Question about Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls
There is a dime stuck in one of the 3 vanes in the drum--I can see it through the holes. Can I get it out myself or do I need to call for service. If I have to call for service, how involved is the repair?
  • 2 more comments
  • robmel795 Sep 13, 2010
    In the interim, can I still use the washing machine without causing damage?
    It rattles.
    How familiar are you with this particular model? I decided to wash another load and did not hear any rattling during the cycle. When the load was done, there was no rattling when I manually rotated the drum as there had been when I initially asked my question. Where do you think the dime went and should I be concerned? It seemed to be trapped inside the vane--are there drain holes under the vane leading to the drain pipe or are the vanes just attached to the drum to assist in agitating clothes? I really like the machine and don't want to cause any damage. Thank you.
    I don't see a panel on the lower front side of my machine to remove. I did not purchase a pedestal with my machine, and all of the panels are located on the top front as the picture shows. Would the coin trap be in the back?
  • Electrolux Master
  • 19,396 Answers
Hi.
the coin should end in the coin trap, whigh is located in hose to drain pump.
The coin should not cause any damage to machine, try washing it down by performing a cycle with no load, set half load and eventually forward cycle to drain after filling.
Once you drain down the coin, this will end up being caught by the trap filter.The coin trap is accessed removing the panel at the lower front side of the machine. Be prepared to collect water in the hose with a container. Remember to disconnect power before performing any maintainance.
Posted on Sep 13, 2010
  • Ginko
    Ginko Sep 27, 2010
    Re:"Where do you think the dime went and should I be concerned?"
    The coin is gone in the filter trap, before reaching the drain pump. That was summarily explained in my previous comment.
    If you think this was helpful, please do not forget to accept.
    Thanks.
  • 10,865 Answers
Hi. If you can see it, you may be able to reach it with a tiny pair of needle nosed pliers and some patience. Other wise call a couple of shops and explain the problem. Ask them what they will charge u to come out and remove the dime. J.
Posted on Sep 14, 2010
  • Electrolux Master
  • 16,994 Answers
MY question is what problem is the dime causing? IF it is just bothering you leave it there. It cannot do any damage. Even if it is loose in the drum behind the fins there is still no problem.
Hole in plastic outer drum
I have plastic welded my son's hockey skate with an automotive bumper cover welder and surprisingly it has held up-its basicly like a soldiering iron with a dime size foot on it-it came with a universal welding sticks that have kevlar fibers in it-I would back up the repair area with 3m aluminum repair tape and fill in your hole-cheers Denyy
Oct 21, 2013 | AEG Lavamat 12710 Front Load Washer /...
Sounds like I have a coin in the neptune dryer under one of the fins inside the drum. how do I get it out?
Disassembly of the front and top of your dryer can be found in the Service Manual at the link below beginning on page 9-1. Once the top is raised turn the drum slowly clockwise until the screws for the vane you wish to remove are at the top. Loosen the screws just a few turns and turn the drum until the coin or article falls out. Repeat for each vane until you find the noisy object. Reverse the disassembly to reassemble.
MDE5500 Service Manual
Oct 04, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a LG WM2016CW washing machine and there is change (penny,nickle,dimes ect.)stuck in the drum some were, how do i get them out?
You said "stuck" in the drum somewhere? Like under the agitator vanes? You should be able to take the lid off the agitator, it should either clip in or have a screw holding it on, and there you will see the nut, or keeper that holds the agitator on the motor shaft. Remove that clip or nut and you can lift the agitator out of the washer. From there you will see all of the wash drum and should be able to remove any foreign objects. If these "coins" are between the inner and outer tub, then you will have to remove both the top cover and lid, and remove the agitator and the inner drum to get to the outer drum in order to reach these objects. Not a hard job, but it will take you a little while. You could try reaching with your fingers around the agitator bottom and see if you can "feel" the coins or objects and possible use a small brush or stick or popsicle stick to move them out so that you can reach them, Kinda like "fishing" under the refrigerator or the couch. In the alternative, you could enlist four friends and unhook the washer from the water supply and the electric, and turn it upside down and try to shake the coins or objects out the top of the drum. Tilting the machine to one side will let them fall to the cabinet sides and possibly drop out the bottom when it is uprighted. Now I know why Mom always "checked" my pockets before she washed Dad and my clothes. We left a little of everything in there, from time to time. Good Luck with this.
Sep 27, 2009 | LG WM2688HWM TROMM SteamWasher
Removing drum vane
No! Remove the screw holding the vane and slide it towards you. It will then come out.
May 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
Money (change) caught inside interior drum plastic pieces.
Remove the top lid.
Rotate the drum until a vane is at the 12 o'clock position.
Remove the screws from the drum holding the vane in place.
May 10, 2009 | Kenmore 63942 Dryer
Kenmore Elite Dryer with loose paddle- can I glue?
Unplug the dryer.
Remove the lint filter.
Remove the screws at the lint filter opening.
Pop the lid clips on the left and right front corners of the cabinet.
Rotate the drum counterclockwise until a tumble vane(paddle) is at the 12 o'clock position.
Tighten the screws going through the drum.
Repeat this for the other 2 vanes.
Re-assemble the dryer.
May 10, 2009 | Whirlpool LEB6300 Electric Dryer
Dryer vanes came loose... can't figure out how to remove front or top panel to access the outside of the drum in order to tighten the bolts/screws that hold the vane in place.
use a putty knife and about 4 inches inside on each side insert the putty knife between the frount panel and the top and lift up on both sides, the tub will be visable to the screw holes in the tub to reinstall the vanes
May 27, 2008 | Magic Chef Dryers
Kenmore Dryer Model 417.80042990 problem
Could be just that. Thin coins like that can get into the drum baffles (those 3 "vanes" inside the drum that lift the clothes). It's a simple matter to open the top, remove the baffle(s) and clean them out.
Dec 29, 2007 | Frigidaire FEQ332E Electric Dryer
Not heating the food
sam..vane...two different problems.
Sam...find out if you've got power in the outlet you're using. If not, you've got to check to see if you've got a blown fuse in the unit. Also ...see below.
vane...chances are you have a power issue or the thermosensor which is used for a safety has blown. It is the size of a dime and 3/8 inch thick...black...two wires. You'll probably find it has opened. Found attached inside the control area to the side of the microwave heating area.
Dec 16, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Elastic eating front load washer
Check the inside drum vanes. Sometimes the vanes may crack and grab certain items.Next check the front of the drum and tub for any loose items like wires from bras or curtains sometimes these may get stuck in the drum or vane and cause this problem.Also check your soap make sure there is not alot of suds this is my number one problem with these machines.H.E. soap is best but watch liquid tide it's been sudsing alot.
Oct 03, 2007 | GE WSXH208A Front Load Washer
Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls Logo
199 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
