likely still needs replacing as it will have become glazed from slipping. On a drive belt it is adjusted by loosening the mounting bracket on the A/C and moving it in a direction that tightens the belt.
Nov 07, 2009 | 2008 Mazda MAZDA5
Changing a timing belt on a 2001 Honda Accord
All of your fan belts needs to be taken off because the timing belt is located beneath the crankshaft pulley. There is a possibility that you may need to lift the motor off its motor mounts to gain access to the timing belt. Remember, the timing belt can't be seen from the outside.
Mar 08, 2009 | 2001 Honda Accord
Need a belt diagram
Good Day,
One is with A/C the other w/o.
Hope this helps
Jul 08, 2008 | 1995 Chrysler LeBaron
EuroTech EDC158 Electric Dryer Logo
142 people viewed this question
Top EuroTech Dryers Experts
Tim Whalen
Colin Stickland
Colin Stickland
Are you an EuroTech Dryer Expert? Answer questions, earn points and help others
