Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Not sucking up water
Dispenses water but will nto **** it up
  • joiedevivre May 25, 2008
    I have same problem . . . believe I have addressed the black oval gasket that was mentioned . . . is in center and covered by clear oval on water tank top (next to red mesh opening that is closed/filled by putting water tank in place . . .
    But still not drawing/sucking water . . . when put on "tools" instead of "floor cleaning" there is only a slight amount of suction . . .
    When power on much blowing - but not sucking - at base of unit where sits atop the floor . . . Frustrated
    President:
  • 1,673 Answers
There is a gasket, black oval shaped that sits on top of the clear window, the tank lip will sit over this, is it there and seated correctly. Is the tank filter clogged?
Posted on May 15, 2008
Will not suck water out of carpet
take the tank off and make sure their is suction coming through the suction port. While you are there make sure the rubber seal is on it. Let us know if this is not the problem and we can go from there.
Sep 13, 2014 | Bissell 9400 ProHeat Upright Wet/Dry...
Bissell powersteamer will not dispense water
calcium deposits from hard water... run vinegar and hot water through it a few times.
Mar 19, 2013 | Bissell 1699 ProHeat Clear View Upright...
Instruction manual for hoover swish carpet cleaner
my hoover swish dosent seem to **** up much of the water out of the carpet carpet is still quite wet and bot much water is sucked up for the amount of water that goes in the water dispenser
Nov 26, 2010 | Vacuums
Bissel proheat is not sucking up water
There is a oblong black seal that sits where the tank lip and the clear noozle window come together, is it there. Also make sure the filter in the tank lid is clean.
Jul 09, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell proheat
Where the lip of the tank sits on the clear window, is the gasket there? If it is missing, it won't suck up the water. It is black, oblong (#24)and sits in a slot on the clear window providing a seal for the tank. Is the filter clean(#62), should be sitting in the square opening on the bottom of the lid, it sits right over the sucking opening.
Feb 25, 2008 | Bissell 1699 ProHeat Clear View Upright...
Will not dispense soap from handle
The soap dispenser, on the side, make sure the seal is on the bottom of it and not in the hole. You may have to replace the valve asm for the dispenser part # 2101795
Sep 30, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Problem with staemcleaner
Check the bottom of the solution bottle to make sure that the seal is on the valve and not in the hole that it sits in.
Check to make sure that the seal that sits on top of the clear window, it seals the opening between the top and the tank. Also is the filter clean, the one on the bottom of the lid?
Sep 19, 2007 | Bissell 7950 ProHeat Upright Wet/Dry...
Water tank doesn't dispense water
water is not coming out or sucking up water
Aug 24, 2007 | Hoover F5906-900 Upright Steam Vacuum
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
35 people viewed this question
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
