Question about Goodman Heating & Cooling
Outside unit won;t come on blower on furnace inside works central air unit is 5 yrs old
  • 674 Answers
First check the disconnect/circuit breaker for the outside unit. Then set the thermostat to make the unit come on. Remove the cover on the outside unit where the power goes in so that you can see the contactor. Is the contactor pulled in? If it is, check for proper voltage on the load side of the contactor. If thats good then look at the capacitor. If it looks swollen then it is bad otherwise you can check it with a multimeter or have a heating and air supply check it for you. If the contactor isn't pulled in, remove the face of the thermostat and install a jumper between the R and Y terminals. If the contactor pulls in then, the thermostat is bad. Let me know what you find so I can give you more advice if this doesn't get you going.
Posted on Sep 13, 2010
Bryant FA4ANF04200 Operation is intermittent. Some of the time it will go on when set to heat or cool. Other times, it will not turn on. Replaced thermostat. Problem continues. Sounds like defective...
Is this a heatpump system or a gas furnace /a/c system,you have a 3 1/2 ton a/c unit,if it is over 5 yrs old it could be a board problem,look for any spliced wiring where they used little wire nuts to join wires,these can make bad connections,?does the blower turn on,is the outside unit running but no airflow,if you have a gas furnace it may have a window,a little clear lens to look in at the furnace control board,it will blink a failure code if there is a problem,need more info :)
Mar 08, 2013 | Heating & Cooling
I HAVE A CARRIER CENTRAL AIR, THE OUTSIDE FAN IS BLOWING INWARD AND WON'T SHUT OFF WHEN THE FURNACE SHUTS OFF AFTER TEMP IS REACHED
Check the t-stat to make sure that the "fan" switch is st to auto. If not the fan is in the "on" position and is always on. Otherwise, It sounds like your "Central Air" is a packaged unit(Furnace and air all one unit outside the home) and the fan relay inside the unit is stuck. This need to be replaced. It is the rectangular unit with the leads from the fan motor attached to it.
Jul 29, 2011 | Heating & Cooling
I have a Goodman gmp100-3 furnace and a/c unit. The outside fan and compressor are working but the inside blower won't come on Any Help ?
try putting thermostat on fan only see if it runs,if not check for any broken or loose wire on the thermostat wire take cover off and check.
Jul 17, 2011 | Heating & Cooling
The furnace part of my central air is wired to a seperate breaker but keeps tripping the breaker and making a spark in the breaker box.
Usually a Central Unit is wired seperate, the Air handler inside and the
Cooling unit outside. It appears that the breaker is bad, is it a Single Pole Breaker?
Another possibility is that the indoor blower motor might be bad.
Jan 10, 2010 | Heating & Cooling
Hello We have a Trane central air
Bad thermostat, improper wiring or bad circuit board in furnace. Turn off the disconnect outside.
Dec 30, 2009 | Heating & Cooling
My AC unit wont blow the cold air.
if the ac outside is working, but not the furnace, means there is a control problem with the furnace, check wires in the furnace, make sure there is a blower wire plugged into the contact marked cool on the control panel of the furnace
Jul 09, 2009 | Fedders A&B Chassis A1A07W2B Air...
AC unit turns on blower doesn't come on
The thermostat is the controller.
Jun 19, 2009 | Heating & Cooling
Rheem Central Air united stopped working, no hum but power is there
It looks as if the 24 signal from the thermostat is not getting to the contactor. Or possibly the coil in the contactor itself is dead. Or a third option may be a bad control power board in the condensing unit itself. If you feel comfortable reading through these devices comment back. PLEASE REMEMBER THERE IS HIGH VOLTAGE INSIDE THE CONDENSER AND A CAPACITOR.
Jul 06, 2008 | Ruud Heating & Cooling
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
