Question about Maytag HAV2557 Top Load Washer
I have a Maytag LA212 AND a Maytag A8120 washers that will both fill but then do nothing else. The A8120 I got first and it just started this behavior last night then then today someone put out the LA212 for free but working. hump!! And they are doing the same thing. Any ideas? D
  • 1,305 Answers
I used to have 2 laundromats full of toploader Maytags... these will fill and do exactly what is happening to you if the LID SWITCH is not activating. Open and close the lid and listen for a clicking sound. Look a the rear edge of the lid... there is an indentation that is supposed to activate a small white switch in the that's attached to the top of the machine. Many times the lid will simply get bent.. someone sitting on the lid, standing on the lid... will be enough to throw it out of whack. Close the lid and push on the center of the closed lid... will the machine work? Or carefully push a flatblade screwdriver tip between the lid and the switch to see if you can get it to activate. Solution: Open the lid and apply firm pressure on the lid towards the back of the machine, while with the other hand push DOWN on the back edge of the lid...right where the indentation for the switch is... if you give it a slight tweak...you'll probably be back in business. One other thing, if the lid switch isn't clicking...replace it.
Posted on Sep 12, 2010
Do you have a wiring diagram for install a maytag washer water valve? the washer model is LA212
Sorry but this forum does not supply operation and service manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer service manual' and you may be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Also may I suggest you try the manufacturer's web site direct? You may find, however, that it will supply only to service engineers but good luck anyway.
Good luck,
John C
Mar 06, 2011 | Maytag Washing Machines
Maytag Washer MAV7000AWW Washer fills as it
Sounds like a bad timer motor.
Try watching the timer motor and see if you can see it moving .
Jun 09, 2009 | Maytag Atlantis MAV7000
Maytag Atlantis MAV6200 fills but doesn't do anything afterwards
If nothing turns on than your Lid Switch is probably it.It is the first most common fix on this model. Please Rate This !!!
Nov 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer will fill but won't start cycle
you need to take the 2 lid switch wires from the lid switch and wire them together this will bypass the lip switch,should fix it,let me know-mike
Oct 20, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag LA212 Toploading Washer - leaks as soon as a load is started. Will continue to leak until washer is stopped. Not a small leak - there is a puddle two days later in the floor below it. Removed...
It appears that from that area the problem may be the water inlet valve or it's connections. See diagram https://www.searspartsdirect.com/model-number/LA212/3048/0153000.html?searchType=modelSearch&q=LA212&searchTerm=LA212
Nov 02, 2017 | Maytag Washing Machines
Maytag washer
the timer might be broke, well let me explain more the prongs on the back of the timer might not be making contact so the washer will not start.
Feb 12, 2008 | Maytag Atlantis MAV7260B Top Load Washer
Water fills but does not agitate or spin
THIS UNIT HAS A DOOR SAFETY SWITCH WICH ALLOWS WATER TO COME IN BUT NOTHING ELSE TO HAPPEN IF THE DOOR IS OPEN I WOULD START BY CHECKING THIS SWITCH.
Nov 29, 2007 | Maytag Atlantis MAV6260AWW Top Load Washer
Maytag HAV2557 Top Load Washer Logo
158 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
