Question about JVC AV-48WP30 48" Rear Projection Television
V-chip lock please help me unlock my v-chip. I have a JVC projection t.v. And the v-chip is lock. I can not seem to unlock the v-chip I tried and now I have a black box appearing on my screen which prevents me from seeing the picture, please help me
  • 30 Answers
SOURCE: Lens cap fault on JVC GR-D72
This is a known problem with this model. The cause has been identified by JVC as a failure of the CCD image sensor. Until October 1, 2007, repairs of units exhibiting these problems will be made free of charge at JVC Factory Service Centers.
Posted on Apr 05, 2006
TVtechmaniac
  • 140 Answers
SOURCE: JVC AV 32120
Sounds like your "CC" (closed captioning) is turned on and it is set to text mode.Go into the menu and turn the closed captioning "off". The default v-chip unlock code is "0000"
Posted on Sep 27, 2007
ctf1800
  • 4402 Answers
SOURCE: convergence problem on JVC
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Posted on Jan 31, 2008
  • 375 Answers
SOURCE: Locked!
try entering your menu setup and turning off the text and cc modes,look on your remte for the function also.
Posted on Apr 13, 2008
doin12volt
  • 233 Answers
SOURCE: there is a black box
Try going into your tv's menu settings and turning of Closed Captions or "cc"
Posted on Dec 19, 2008
There. Is a channel lock on my tv. So I can't change the channels. How do I take it off?? Help!
Hello
you have to unlock your jvc set, and reset the V-Chip settings. There are two ways to unlock JVC TVs, you have to find out which proceedings frome below mentioned will work with your TV.
[1]
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
[2]
Select "TV" from the menu then select "V-Chip" from the drop-down list on the screen. "Please Input Password" will appear on the screen.
Enter your four-digit password by selecting numbers on the 10-pad that appears on the V-Chip menu display or your remote control. Create a new password if you forget it by unplugging your TV power cord from the outlet then reconnect the power cord. This procedure resets your password to "0000." Enter four numbers for your new password using the keypad on the screen or your remote and select the arrow to advance to the next number. Press "OK" on your remote or select "OK" on the screen to set your new password.
Unlock a TV rating or TV channel by selecting "MPAA" or "TVPG" from the V-Chip menu. Use the up or down arrows to select the locked rating then select "OK" on the display or press the "OK" button on your remote control to unlock it. The MPAA represents the U.S. Motion Picture Association of America rating system, such as "NC-17," meaning not intended for viewers 17 years or younger. TVPG provides you
May 10, 2011 | JVC AV-27020 TV
I bought a JVC Screen 48inch used now I am locked out of sound on menu sound like treble and bass is dull how can I get code to unlock I need to unlock code to a used Jvc tv so I ca hear sound, sound on...
Hello
To set Lock and unlock proceeding are give here:
Channel guard and V-Chip settings are protected by a four-digit lock code. Your TV comes
pre-set with a lock code of "0000". You may change the code to any four-digit number you
wish. To change the lock code, follow the steps below.
Press the MENU button
Press [UP/Down] button to SET LOCK CODE.
Press [=> / <=] buttons to operate [lock icon appears]
Press ZERO to acess the lock code. The first digit will be highligted.
Press [ => / <=] button to select the number.
Press [Up/Down] button to move the next digit and continue to follow these directions for all the four digits.
Press OK button to finish.
Press the menu button when finished
DO THIS AFTER UNPLUG THE TV FROM AC MAINS WALL SOCKET, AND LEAVE IT FOR ABOUT 30 MINUTES OR SO, REPLUG IT TO ac MAINS, AND DO ALL THE ABOVE SAID PROCEEDINGS. THIS PROCESS WILL ERASE ALL THE V-VHIP CODES, IF SET, AND WILL ALLOW YOU TO SET AN OTHER OF YOUR OWN. The default V-Chip code is [0000]. Ok.
Apr 24, 2011 | JVC Televison & Video
My JVC HDTV station is locked on Channel 3, How do I unlock it from this station
Hello
To unlock the panel lock of your JVC tv do the following.
Turn on the JVC television and press the "Menu" key on the remote control.
Use the Up and Down or Channel buttton to toggle through thre menu selections until V-chip appears.
Stop on V-chip and press the right arrow button to display a padlock icon
Enter the four-digit code by pressing the numbers on the keypad. If a code has not been entered, the default code is 0000 (four zeros).
Press the right-arrow key to unlock the channels
Unplug the JVC television for at least 15 minutes to reset the code to 0000 if a previously set code has been lost or forgotten
OK
Mar 22, 2011 | JVC HD-52G886 52" Rear Projection HDTV
Mitsubishi TV model ws-48315 v chip locked
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Apr 29, 2010 | Mitsubishi WS-48315 48" Rear Projection...
TV will not unlock channels over TV14
These steps are actually for the rear projection models, but I hope the work for dlp plasmas as well.
I hope that helps.
Jan 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
My JVC intergrate chip convergence chip went bad. I try to locate and fix it
If you need the convergence kit then you can try this.
http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
asnowman
Oct 15, 2009 | JVC AV-56WP74 56" Rear Projection...
My mitsubishi 1995 model vs 6055 is on parental lock
I can help you unlock your Mitsubishi HDTV V-Chip parental lock.
I hope that helps.
Mar 05, 2009 | Mitsubishi VS-6055 60" Rear Projection...
JVC AV-56WP30 56 black screen blue light on no response
make sure your front panel lock in your menu is not lock if is then unlock it cause it will lock everything on the tv in front and can't move anything
Jul 15, 2008 | JVC AV-56WP30 56" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
