Question about HP Compaq Presario sr1010z PC Desktop
Green light in rear flashing won't part up - HP Compaq Presario sr1010z PC Desktop
  • HP Master
  • 5,660 Answers
The green light flashing is a diagnostic LED light, telling you there is a power failure.
More specifically a bad Power Supply.
Weak voltage power rail.
The Power Supply used in a Compaq Presario SR1010Z desktop computer, is a 300 Watt unit, and is an ATX form factor.
[ATX form factor for a Power Supply, denotes the size of the Power Supply case, and the shape.
It is approximately 6 inches Long, 6 inches Wide, and 3-1/2 inches Tall.
The ATX form factor for a Power Supply is used in over 90 percent of the personal computers out there, and is as readily available as the air we breathe]
Usually, HP uses one of three generic Power Supply manufacturers.
1) Bestec
2) Delta
3) HiPro
All are low quality Power Supply manufacturers.
This is HP Support, and the main menu page for the Compaq Presario SR1010Z desktop computer,
http://h10025.www1.hp.com/ewfrf/wc/product?product=1146324&lc=en&cc=us&dlc=en&submit.y=7&submit.x=6&lang=en&cc=us
If you click on Manuals, then on Upgrading and Servicing Guide on the following page, there are instructions on how to open your computer case.
This is instructions on how to replace a Power Supply, from HP Support,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01356113&cc=us&lc=en&dlc=en&product=3548196
(It's for a Pavilion a6230n desktop computer, but after you open the computer case of your Compaq Presario SR1010Z, the instructions are the same)
What Power Supply would I recommend?
There are 100's to chose from.
This is but one example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3276575&CatId=1078
Chosen because;
1) Maximum wattage is rated at 450 Watts.
A computer ONLY uses the power it needs, and NO more.
Wouldn't matter if you had a 10,000 Watt power supply, (No such thing. An exaggeration), if your computer only needs 100 Watts, it would only use 100 Watts.
(Surfing the internet typically uses 100 watts)
2) Has all the power cables you'll need, and more. Tie up the power cables you do not need. (Use plastic ties, Not wire, or bread wrapper ties)
3) 24 Amperes (24A) on the 12 volt power rail.
4) 135mm cooling fan.
The cooling fan on the Power Supply you have now is 80mm.
A larger fan turns slower. Produces as much air as a smaller fan, (Or more), but makes less noise.
Less wear on the fan's bearings also.
5) Is an ATX form factor Power Supply.
6) It's 80 percent efficient, compared to the 60 percent efficient Power Supply you have now.
(That is, if it was working)
Posted on Sep 13, 2010
  • joecoolvette
    joecoolvette Sep 16, 2010
    Most kind jatazus1, appreciate the rating!
Green light flashing won reset
DI YOU UNPLUG THE SET FOR 5 MIN OR MORE ?
Oct 04, 2013 | Mitsubishi WD-52525 52" Rear Projection...
Won't start up little green light flashing on back
the green light flashing on the backside is your internetconnection.
about the computer wan't start i should check the PSU do the fan movs any light on the motherboard.if not is the electric cord firmly and tight in place.if the fans runs and lights on the motherboard.you got no picture proberly brooken videocard.
Apr 11, 2013 | Computers & Internet
Describe your WD-62725 62 in. Rear Projection HDTV-Ready Television Problem Green light is blinking the TV won't turn on. We've unplugged it and tried to push the reset button and the green light...
If the led light flashes green continuously, the fault came from the DM power supply. The faulty parts there are the electrolytic capacitors. Let me know if your handy with electronics and I will assist you to fix it yourself.
Jdvillanueva
Sep 16, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Timer light did not stop flash
Lamp is not the issue. It most likely is a your DM card. You most likely have some capacitors that need to be replaced. This is a terrible issue with this unit. Do a google search for "DM" and the model number and you should see hundreds of posts.
Jul 02, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Flashing green power light on TV
have the power supply checked out sounds like it went out
Jul 09, 2008 | JVC AV-56WP74 56" Rear Projection...
HP Compaq Presario sr1010z PC Desktop Logo
297 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
