Question about Dell Inspiron 2200 PC Notebook
Connecting TV via cable.
I once have this notebook connected to my television. For some reason it no longer boots up via my PC connection for my television. I have checked the drivers and it gives me four plug and play monitors that are installed which seems odd. I have tried uninstalling them and reinstalling them but I get no response to my television. Any advice?
  • pookiy1980 May 17, 2008
    Sorry, I am new here and just saw this option.
    As I posted I am having the same problem, although I can not find a "F?" key on my computer....any help?
I too have the inspiron 2200 notebook and cannot get the picure to show on my tv.
I do not see a F? key nore a key with a small monitor icon.....
where shoudl it be located?
Posted on May 17, 2008
    Brigadier General:
  • 6,966 Answers
Try lowering your laptop's screen resolution and refresh rates to the lowest possible.
Additionally, you need to press Fn + F? keys on the laptop to cycle on laptop display, laptop display + external display and external display. The F? key would be the one with the small monitor icon.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 15, 2008
How do I change source resolution on my TV?
connecting PC to Tv through VGA - Tom's Guide
www.tomsguide.com/answers/id-1891563/connecting-vga.html
Nov 20, 2013 - Q: Can I connect the TV to the PC via a VGA cable...bearing in mind the .... Forum; SolvedI'm trying to connect my Sony bluray player home ...
Connecting my Plasma to my PC via the VGA port. - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - Ensure that the VGA cable is working properly using other methods. Perhaps .... I am trying to connect my pc with my samsung tv. .... I'm very sorry to hear that has happened, and I apologize for any inconvenience this may have caused you. Connection between Dell laptop and Samsung TV
Jun 11, 2015
How to connect computer to tv with sound and picture?
Jun 5, 2015
PC Audio won't play through connected Samsung LCD TV
Jun 4, 2015
Connecting computer to TV
Jan 18, 2008
More results from www.cnet.com
My custom built PC will not connect to my TV via VGA cable ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Jun 28, 2013 - 5 posts - ‎2 authors
Jan 31, 2016 | VIA Computers & Internet
How to connect laptop to my tv
The only output you have on this laptop is a VGA monitor connection.
See manual.
HP Compaq 6820s Notebook PC QuickSpecs c04151583 pdf
You need a TV with a PC connection to view the video.
You will also have to connect up the speaker sockets t the TV audio in via a cable, that depends on the TV.
Feb 01, 2014 | HP Compaq 6820s Business Notebook
What channel does the tv have to be on to play a dvd?
That will depend of how you're connecting the DVD player to your TV. If your connecting via Coax cable (threaded screw type), then it'll be channel 3 or 4. If you're connecting via AV (3 round connectors), then the channel will be "input... AV". If you'e connecting via Component (5 round connectors), then the channel will be "input... Component". If you're connecting via HDMI (small flat D-shaped connector), then the channel will be "input... HDMI". See a pattern?
Jul 19, 2011 | iLO IWT3206 TV
Toshiba L355-S7905 does not want to connect to tv via vga port(no other ports available) The pc monitor goes dark after connecting vga cable to it. the TV says ''no signal'' is there anything that needs...
First without connecting the external Monitor/TV Go to display properties and Lower down resolution then when you connect the TV press and hold the Fn key on the left bottom of keyboard between Ctrl and Alt and while holding FN ket down press Change monitor button ( Normally F5)( must be having 2 monitor kind of image printed on any of the function key) once then twice or thrice to shift between different options like display output on one monitor, 2 monitor, extended display etc.
May 24, 2010 | Toshiba Satellite L355-S7811 Notebook
I want to connect my laptop to the tv via an s
Once connected through S-video, you have to ensure that the proper source is chosen on your television. The command is usually Fn+F4
Jan 18, 2010 | HP Compaq Presario V2000 Notebook
Gateway notebook goes BLACK when connecting new lcd tv to laptop
try setting the frequency down to 60hz and the resolution before you connect. then if it works you can set it up again with a setting the TV likes
Jan 08, 2010 | Gateway MT3705 Notebook
Blu Ray connection on notebook to tv
i would go with the dvi or, avi pc inputs. this will mesh well with this Phillips.
Feb 15, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Hi, I'm having a problem connecting my laptop to my TV via S-video to RCA cable. I have it connected correctly, hjave tried restarting, but get no video on my TV
I found the problem.
I was connecting it throught an RCA switch box, it worked when I connected directly to the television.
May 09, 2008 | Computers & Internet
Connecting my acer aspire 5100/5102 to my tv via cable
There are a number of possible ways to getbthe display up onto your television. Im not certain which colours to use with which but once its all plugged in you will need to hold down the FN (funtion) key and press one of the F1-F12 buttons. to work out which one you just need to look for a button that looks like a screen or two screens and that should make the display external. good luck
Feb 07, 2008 | Acer Aspire 5102WLMi Notebook
Connecting PC to sony SXRD with RGB cable no display?
How are you connecting the PC to the TV (ie which input and what type of cable are you using?)
Aug 12, 2007 | Sony KDS-R50XBR1 50" HDTV
Dell Inspiron 2200 PC Notebook Logo
79 people viewed this question
Alun Cox
