Cannot turn caption off .option not available on menu
  • Anonymous Jun 03, 2008
    I cant turn the caption off my tv..
  • 520 Answers
There may be a closed caption button on remote. Might say cc or tv/cap/text etc.
Posted on May 15, 2008
Can I turn the caption mode off with the remote?
CC (Closed Caption)
To select the options in the CC sub-menu, press the MENU button or the #
button. A new menu will be displayed showing the following CC settings:
CC
The CC feature is available when watching regular analog (NTSC) TV.
Select from CC1, CC2, CC3 or CC4. Closed Caption for regular TV is
usually CC1 or CC2.
Digital CC Style
The Digital CC Style feature is available when watching digital TV.
Select either As Broadcaster or Custom. If Custom is selected then
you can customize the way Closed Caption is displayed.
Feb 14, 2015 | Vizio VF550M 55 in. LCD HDTV
How can i play english subtitles in my tv lg 42 inches
If the signal is from a digital source with multiple language options, then press Menu and go to Option (with the up/down arrows). Press the right arrow button and go to Caption Text. Press the right arrow button and use the up/down arrows to select English. Press Exit or Menu to save and either return to TV viewing or the previous menu.
Otherwise, you will be limited turning on the captions with the CC button and viewing the captions available with the video feed.
For some sources (DVD, satellite), you may need to change the caption options on that unit. See the appropriate manual for the device.
I hope this helps.
Jan 22, 2011 | LG 42LC2D 42 in. LCD HDTV
2008 Samsung 32" Flatscreen 720p Channels are
The cc has been enabled on your cable box. Usually there is a hidden menu accessed by turning off the cable box. Yes I did say turning off the cable box first. Then immediately pressing the menu button on the front of the cable box. The hidden menu should pop up and one of the menu options will be closed captioning,. Disable it.
Nov 09, 2010 | Samsung LN32A540 32 in. LCD HDTV
HOW DO I REMOVE THE SUBTITLES FROM MY SONY BRAVIA
The Subtitle option is available only with the connected devices like DVD Player, Blu-ray Disc Player etc. The option avaialble in the TV is known as Closed Caption. The Closed caption option can be turned off by selecting the options below:
Press Menu button on the TV Remote. Select, Setup settings. Then select Caption Vision option to OFF. This option is for turning off the Closed Caption option in the TV to OFF. For disabling the Subtitle option in the connected devices like DVD Player and Blu-ray Disc Player, press the SUBTITLE button on the supplied Remote continuously to select OFF.
In few of the TV broadcasting channels the Subtitles cannot be turned OFF as this is being broadcasted with the channels.
Good Luck! KenSolutions
Oct 28, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Turning off Closed Caption
Are you using a cable/satellite box or just basic cable service?
When you go to the menu what options become available to you?
If the following options are present-
smartlock
setup
cc
If not try to press both the volume buttons on the front of the TV at the same time and see if the above options become available.
If so use the channel down button on the front of the tv to scroll to "cc"
Once CC is highlighted use the volume + button until it says CC off.
If these menu options don't become available please reply what options are shown.
Good Luck.
Jan 05, 2010 | Philips Magnavox 20MS233S 20" TV
Need to know how to put the tv on close caption
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option.
1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
  1. 2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
  2. 3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
  3. 4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
  4. 5)If you're watching a DVd on your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
  5. thanks.
Nov 11, 2009 | Televison & Video
I need to activate CC for my Dad, Please help I have to go to work. I have a flat screen SOYO
Determine if closed captioning is available on the program that you've selected. In your program guide, the letters "CC" should appear at the end of the description.
Locate the closed captioning option on your remote. Some remotes have a "CC" button that you simply need to push to activate closed captioning
Locate the closed captioning option in your television's menu if there is no "CC" button on your remote. To do this, push the "menu" button on the remote control. The closed captioning option will probably be in the same section as the language function.
Set the closed captioning option to "on." Within several seconds, you should see the text appear on your screen.
To use closed captioning for DVDs, look for the "CC" label on the lower back section of the DVD case where it lists audio information. Turn on your TV's closed captioning and you should see the captioning like you do on a television program. Alternately, some DVDs include English subtitles that you can turn on in the setup/language menu of the DVD.
Thank you.
Aug 28, 2009 | Televison & Video
How do I turn ON Closed Captioning.
It sounds like that option is not available on that model , contact samsung
Dec 07, 2008 | Samsung DLP HL-P5663W 56" TV
Closed caption
maybe in cable box setup?
May 27, 2008 | Samsung DLP HL-P5663W 56" TV
Cant get rid of captions
look on top and behind of the monitor you will find buttons for your TV then follow this steps: The Setup menu lets you configure the TV to fit its surroundings and your preferences. To access the Setup menu, press MENU, and then select Setup from the Main Menu.closed caption options are: CC Setting Lets you choose the way closed captioning information appears on the screen. Off No captioning information displayed. On Always Captioning information shown always, when available. On When Muted Displays captioning information, when available, whenever the TV?s sound is muted by pressing the MUTE button. The captioning information is not displayed when the sound is not muted. Make sure all of the options for closed caption are off press exit and you are good to go.
Aug 23, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
