My child pulled the tape out of the mini DV. I tried to smooth it out, and reinserted it. It played OK for a while, but then read "eject cassette". Can the tape be salvaged, and so, who repairs tapes?
You have to make sure that when the tape was put back in the cassette, that it maintained it's side to head integrity, in other words, that it did not flip so at a certain point, the back of the tape is running against the drum and head in the machine. If that is the case, then you should insert the tape and rewind it and fast forward the tape 2 or three times and then let the tape rest for a day fully rewound or fully fast forwarded. This should iron out the small wrinkles, but unfortunately, the big creases in the tape will cause a loss of information so the picture will fail. You should transfer the tape immediately to your computer and burn a DVD as your tape has a very short life span now,
If recently recorded plays back ok, and there's no warning about low rf or head clogging problems,it seems to be electronic problem in vtr board,but usually is head problem,which is not so expensive.
If you are referring to the JVC GR-DVL520, yes it does play Mini DV tapes, as well as records to them. It will not play Mini DV tapes that were recorded on an HDV camera. HDV is used by any Mini DV camera that records HD video.
Only way is Play burned DVD in dvd player and provide Audio- Video out (yellow-red-white) to mini DV camera that has AV Line Input recording facility. Or find any Mini DV recorder and record tape. In that way you can record video again on Mini DV tape.
If the problem only shows with Mini DV tapes, it can be a tape guide issue or a mchanism loading problem where the tape is not being properly "seated" into the tape mechanism. You will need to use an oscilloscope to look at the RF waveform coming off the tape to try and figure out where your problem is.
it is probably matter of dirty guide so the timecode stop reading
try a wet head cleaning tape to play it there
regards
please don't forget to rate ,thx
