Question about White Sewing 1418 Mechanical Sewing Machine
W1409 model, I need a diagram on how to put the tension knob parts back on
    Genius:
  • 1,788 Answers
You can google, tias, relics and they have a service manual for White & dometic generic and it would help you. It costs $21. but maybe a better way would be to go to www.sewingpartsonline.com and buy the part for $19. with the directions, and they will be able to tell you how to do it. It must have had a problem to begin with, so it may not work if you get it back on. Good luck, but I think I would opt for the new part, if it were me.
Posted on Sep 13, 2010
Brother jx2517sewing machine the tension dial knob came off want a step by step how to put it back on
You should have a book for your machine with detailed diagrams. If you need a book, you can find it online. Should be free to copy and print.
Otherwise, all machines are the same, and usually when the knob comes off, behind it there are two discs that may have come off too. Replace the discs so that the slight curve - so the two scoop toward each other in the middle. Put them on the screw, followed by the tension knob. Tighten until you have contact with discs. (Or re-set to number you think you used last.) Re-thread the machine, both top and bottom. When you pull both threads, together, one thru needle, and the other under lifted feeddog foot you should feel near equal tension on both. Now sew a few stitches on some doubled piece of fabric. Remove, leaving threads. It should look the same on both sides. Any machine book will show you what that looks like.
Machines are pretty durable, and forgiving. You cannot mess anything up by trying. They do, however, want to be threaded correctly to sew happliy. Very often, a machine that has not been used or cleaned for years - the bottom thread tension will get 'off.' Easy to check - remove bottom assembly. Hold it by the thread. If the assembly slides down, it is too loose. If shaking it will not get it to slide, then it's too tight.
Jan 04, 2018 | Brother Sewing Machines
How to thread model 661 sewing machine
From the photo, it appears that you may have the thread path correct, but it does appear that the thread is not seated in the tension disk (the round knob that the thread goes around before going up to the take-up lever). There is a spring in the tension disk that needs to be activated. FIRST, be sure when you thread the upper thread, ALWAYS RAISE the presser foot. These releases the tension disk and allows the thread to seat. Also, when going around the tension knob, hold the thread above where it goes around the knob and make a complete circle around the tension disk and tug. This should seat it in the spring.
Brother 651 Charger Sewing Machine Threading Diagram
A manual would be most helpful, not only in how to use your machine but also how to maintain (clean & oil) it.
If you don't have a manual, search the internet for:
Make + Model + the word "Manual"
Oct 26, 2016 | Sewing Machines
Janome Super Novum mk X
You can try searching for:
Make Model parts diagram
Feb 06, 2018 | Janome Sewing Machines
Thread tension control knob parts list.
There are just so many kinds of tension control knobs. Do you have a photo or model number?
Jan 30, 2014 | Simplicity Sew Precious SWSP2 Mechanical...
Tension mechanism
What make and model sewing machine?
Jul 13, 2013 | Sewing Machines
Kenmore 1249 top tension control is apart and don't know how to reassemble
Contact Kenmore.
http://www.searspartsdirect.com/partsdirect/brands-products/Kenmore-Parts/Sewing-machine-Parts?page=1
I don't see your model, but if you use the chat or call the number they may be able to send you a parts diagram with the info you need.
Nov 11, 2012 | Sewing Machines
Hi! i was just gifted w/ a kenmore sewing machine model # 12121 i havent even plugged it in yet. I noticed that the top thread tension control knob has fallen off. it appears to have all its pieces, but i...
Open the left end door that accesses the light. On the edge of the casting by the tension control, you'll see a set screw tapped into the hole that the upper tension control fits into. That set screw locks the tension unit into the casing. If the upper tension unit is in peices, you'll need a diagram to re-assemble it correctly. If you don't assemble it correctly, it will NOT work right.
Jan 03, 2011 | Kenmore Sewing Machines
Clutch Release Problem
You will need to remove the clutch release knob and the 3 eared positioner (the clutch) under that knob. Reposition the clutch on the shaft, put the knob back on and see if you can put the screw back in the hole. If it hits something, remove the knob, remove the clutch and turn it 180 degrees. This will reposition the ears. Put the clutch back on the shaft, put the knob back on the shaft and screw the screw into the hole. Test to be sure the knob releases the hand wheel to wind the bobbin.Be sure the thread is under the thread guide when you wind the bobbin and that there is a slight tension on it.
sewman7
Jan 16, 2009 | Brother Sewing Machines
White Sewing 1418 Mechanical Sewing Machine Logo
67 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
