Question about Marshall JVM410C 100 Watts Valve Guitar Combo
My brand new Marshall JVM410C 100 watt combo gets very hot. Is this normal?
  • Marshall Master
  • 5,603 Answers
"Very" is relative... yes they do get warm but nothing you should not be able to hold your hand for extended period.
The amps are probably only 30% efficient overall, and the rest comes out as heat... it has to go somewhere, so the case must get hotter than the surrounding air to get rid of the energy.
Posted on Sep 13, 2010
Bought amp 1 year ago, three months ago, no sound, Guitar Center said call an authorized repair shop. I did'n't open it up to check fuse because i didn't want to void the warranty. The shop replaced the...
Possible that the output tubes that were replaced are drawing too much current, hence the popping sound (may be "motorboating", one common word to describe a similar sound)
This means the tubes need to be biased properly. You need to get it to someone who knows what they are doing, ie a good amp tech, not GC. The voltages here are dangerous.
Feb 25, 2011 | Marshall JVM410C 100 Watts Valve Guitar...
I was playing my guitar on my marshal until i noticed the volume started to quit down until the sound totally died out. and now the amp is turned on and all the valves are on but theres no sound whats so...
Just because the voves are lit doesn't mean there is the high voltage power to the valves.
ALSO the smaller valves have TWO heaters in them and if one half has burned out that would cause the symptom. Check if the smaller 12AX7/12AT7 types all have two heaters burning. Verify that the standby switch has not gotten bumped off.
Jan 19, 2011 | Marshall JVM410C 100 Watts Valve Guitar...
My marshal jvm410 head seems to lose its tone and volume sometimes completely. It does it occasionally and often when it does there is a lot of other noise. One time it went up and down in volume and off...
Given the symptoms you have, the following possibilities are likely:
1. Bad jacks or the switch contacts on them, especially one for power amp input or insert.
2. Bad solder joints... very often where volume controls attach to the circuit board.
3. Cracked circuit board.
In any event, opening the unit and servicing is the only option. The vibration of the unit causes intermittent contact which causes the problem.
Jul 25, 2010 | Marshall JVM410C 100 Watts Valve Guitar...
The valves on my Marshall TSL 122 are getting to hot.What might be the problem? Can you get me the scheme for that amp?
Probably the bias is set wrong... Please note that when installing MATCHED pair tubes, the tube pairs usually go at opposite ends of the strings, that is one on either side of the center of a set of four.
Jul 23, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Where can I get a schematic of the circuit board for the MG100DFX. The main fuse as blown and I need information on wiring connection to the transformer and values of other components.
Just a hint to troubleshoot: Connect a 100 Watt light bulb in series with the hot side of the power line into the amp. Make a cord with a light socket and a receptacle to plug the amp into. This acts as a resetable fuse and will send enough current through the amp to not fry stuff, but enough to do troubleshooting.
Apr 01, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
What is the position of each valve on the Marshall JVM410C chassis? I assume the one with the screen can is V1 but does it run from right to left from there for V2, V3 etc?
It doesn't matter. It takes 5 ECC83 tubes which have a smaller tube socket than the output tubes. The output tubes are 4 of EL34. If this helps please rate me.
Feb 23, 2010 | Marshall JVM410C 100 Watts Valve Guitar...
My Marshall JVM Has no power to the Valves
The schematics I found show SEVERAL fuses on the secondary side of the power transformer. I suspect one or more of those are blown. The fuses include the filament power.
As an electrical engineer I will have to caution you on leaving the amp in standby for extended periods. The high voltage rectifier circuit has NO bleeders in this unit and IF a power line transient occurs while in standby, the filter caps CAN be pumped up over their ratings causing them to fail.
Since you had no heaters lit in the tubes, you better pray that the heater fuses have opened as the only other thing is a failure of the power transformer since the neon pilot light is right across the 120 volt primary connections.
Dec 02, 2009 | Marshall JVM410C 100 Watts Valve Guitar...
Marshall MG100DFX noisy
Before you bring this into a shop, try spraying out all of the controls. Use an electronics switch cleaner that contains a lubricant. Spray into the control and work the control back and forth a number of times to loosen up any dirt inside. Then spray it again.
Let me know if that resolves the problem.
Thanks,
Dan
Feb 14, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall MG100 DFX manual
If you just bought it new, Marshall will replace any parts, or the store you got it from. If its second-hand I would have a look on ebay for parts.
The user guide can be found here...
http://www.marshallamps.com/product.asp?productCode=MG100DFX&pageType=DOWNLOADS
Good luck, its a sweet little amp!!!
Feb 13, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall Amp Sound Problem
try cleaning the send and return sockets with switch cleaner or WD40
Jan 31, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall JVM410C 100 Watts Valve Guitar Combo Logo
102 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Leonard Jeffrey
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
