Wiring diagram model number E3EB-O17H - Heating & Cooling
  • i want sonometer block diagram
Posted on Nov 03, 2010
I have a nordyne furnace model # e3eb-017h. Furnace doesn't kick on at all. No relay click or anything but it's getting power. Did the thermostat trick with touching wires together to kick on the furnace...
Check the pilot light sensor. Have seen this issue before. Sometimes after lighting need to hold it in longer. If it doesn't detect the lit pilot wise it will sit in safety shut down mode
Oct 28, 2014 | Heating & Cooling
Kelvinator wiring diagram for wall mount air conditioner model ewh09hra
Good Morning Friend,
I understand that you are looking for the wiring diagram for your Kelvinator air conditioner, model# EWH09HRA. Typically, the wiring diagrams are not readily available. I suggest contacting the manufacturer, and have your model number available for them. They might be able to locate a copy of the wiring diagram of your air conditioner for you. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Electrolux Heating & Cooling
Where on internet can I find a diagram of the furnace listed below?
Google that number. Find manufacture, go to their site search customer support or contact us. Ask them for it.
Mar 05, 2014 | Intertherm E3EB-017H Furnace 17Kw 2
HOW TO WIRE E3EB-20 TO PANEL BOX
I'm just assuming that is 220 volt 20 amp The wire that is run is likely a common romex 12-2 NMD-90 Strip the 2 wires put red tape on the white wire as it is no longer a neutral. Hook both wires into a double 20 amp breaker. Put the ground wire onto a ground screw.
Nov 28, 2013 | Heating & Cooling
How do u wire athermostat to the furnance and ac unit on model e3eb-015h nordyne
You need to get low voltage wire known as 5 wire. run wires thru wall to stat and furnace Red wire goes to R terminal white to W terminal Green to G terminal Yellow to Y terminal on both the stat and furnace circuit board. Now you need a wire called 2 wire low voltage wire run that from furnace circuit board to outside A/C. At furnace hook red wire to Y terminal and white to C terminal doesnt matter which ones you hook up at outside unit. Do it just like i told you this will work properly.
If this helps please rate me.
May 20, 2011 | Heating & Cooling
I have a maytag gas range model #mgr445bdb I had a rat eat wires going to the oven looking for a wiring diagram .. I can't find my book
Hi and welcome to FixYa, I am Kelly.
The model number you provided is missing 1 digit. There should be 1 more digit after the 5.
Here is the wiring diagram for model number MGR4451BDB
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28482336&pkw_=basket&model_id=5170960&NewWindow=1
If this is not your model number you can go to this link and enter your model number:
The wiring diagram will be the last diagram on the left side of the page at the bottom.
Thanks for choosing FixYa,
Kelly
Feb 17, 2011 | Maytag Kitchen Ranges
Fan Only Won't Work
I jumped the rc and rh wires in the therostat box and now have fan only when selected.
Jul 01, 2008 | Heating & Cooling
Wiring diagram
i need a air conditioner wiring diagram
Apr 25, 2008 | Intertherm P3RC-030K Air Conditioner
Heating & Cooling Logo
115 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
